I’m a little concerned about the temperature of the mt7921 Wi-Fi/Bluetooth module on my ASUS ROG STRIX B650E-F mainboard.
When I use Wi-Fi at 10 MB/s, the sensor reading rises to 80–90 (one-time peak of 124 °C!!) degrees Celsius?! At idle, it’s around 50 °C, which seems normal to me.
The Wi-Fi works perfectly, even at this temperature.
According to the module’s specifications, the maximum allowable temperature range is up to 70 °C.
Is the reading incorrect, or is the cooling at that location on the motherboard that inadequate?
inxi
Kernel: 7.2.0-rc4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: root=UUID=a2c104c7-14bf-4d19-b775-e2095cc8d407 rw
sysrq_always_enabled=1 udev.log_priority=3 nmi_watchdog=0 nowatchdog
initrd=\boot\amd-ucode.img initrd=\boot\initramfs-7.2-x86_64.img
Desktop: KDE Plasma v: 6.7.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
serial: <filter> part-nu: SKU uuid: 2500e437-a72d-7062-a7d6-60cf8477243b
Firmware: UEFI vendor: American Megatrends v: 3854 date: 04/03/2026
System RAM: total: 64 GiB available: 62.45 GiB used: 3.91 GiB (6.3%)
Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 32 GiB speed: 4800 MT/s volts: curr: 1.1 min: 1.1
max: 1.1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK64GX5M2B5600Z40 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Slot: 0 type: PCIe gen: 5 status: in use length: long volts: 3.3
bus-ID: 00:01.1 children: 1: 01:00.0 class-ID: 0604 type: bridge children:
1: 02:00.0 class-ID: 0604 type: bridge children: 1: 03:00.0 class-ID: 0300
type: display 2: 03:00.1 class-ID: 0403 type: audio
Slot: 1 type: PCIe gen: 4 status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 2 type: PCIe gen: 4 status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 3 type: PCIe gen: 4 status: available length: long volts: 3.3
bus-ID: 00:1f.7
Slot: 4 type: N/A status: available info: M.2 length: long volts: 3.3
bus-ID: 00:1f.7
Slot: 5 type: N/A status: in use info: M.2 length: long volts: 3.3
bus-ID: 00:02.2 children: 1: 0d:00.0 class-ID: 0108 type: mass-storage
Slot: 6 type: N/A status: available info: M.2 length: long volts: 3.3
bus-ID: 00:1f.7
Slot: 7 type: N/A status: in use info: M.2 length: short volts: 3.3
bus-ID: 05:0b.0
Info: model: AMD Ryzen 9 9900X3D socket: AM5 bits: 64 type: MT MCP
arch: Zen 5 gen: 5 level: v4 note: check built: 2024+ process: TSMC n4 (4nm)
family: 0x1A (26) model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 960 KiB desc: d-12x48 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 605 min/max: 605/5576 boost: enabled
base/boost: 4400/5550 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.3 V ext-clock: 100 MHz cores: 1: 605 2: 605 3: 605 4: 605 5: 605
6: 605 7: 605 8: 605 9: 605 10: 605 11: 605 12: 605 13: 605 14: 605
15: 605 16: 605 17: 605 18: 605 19: 605 20: 605 21: 605 22: 605 23: 605
24: 605 bogomips: 210790
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: vmscape mitigation: IBPB on VMEXIT
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: Tul / PowerColor driver: amdgpu v: kernel
arch: RDNA-4 code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie:
gen: 5 speed: 32 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3,
HDMI-A-1, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
Display: unspecified server: X.Org v: 24.1.13 with: Xwayland v: 24.1.13
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2024 res: mode: 2560x1440 hz: 180 scale: 100% (1) dpi: 93 gamma: 1.2
chroma: red: x: 0.686 y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149
y: 0.055 white: x: 0.314 y: 0.329 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: 2560x1440, 1920x1080, 1280x720,
1024x768, 800x600, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unknown tag 112
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.5-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi gfx1201 ACO
DRM 3.64 7.2.0-rc4-1-MANJARO) device-ID: 1002:7550 memory: 15.62 GiB
unified: no
