Mt7601u usb wifi failure/issues
Hi,
there is this long time issue with a wifi usb adapter which seems quite common. When I plug that (with all the last kernel versions), I get the following error messages:
[  107.311072] usb 1-2: new high-speed USB device number 35 using xhci_hcd
[  107.463827] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[  107.463839] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  107.463843] usb 1-2: Product: 802.11 n WLAN
[  107.463847] usb 1-2: Manufacturer: MediaTek
[  107.463850] usb 1-2: SerialNumber: 1.0
[  107.587658] usb 1-2: reset high-speed USB device number 35 using xhci_hcd
[  107.736197] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
[  107.739631] mt7601u 1-2:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[  108.169485] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
[  108.359347] mt7601u 1-2:1.0: Error: MCU resp urb failed:-71
[  108.359357] mt7601u 1-2:1.0: Error: MCU resp evt:0 seq:5-4!
[  108.359438] mt7601u 1-2:1.0: Error: MCU resp urb failed:-71
[  108.359442] mt7601u 1-2:1.0: Error: MCU resp evt:0 seq:5-4!
[  108.359541] mt7601u 1-2:1.0: Error: MCU resp urb failed:-71
[  108.359544] mt7601u 1-2:1.0: Error: MCU resp evt:0 seq:5-4!
[  108.359652] mt7601u 1-2:1.0: Error: MCU resp urb failed:-71
[  108.359655] mt7601u 1-2:1.0: Error: MCU resp evt:0 seq:5-4!
[  108.359762] mt7601u 1-2:1.0: Error: MCU resp urb failed:-71
[  108.359765] mt7601u 1-2:1.0: Error: MCU resp evt:0 seq:5-4!
[  108.359768] mt7601u 1-2:1.0: Error: mt7601u_mcu_wait_resp timed out
[  108.498090] mt7601u 1-2:1.0: Vendor request req:07 off:0080 failed:-71
[  108.631177] mt7601u 1-2:1.0: Vendor request req:02 off:0080 failed:-71
[  108.764700] mt7601u 1-2:1.0: Vendor request req:02 off:0080 failed:-71
[  108.764765] mt7601u: probe of 1-2:1.0 failed with error -110
[  108.765071] usb 1-2: USB disconnect, device number 35
[  109.021365] usb 1-2: new high-speed USB device number 36 using xhci_hcd
Any ideas about how to make the device working without issues?
Waiting for a reply,
Thanks.
Is the system fully updated? The driver should be included in the kernel.
Is linux-firmware installed?
Have you tried a different kernel?
Can you post a full inxi output?
output of sudo dmesg -w
lsusb output
What have you tried so far?
Does it work on the live .iso?
Check in BIOS settings?
The repeating error messages seems to indicate a broken hardware, could be either the dongle or the port (not capable of providing enough power, for instance). MT7601 is a common chipset used in wireless dongles and the kernel has its driver built-in, so it’s unlikely a software issue. But you can try it first in several other computers to find out, with the following scenario:
  1. Test in another computer with Manjaro
  2. If it works, probably a faulty USB port
  3. Otherwise, test in another computer with Windows, as usually it’s guaranteed to work there
  4. If it doesn’t work, certainly a faulty dongle
  5. If it works, now we can conclude it’s a software issue that needs further digging, although from my findings so far, all other threads end with the reporter either use another dongle / card or buying a new dongle, admitting the reported one is indeed faulty
As I said before, I get these error messages with all the last kernel versions; system updated, linux-firmware installed; you can find a full inxi output in this post: forum manjaro → a-few-serious-issues-after-manjaro-installation/121161?u=cristian_c topic post url
As noting at the linked post, dmesg output is spammed by memory corruption messages; Here is (a complete) lsusb output:
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 003 Device 004: ID 0bda:5830 Realtek Semiconductor Corp. USB2.0 camera
Bus 003 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 026: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
Result doesn’t change if OS is running live or it’s installed. What do you mean when you talk about BIOS settings, exactly? What should I check?
I don’t understand: this wifi adapter works with Windows 10 on this same machine but it doesn’t work on other machines with manjaro. Does it mean it’s a faulty/broken adapter? It seems not, looking at these results. If it’s a software issue, how can I make this mwifi adapter working? Waiting for a reply, thanks.
Hi @cristian_c,
If I have things correct, then it is this device:
And as can be seen on said page, it has many more Failed reports than than Working or even just Detected. But luckily it seems there are alternative drivers that can be tried. Unfortunately, we don’t really know which driver it’s currently trying to use that’s faulty, which we need to know about so that we can block it.
