Solution:
If EC reset doesn’t help in your case, reset all your BIOS settings. This is what helped me, but it was my fault too. I had been poking at the BIOS engineering menu, enabling all sorts of ASPM and other toggles that looked like power management (in the hopes of reducing power usage).
Verbose info dump below.
Working state - inxi -A -xxx output:
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Audio Coprocessor
vendor: Micro-Star MSI driver: snd_rn_pci_acp3x v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 08:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s
lanes: 16 bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.18.0-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 1.4.8 status: off with: pipewire-media-session
status: active
Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin
dmesg:
[ 13.797961] snd_rn_pci_acp3x 0000:08:00.5: enabling device (0000 -> 0002)
acp3x is “AMD ACP3x PCI driver”
KDE Sound Settings: must show “Play HiFi quality Music (Mic1, Mic2, Speaker)” or “Play HiFi quality Music (Headphones, Mic1, Mic2)” in selection for Mic/Speaker.
Windows 10: the microphone is back under Inputs: “Microphone Array / AMD Audio Device” aka `ACP\VEN_1022&DEV_15E2&SUBSYS_14621313&REV_01`
If you encounter a Boot loop, you’ll need to keep booting until Windows says enough and loads you into the blue troubleshooting menu. From there, boot into safe mode once. It should be enough to fix the next regular boot (otherwise you may wanna try to remove audio-related drivers from Device Manager)
After booting into safe mode for the first time, I found these event viewer warnings/errors:
IntcAzAudAddService: HAP AcpCreateAudioEngine fail with status (0xC00000BB)
Note: other audio devices like Steam’s virtual interfaces didn’t load too.
Kernel-PnP: The driver \Driver\AMDAfdAudioService failed to load for the device ACP\VEN_1022&DEV_15E2&SUBSYS_14621313\5&e2f4844&3&04.
PS: @nikgnomic thanks, I’ve separated the post.