API: Vulkan v: 1.4.350 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 26.1.5-arch1.1
device-ID: 1002:7550 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: amdgpu_top,lact wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
chip-ID: 0b05:1a52 class-ID: 0300
API: ALSA v: k7.2.0-rc4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.6.8 status: n/a (root, process) with:
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:125c
class-ID: 0200
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 0a:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp10s0 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5
chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
lmp-v: 12 sub-v: 2606 hci-v: 12 rev: 520 class-ID: 6c0104
Info: acl-mtu: 1021:6 sco-mtu: 240:8 link-policy: rswitch sniff
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Local Storage: total: 3.2 TiB used: 501.52 GiB (15.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR003 temp: 41.9 C
scheme: GPT
SMART: yes health: PASSED on: 335d 16h cycles: 2,024
read-units: 151,408,429 [77.5 TB] written-units: 138,369,211 [70.8 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 193d 6h cycles: 3027
written: 21.12 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS5C3020ALA632
family: Deskstar 5K3000 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 6.0 Gb/s tech: HDD rpm: 5940
serial: <filter> fw-rev: A580 temp: 35 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 5y 42d 4h cycles: 9423
ID-4: /dev/sdc maj-min: 8:32 vendor: Verbatim model: STORE N GO
size: 14.57 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
fw-rev: 1.00
ID-1: / raw-size: 864.68 GiB size: 850.03 GiB (98.31%)
used: 501.43 GiB (59.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: a2c104c7-14bf-4d19-b775-e2095cc8d407
ID-2: /boot/efi raw-size: 5 GiB size: 4.99 GiB (99.80%)
used: 90.2 MiB (1.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
maj-min: 259:3 label: N/A uuid: C980-0B5B
ID-1: swap-1 type: partition size: 61.54 GiB used: 0 KiB (0.0%)
priority: -1 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 14927854-56ba-4e55-8a65-89023498411b
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
uuid: 5C2E-2A1A
ID-2: /dev/sda1 maj-min: 8:1 size: 292.97 GiB fs: ext4 label: cachy
uuid: 1a177ab0-a8d8-404b-85ae-dfd4cbe54615
ID-3: /dev/sda2 maj-min: 8:2 size: 161.79 GiB fs: ext4 label: Timeshift
uuid: ed8facc8-ca20-417c-8a2e-49692c97eeec
ID-4: /dev/sda3 maj-min: 8:3 size: 11 GiB fs: swap label: N/A
uuid: 8e7033b8-3797-442c-8c0c-aea22c7404de
ID-5: /dev/sdb1 maj-min: 8:17 size: 1.15 TiB fs: ntfs label: Daten3
uuid: 86E470A6E47099DF
ID-6: /dev/sdb2 maj-min: 8:18 size: 686.12 GiB fs: ext4 label: BackupII
uuid: e0967a4a-9a0d-4483-a7fa-10fc96595cb7
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: ASUSTek USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
Device-2: 1-7:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Hub-2: 1-8:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-11:5 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 5-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 5-2.1:3 info: RY Micro Geeky GK65 gaming Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 480mA
chip-ID: 3532:c0c2 class-ID: 0300 serial: <filter>
Device-2: 5-2.2:4 info: Verbatim Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 100mA chip-ID: 18a5:0302 class-ID: 0806
serial: <filter>
Device-3: 5-2.3:5 info: Razer USA Basilisk V3 type: mouse,keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0099 class-ID: 0300
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 6-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-10: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 39.5 C mobo: 36.0 C gpu: amdgpu temp: 55.0 C
mem: 73.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 745 fan-3: 638 fan-4: 642 fan-5: 0
fan-6: 645 fan-7: 0 gpu: amdgpu fan: 41
Packages: 2191 pm: pacman pkgs: 2176 libs: 452 tools: pamac,yay pm: rpm
pkgs: 0 pm: flatpak pkgs: 15