So let’s try find that out. Please provide the output of:
@Mirdarthos , the command freezes for a few seconds. Btw:
  Kernel: 6.1.21-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=8259574f-d640-4590-9813-d645eb29dc3f rw quiet apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Microtech product: CoreBook v: V1.0
    serial: <superuser required>
  Mobo: Microtech model: CB15SH35 v: V1.0 serial: <superuser required>
    UEFI: American Megatrends v: XPSH_LM15601.15.1.corebook date: 03/12/2021
  ID-1: BMBT charge: 38.0 Wh (100.0%) condition: 38.0/38.0 Wh (100.0%)
    volts: 8.6 min: 7.6 model: Intel SR 1 SR Real Battery type: Li-ion
    serial: <filter> status: charging cycles: 1
  RAM: total: 7.46 GiB used: 2.37 GiB (31.8%)
  Info: model: AMD Ryzen 5 3450U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
    built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
    stepping: 1 microcode: 0x8108102
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1707 high: 2630 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2630 2: 2620
    3: 1176 4: 1175 5: 1951 6: 1757 7: 1175 8: 1176 bogomips: 33551
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
    temp: 44.0 C
  Device-2: Realtek USB2.0 camera type: USB driver: uvcvideo bus-ID: 3-1.1:4
    chip-ID: 0bda:5830 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0064 built: 2018
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
    chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
    v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  API: ALSA v: k6.1.21-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.67 status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-2: Ralink MT7601U Wireless Adapter type: USB driver: N/A
    bus-ID: 1-2:127 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:3
  Local Storage: total: 476.95 GiB used: 101.33 GiB (21.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ256HBJD-00BL2
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 5L2QFXM7 temp: 25.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 model: SSD256M2S80 size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
    rev: 9A0 scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
    used: 101.33 GiB (43.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 8259574f-d640-4590-9813-d645eb29dc3f
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: DF21-7D20
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: SYSTEM
    uuid: F080-CD5A
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 237.87 GiB fs: ntfs label: Windows
    uuid: 6238842C38840171
  ID-4: /dev/sda4 maj-min: 8:4 size: 499 MiB fs: ntfs label: Recovery
    uuid: EE40EF7340EF4147
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-2:127 info: Ralink MT7601U Wireless Adapter type: WiFi
    driver: N/A rev: N/A chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 3-1.1:4 info: Realtek USB2.0 camera type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:5830
  Device-2: 3-2:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-5: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 53.1 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Processes: 273 Uptime: 30m wakeups: 1 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1283
  pm: pacman pkgs: 1271 libs: 356 tools: pamac pm: flatpak pkgs: 5 pm: snap
  pkgs: 7 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.26
lsusb
Bus 001 Device 018: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
lsusb -t
/sys/bus/usb/devices/1-2/configuration: No such file or directory
/sys/bus/usb/devices/1-2/devnum: No such file or directory
/sys/bus/usb/devices/1-2/idProduct: No such file or directory
/sys/bus/usb/devices/1-2/idVendor: No such file or directory
/sys/bus/usb/devices/1-2/maxchild: No such file or directory
/sys/bus/usb/devices/1-2/rx_lanes: No such file or directory
/sys/bus/usb/devices/1-2/tx_lanes: No such file or directory
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 10000M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 4, If 0, Class=Video, Driver=uvcvideo, 480M
        |__ Port 1: Dev 4, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 2: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
    |__ Port 2: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
    |__ Port 2: Dev 0, If 0, Class=Vendor Specific Class, Driver=mt7601u, M
I see this device doesn’t even seem to have a driver, which would explain it.
One mentioned on that page previously is in the AUR:
$ pamac search Mt7601u
mt7601u-dkms-git        latest-1       AUR
mt7601u DKMS driver
So you should be able to install it with:
pamac build mt7601u-dkms-git
Since there doesn’t seem to be another driver, it’s not necessary to unload one.
Hope this helps!
No, @Mirdarthos , if you look at the output in my last post, you can see at the end:
Btw, you’ve talked about alternative drivers that can be tried. Which driver are you talking about? Waiting for a reply, thanks.
There it shows that no driver is loaded.
I do not know how to interpret the output of lsusb -t, if the driver is actually in use, or if that’s one that would work.
Either way, it doesn’t work now, and it doesn’t seem to get loaded.
I gave you all the answers in my previous replies:
Please don’t make demands on anyone that tries to help’s time, here. We’re all volunteers from all over the world giving our own time and sharing knowledge. Hints demanding response, so time like that is not helpful.
