Videos are laggy when they played via MPV.
But Videos are smooth when they played via Haruna.
what should I set in mpv?
Hi @sunriseast,
To be able to possibly provide a solution, or at least something to search for, wee need more information. IIRC, MPV is started via CLI. Something like:
mpv /path/to/video.file
Where, surprise surprise, /path/to/video.file is the path to the video file.
Please provide the output in the terminal when you do that.
Thanks for the reply.
I got as follow.```
(+) Video --vid=1 () (h264 1920x1080 23.976fps)
(+) Audio --aid=1 () (ac3 2ch 48000Hz)
AO: [pulse] 48000Hz stereo 2ch float
VO: [gpu] 1920x1080 yuv420p
AV: 00:00:16 / 01:46:00 (0%) A-V: 0.403 Dropped: 134
Audio/Video desynchronisation detected! Possible reasons include too slow
hardware, temporary CPU spikes, broken drivers, and broken files. Audio
position will not match to the video (see A-V status field).
Please provide the output of:
Did you try enabling Hardware video acceleration?
https://wiki.archlinux.org/title/mpv#Hardware_video_acceleration
I tried,but video is still laggy.
~/.config/mpv/mpv.conf
hwdec=auto
inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 5.9.16-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=bbdf1655-8bdb-4bb3-b264-da83e94847f8 rw quiet
udev.log_priority=3
Desktop: LXQt v: 1.2.0 tk: Qt v: 5.15.7 info: lxqt-panel wm: Openbox
v: 3.6.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 74585FV v: ThinkPad X200
Mobo: LENOVO model: 74585FV serial: <superuser required> BIOS: LENOVO
v: 6DET72WW (3.22 ) date: 10/25/2012
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/235/317
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 7.67 GiB used: 1.05 GiB (13.7%)
Info: model: Intel Core2 Duo P8600 bits: 64 type: MCP arch: Penryn level: v1
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
stepping: 0xA (10) microcode: 0xA0C
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2294 high: 2363 min/max: 800/2401 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2363 2: 2225
bogomips: 9578
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
ida lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs
pge pni pse pse36 pti sep smx sse sse2 sse4_1 ssse3 syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB
filling
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-5 process: Intel 45nm built: 2008 ports:
active: VGA-1 off: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.6 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-size: <missing: xdpyinfo>
Monitor-1: LVDS-1 note: disabled model: Lenovo 0x4010 built: 2007 res: N/A
dpi: 125 gamma: 1.2 size: 261x163mm (10.28x6.42") diag: 308mm (12.1")
ratio: 16:10 modes: 1280x800
Monitor-2: VGA-1 pos: primary model: Philips 170V serial: <filter>
built: 2008 res: 1280x1024 hz: 60 dpi: 96 gamma: 1.2
size: 338x270mm (13.31x10.63") diag: 433mm (17") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
API: OpenGL v: 2.1 Mesa 22.3.1 renderer: Mesa Mobile Intel GM45 Express
(CTG) direct render: Yes
Device-1: Intel 82801I HD Audio vendor: Lenovo ThinkPad T400
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
class-ID: 0403
Sound API: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: no
Device-1: Intel 82567LM Gigabit Network vendor: Lenovo ThinkPad T400
driver: e1000e v: kernel port: 1840 bus-ID: 00:19.0 chip-ID: 8086:10f5
class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel PRO/Wireless 5100 AGN [Shiloh] Network driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:4237 class-ID: 0280
IP v4: <filter> type: dynamic scope: global
IP v6: <filter> scope: link
Device-1: Broadcom BCM2045B (BDC-2.1) [Bluetooth Controller] type: USB
driver: btusb v: 0.8 bus-ID: 4-2:3 chip-ID: 0a5c:2145 class-ID: fe01
Local Storage: total: 111.79 GiB used: 31.93 GiB (28.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: BBF0 scheme: MBR
ID-1: / raw-size: 50.59 GiB size: 49.74 GiB (98.31%) used: 31.93 GiB (64.2%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: bbdf1655-8bdb-4bb3-b264-da83e94847f8
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs
label: \xe7\xb3\xbb\xe7\xb5\xb1\xe4\xbf\x9d\xe7\x95\x99
uuid: 906E0DD96E0DB8CC
ID-2: /dev/sda2 maj-min: 8:2 size: 29.01 GiB fs: ntfs label: N/A
uuid: E46E0EB56E0E8112
ID-3: /dev/sda3 maj-min: 8:3 size: 32.13 GiB fs: ntfs
label: \xe6\x96\xb0\xe5\xa2\x9e\xe7\xa3\x81\xe7\xa2\x9f\xe5\x8d\x80
uuid: 2E98EE5898EE1DD9
ID-4: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Hub-3: 3-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-4: 4-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 4-1:2 info: AuthenTec AES2810 type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 08ff:2810
class-ID: ff00
Device-2: 4-2:3 info: Broadcom BCM2045B (BDC-2.1) [Bluetooth Controller]
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a5c:2145 class-ID: fe01
Hub-5: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 6-2:2 info: Logitech Media Keyboard K200 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 90mA
chip-ID: 046d:c31d class-ID: 0300
Hub-7: 7-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 8-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 39.0 C mobo: 34.0 C
Fan Speeds (RPM): cpu: 3461
Processes: 155 Uptime: 7m wakeups: 3 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1187 libs: 398 tools: pamac Shell: Zsh v: 5.9 running-in: qterminal
inxi: 3.3.24
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Please format your text using Preformatted Text option so that it’s easier to read. It looks like you have an intel card.
mpv --hwdec=vaapi /path/to/file
mpv --hwdev=vaapi-copy /path/to/file
$ mpv --hwdec=vaapi ~/Documents/file
(+) Video --vid=1 (*) (h264 1920x1080 23.976fps)
(+) Audio --aid=1 (*) (ac3 2ch 48000Hz)
[ffmpeg] AVHWFramesContext: Failed to create surface: 14 (the requested RT Format is not supported).
[ffmpeg] AVHWFramesContext: Unable to allocate a surface from internal buffer pool.
[ffmpeg/video] h264: No support for codec h264 profile 100.
AV: 00:02:27 / 01:46:00 (2%) A-V: 0.444 Dropped: 18
$ mpv --hwdec=vaapi-copy ~/Documents/file
[vaapi] libva: /usr/lib/dri/iHD_drv_video.so init failed
[ffmpeg/video] h264: Failed setup for format vaapi: hwaccel initialisation returned error.
AV: 00:04:08 / 01:46:00 (4%) A-V: 0.403 Dropped: 22
What does vainfo from package libva-utils report? In this specific case mpv is reporting that your GPU does not support h264 codecs.
On my old laptop with 4th gen intel CPU/iGPU I had to install libva-intel-driver-g45-h264 from the AUR to get hardware decoding on h264 to work.
Take a look at Hardware video acceleration - ArchWiki for the specific packages related to your card.
Kernel 5.9.16-1 was marked End Of Life in April 2021 and is no longer supported
I suggest you install LTS kernel v5.10
sudo mhwd-kernel -i linux510