1: https://ftp.gwdg.de/pub/linux/manjaro/unstable/$repo/$arch
2: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/unstable/$repo/$arch
3: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
Processes:
CPU top: 5 of 430
1: cpu: 7.0% command: firefox pid: 2202 mem: 580.3 MiB (0.9%)
2: cpu: 4.6% command: firefox pid: 2783 mem: 337.6 MiB (0.5%)
3: cpu: 3.5% command: plasmashell pid: 1405 mem: 367.8 MiB (0.5%)
4: cpu: 2.2% command: kwin_wayland pid: 1281 mem: 212.6 MiB (0.3%)
5: cpu: 1.9% command: ksystemstats pid: 1828 mem: 32.4 MiB (0.0%)
Memory top: 5 of 430
1: mem: 974.2 MiB (1.5%) command: clamd pid: 712 cpu: 0.2%
2: mem: 580.3 MiB (0.9%) command: firefox pid: 2202 cpu: 7.0%
3: mem: 367.8 MiB (0.5%) command: plasmashell pid: 1405 cpu: 3.5%
4: mem: 337.6 MiB (0.5%) command: firefox pid: 2783 cpu: 4.6%
5: mem: 333.4 MiB (0.5%) command: firefox pid: 2993 cpu: 1.7%
Processes: 430 Power: uptime: 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.93 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: clang: 22.1.8 gcc: 16.1.1 Shell: Sudo (sudo) v: 1.9.17p2
default: Bash v: 5.3.15 running-in: yakuake inxi: 3.3.41
sensors when wifi idle
k10temp-pci-00c3
Adapter: PCI adapter
Tctl: +48.6°C
Tccd1: +38.1°C
Tccd2: +37.0°C
nct6799-isa-0290
Adapter: ISA adapter
in0: 536.00 mV (min = +0.00 V, max = +1.74 V)
in1: 1000.00 mV (min = +0.00 V, max = +0.00 V) ALARM
in2: 3.41 V (min = +0.00 V, max = +0.00 V) ALARM
in3: 3.33 V (min = +0.00 V, max = +0.00 V) ALARM
in4: 1.01 V (min = +0.00 V, max = +0.00 V) ALARM
in5: 1.03 V (min = +0.00 V, max = +0.00 V)
in6: 704.00 mV (min = +0.00 V, max = +0.00 V) ALARM
in7: 3.41 V (min = +0.00 V, max = +0.00 V) ALARM
in8: 3.31 V (min = +0.00 V, max = +0.00 V) ALARM
in9: 3.33 V (min = +0.00 V, max = +0.00 V) ALARM
in10: 1.14 V (min = +0.00 V, max = +0.00 V) ALARM
in11: 1.12 V (min = +0.00 V, max = +0.00 V) ALARM
in12: 1.03 V (min = +0.00 V, max = +0.00 V) ALARM
in13: 440.00 mV (min = +0.00 V, max = +0.00 V) ALARM
in14: 2.04 V (min = +0.00 V, max = +0.00 V) ALARM
in15: 824.00 mV (min = +0.00 V, max = +0.00 V) ALARM
in16: 1.82 V (min = +0.00 V, max = +0.00 V) ALARM
in17: 1.04 V (min = +0.00 V, max = +0.00 V)
fan1: 0 RPM (min = 0 RPM)
fan2: 744 RPM (min = 0 RPM)
fan3: 644 RPM (min = 0 RPM)
fan4: 645 RPM (min = 0 RPM)
fan5: 0 RPM (min = 0 RPM)
fan6: 645 RPM (min = 0 RPM)
fan7: 0 RPM (min = 0 RPM)
SYSTIN: +35.0°C (high = +80.0°C, hyst = +75.0°C)
(crit = +125.0°C) sensor = thermistor
CPUTIN: +39.5°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN0: +43.0°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN1: +19.0°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN2: +20.0°C (high = +80.0°C, hyst = +75.0°C)
(crit = +100.0°C) sensor = thermistor
AUXTIN3: -62.0°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN4: +24.0°C (high = +80.0°C, hyst = +75.0°C)
(crit = +100.0°C)
PECI/TSI Agent 0 Calibration: +39.0°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN5: +24.0°C
PCH_CHIP_CPU_MAX_TEMP: +0.0°C
PCH_CHIP_TEMP: +0.0°C
PCH_CPU_TEMP: +0.0°C
TSI0_TEMP: +48.6°C
pwm1: 86% (mode = pwm)
pwm2: 44% (mode = pwm)
pwm3: 44% (mode = pwm)
pwm4: 44% (mode = pwm)
pwm6: 44% (mode = pwm)
pwm7: 128% (mode = pwm)
intrusion0: ALARM
intrusion1: OK
beep_enable: disabled
nvme-pci-0d00
Composite: +40.9°C (low = -0.1°C, high = +85.8°C)
(crit = +87.8°C)
Sensor 1: +40.9°C (low = -273.1°C, high = +65261.8°C)
mt7921_phy0-pci-0a00
temp1: +58.0°C
spd5118-i2c-11-53
Adapter: SMBus PIIX4 adapter port 0 at 0b00
temp1: +44.2°C (low = +0.0°C, high = +55.0°C)
(crit low = +0.0°C, crit = +85.0°C)
spd5118-i2c-11-51
temp1: +43.8°C (low = +0.0°C, high = +55.0°C)
amdgpu-pci-0300
vddgfx: 311.00 mV
fan1: 0 RPM (min = 0 RPM, max = 3650 RPM)
edge: +52.0°C (crit = +110.0°C, hyst = -273.1°C)
(emerg = +115.0°C)
junction: +54.0°C (crit = +110.0°C, hyst = -273.1°C)
(emerg = +115.0°C)
mem: +71.0°C (crit = +108.0°C, hyst = -273.1°C)
(emerg = +113.0°C)
PPT: 30.00 W (cap = 330.00 W)
pwm1: 0%
sclk: 45 MHz
mclk: 1 GHz