You can easily check out if driver is loaded, we have the name it seems (mt7601u)
lsmod | grep mt7601u # it should be listed out
# or also just in case
lsmod | grep -i Ralink # or just lsmod and check all out manually
Then use # modprobe to remove / load the module (and see how it goes)
sudo modprobe -r mt7601u
sudo modprobe mt7601u
@Mirdarthos , I don’t understand. If your answer is mt7601u, this is the driver actually selected/used by the kernel, as clearly shown by the output in the first post:
and lsusb -t shows the driver loaded by the kernel. Which other driver what you was talking about?
@dragan ,
mt7601u               155648  0
mac80211             1323008  1 mt7601u
cfg80211             1138688  2 mt7601u,mac80211
The command:
returns nothing.
Done. What should I do next? Waiting for a reply, thanks.
Did anything change once you reloaded the module (via modprobe), has wifi status changed in any way (working or otherwise), run inxi and all again to see.
Also (if things don’t work) run
journalctl -r # (or maybe `journalctl --dmesg -r`)
…and see if any messages there during the moudule loading (e.g. you can open that in one terminal, in another try to reload module again, see if it’s failing with some particular error).
lsmod output means driver module was there. But reloading might have helped.
This is for diagnostics mostly, if reloading module doesn’t help then try the other driver as @Mirdarthos suggested.
Windows can sometimes leave some of the devices (WiFi-s typically) in some funny state, sorry I can’t remember much more, happened to me once many yrs ago. Meaning try shuttind down the Win fully then going into Manjaro. Long shot, or read about it for more.
I can’t add much more to this I’m afraid.
@dragan , I didn’t notice better results reloading the module. The wifi adapter keeps going appearing and disappearing continuously, as shown by sudo dmesg -w command output.
Running journalctl --dmesg -r command gives the same results as explained above. Btw, the command output:
apr 08 08:05:52 cristian-corebook kernel: usb 1-2: reset high-speed USB device >
apr 08 08:05:52 cristian-corebook kernel: usb 1-2: SerialNumber: 1.0
apr 08 08:05:52 cristian-corebook kernel: usb 1-2: Manufacturer: MediaTek
apr 08 08:05:52 cristian-corebook kernel: usb 1-2: Product: 802.11 n WLAN
apr 08 08:05:52 cristian-corebook kernel: usb 1-2: New USB device strings: Mfr=>
apr 08 08:05:52 cristian-corebook kernel: usb 1-2: New USB device found, idVend>
apr 08 08:05:52 cristian-corebook kernel: usb 1-2: new high-speed USB device nu>
apr 08 08:05:51 cristian-corebook kernel: usb 1-2: USB disconnect, device numbe>
apr 08 08:05:51 cristian-corebook kernel: mt7601u: probe of 1-2:1.0 failed with>
apr 08 08:05:51 cristian-corebook kernel: mt7601u 1-2:1.0: Vendor request req:0>
apr 08 08:05:51 cristian-corebook kernel: mt7601u 1-2:1.0: Error: mt7601u_mcu_w>
apr 08 08:05:51 cristian-corebook kernel: mt7601u 1-2:1.0: Error: MCU resp evt:>
apr 08 08:05:51 cristian-corebook kernel: mt7601u 1-2:1.0: Error: MCU resp urb >
lines 1-23
I’ve asked which other driver he talked about (apart mt7601u, that I’m using) but he never answered.
Actually, I always boot manjaro, anyway I shut windows 10 down, so it doesn’t solve the issue.
Any other ideas? Waiting for a reply, thanks.
I did explain.
I don’t understand what you mean. The thread doesn’t show replies after that:
Edit: @Mirdarthos , do you display a following up reply which I’m not able to view in the thread?
This:
@Mirdarthos , I don’t understand what you mean. Your url shows the same messages I’m able to view in the thread. Why did you post that?
Because you said:
So I linked a screenshot showing my replies, including the ones with my suggestions that I understood you didn’t get, and highlighted my replies.
But in any case. This, I realize is the case:
…but it might have been updated or something in that line, in the driver I specified. In any case, according to this:
https://linux-hardware.org/?id=usb:148f-7601
It seems it is quite the problematic device…
you replied posting that url but I can display the same thread messages after Mt7601u usb wifi failure/issues - #16 by cristian_c included in your url. So there seem not to be messages I’m not able to view in the thread. It doesn’t make sense.
Looking at Ralink Technology MT7601U Wireless Adapter , the other driver mentioned there (apart mt7601u which I’m already using) is named as W311MI but that url points to an error page url.
