Msi Pro x670-p Network device (Realtek RTL8125), didn't install the driver for itself on the 2nd go?
To put it simple:
I installed the Manjaro-Plamsa and the first time actually installed the network device (the wifi). Everything was great until something happened to the boot so I just reinstalled from scratch.
Now on ‘take 2’ of reinstalling everything the driver didn’t ‘take’ and blutooth is the only working part of it. Like wtf? I wish I just fixted the boot the first time I did this.
below is command cut for only network:
inxi -Fza
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0
  IF: enp8s0 state: down mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: N/A modules: mt7921e pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF-ID-1: enp26s0f4u1 state: unknown speed: -1 duplex: half mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:6 chip-ID: 0e8d:0616
I used to be better at at least installing drivers at min but I guess its been a bit. Back to noob :frowning:
please post the full output of
Different ISO? Different kernel?
How elucidating. Please be respectful of everyone and their time.
I’m not sure what this is supposed to mean?
You believe that a clean install should have instead silently bailed out and done some automagic fix of your previous boot problem on its own?
Here’s that full output you asked for
  Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=8c21893f-cbdc-4261-adc1-44c715c503df rw quiet splash
    resume=UUID=23b03b34-4c43-41f9-b601-ec813909737b udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
  Type: Desktop System: Micro-Star product: MS-7D67 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: PRO X670-P WIFI (MS-7D67) v: 1.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: 1.90
    date: 06/08/2023
  ID-1: hidpp_battery_0 charge: 99% condition: N/A volts: 4.2 min: N/A
    model: Logitech Gaming Mouse G900 type: N/A serial: <filter> status: full
  System RAM: total: 32 GiB note: est. available: 30.51 GiB
    used: 4.08 GiB (13.4%)
  Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3800 high: 5347 min/max: 3000/5572 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 5347 2: 2673
    3: 3561 4: 2673 5: 5340 6: 3000 7: 2669 8: 3000 9: 5342 10: 2671 11: 5306
    12: 2674 13: 5333 14: 2636 15: 3242 16: 5346 bogomips: 144050
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
    avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
    gfni ht hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku
    pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good
    sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: ASRock
    driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
    built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 03:00.0 chip-ID: 1002:744c
    class-ID: 0300
  Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
    arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5, DP-6,
    HDMI-A-2 bus-ID: 1a:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 55.0 C
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu,amdgpu d-rect: 4720x2160 display-ID: 0
  Monitor-1: DP-1 pos: top-right res: 2560x1440 size: N/A modes: N/A
  Monitor-2: DP-2 pos: primary,top-left res: 3440x1440 size: N/A modes: N/A
  Monitor-3: HDMI-A-1 pos: bottom-r res: 1280x720 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 7900 XTX (gfx1100
    LLVM 15.0.7 DRM 3.49 6.1.41-1-MANJARO) direct-render: Yes
  Device-1: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Micro-Star MSI
    bus-ID: 1a:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
    bus-ID: 1a:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:5
    chip-ID: 0db0:3130 class-ID: 0300
  API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.75 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Local Storage: total: 3.71 TiB used: 18.58 GiB (0.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apacer model: APSFG-2T-CSUS
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3.2.F.83 temp: 50.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EARS-00MVWB0
    size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: N/A serial: <filter> fw-rev: AB51 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 model: USB Flash size: 30 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
    mode: 2.0 tech: SSD serial: <filter> fw-rev: 1100 scheme: GPT
  ID-1: / raw-size: 1.83 TiB size: 1.8 TiB (98.37%) used: 18.58 GiB (1.0%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 8c21893f-cbdc-4261-adc1-44c715c503df
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: A019-1DF8
  ID-1: swap-1 type: partition size: 33.56 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 23b03b34-4c43-41f9-b601-ec813909737b
  ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: 2T Drive
    uuid: 1C4E9B0A4E9ADC38
  ID-2: /dev/sdb1 maj-min: 8:17 size: 30 GiB fs: vfat label: N/A
    uuid: 5C3C-CF62
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-5:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
  Device-1: 1-5.4:4 info: Logitech Gaming Mouse G900 type: mouse,HID
    driver: logitech-hidpp-device,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 498mA
    chip-ID: 046d:c081 class-ID: 0300 serial: <filter>
  Device-2: 1-6:3 info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 090c:1000 class-ID: 0806
  Device-3: 1-7:5 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d67 class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-4: 2-5:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: XP-Pen 15.6 inch PenDisplay type: mouse,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 70mA chip-ID: 28bd:090d class-ID: 0300
  Device-2: 3-4:3 info: Logitech Lightspeed Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c539 class-ID: 0300
  Device-3: 3-5:4 info: Corsair Gaming K70 LUX RGB Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 1b1c:1b33 class-ID: 0300 serial: <filter>
  Device-4: 3-6:5 info: Micro Star USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-5: 3-7:6 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 7-1:3 info: Samsung GT-I9070 (network tethering USB debugging
    enabled) type: CDC-data driver: rndis_host interfaces: 3 rev: 2.1
    chip-ID: 04e8:6864 class-ID: 0a00 serial: <filter>
  Hub-10: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-11: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-12: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 67.6 C mobo: N/A
  GPU: device: amdgpu temp: 54.0 C device: amdgpu temp: 57.0 C mem: 71.0 C
    fan: 942 watts: 80.00
  Processes: 379 Uptime: 8m wakeups: 3 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1322 libs: 430 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
Same OS but twice over. Manjaro-plasma distro. Idk what it did different but it was different.
Also thank you guys for the responces. So speedy :dash:
Please show
mhwd -l -li
Here’s that output:
           video-linux            2018.05.04                true            PCI
> 0000:03:00.0 (0300:1002:744c) Display controller ATI Technologies Inc:
> 0000:1a:00.0 (0300:1002:164e) Display controller ATI Technologies Inc:
Questions:
a) is a ms-windows installed (dual boot) or was ms-windows installed previous ?
b) is there a “hotkey” of the laptop. some laptops use a “magic key” like keep on/off switch pressed for a specific time (e.g. 30 seconds) to reset the hardware ? check the manufacturer-manual/internet for this.
c) is there a bios setting “ASPM” ? if so please disable this option for testing.
I wish it was a laptop. I’ve read around and it seems like they have an easy solution.
I’ll do that now:
Sadly no ASPM found
what about the windows questions ?
Oh yeah sorry about that. No, windows wasn’t installed beforehand
any output of
sudo dmesg | grep mt792
Output:
[    5.925144] mt7921e 0000:0f:00.0: enabling device (0000 -> 0002)
[    7.117823] mt7921e 0000:0f:00.0: driver own failed
[    7.117876] mt7921e: probe of 0000:0f:00.0 failed with error -5
may you try
sudo modprobe mt7921e
As much as I wish this worked. I did do it again for sanity checking. Nothing
Omg, I f-ing hate hardware sometimes
I decided to look around a bit in the meantime and all these laptops keep recommending shutting off/turn off switch for a good period of time.
So the solution is to unplug everything… :electric_plug: :raised_hand_with_fingers_splayed:
