Mpv播放mp4文件闪退,视频编码格式为hevc
如题,同样的文件使用vlc选择vaapi解码器可以播放,但是使用mpv播放时打开大概2秒钟就闪退。
~/.config/mpv/mpv.conf设置如下:
hwdec=auto-copy
hwdec-codecs=all
打开mp4文件使用-v输出如下:
[   0.003][v][cplayer] mpv 0.35.0-20-ge1a04cd8ac Copyright © 2000-2022 mpv/MPlayer/mplayer2 projects
[   0.004][v][cplayer]  built on Mon Nov 21 09:57:54 2022
[   0.004][v][cplayer] libplacebo version: v5.229.1-33-g7ead30d
[   0.004][v][cplayer] FFmpeg version: n5.1.2
[   0.004][v][cplayer] FFmpeg library versions:
[   0.004][v][cplayer]    libavutil       57.28.100
[   0.004][v][cplayer]    libavcodec      59.37.100
[   0.004][v][cplayer]    libavformat     59.27.100
[   0.004][v][cplayer]    libswscale      6.7.100
[   0.004][v][cplayer]    libavfilter     8.44.100
[   0.004][v][cplayer]    libswresample   4.7.100
[   0.004][v][cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=debugoptimized -Doptimization=2
[   0.004][v][cplayer] List of enabled features: alsa av-channel-layout build-date caca cdda cplayer cplugins cuda-hwaccel cuda-interop debug dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs luajit manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video shaderc sixel sndio stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vapoursynth vdpau vector vt.h vulkan wayland wayland_protocols_1_24 wayland_protocols_1_27 x11 xv zimg zlib
[   0.004][v][cplayer] Command line options: '-v' '--log-file=~/log' 'Forrest.Gump.1994.REMASTERED.1080p.BluRay.x265-RARBG.mp4'
[   0.004][v][cplayer] mpv 0.35.0-20-ge1a04cd8ac Copyright © 2000-2022 mpv/MPlayer/mplayer2 projects
[   0.004][d][global] config path: '' -> '/home/lw208/.config/mpv'
[   0.004][d][global] user path: '~~home/' -> '/home/lw208/.config/mpv'
[   0.004][d][global] user path: '~~old_home/' -> '/home/lw208/.mpv'
[   0.004][d][global] config path: 'encoding-profiles.conf' -/-> '/home/lw208/.config/mpv/encoding-profiles.conf'
[   0.004][d][global] config path: 'encoding-profiles.conf' -/-> '/home/lw208/.mpv/encoding-profiles.conf'
[   0.004][d][global] config path: 'encoding-profiles.conf' -> '/etc/mpv/encoding-profiles.conf'
[   0.004][v][cplayer] Reading config file /etc/mpv/encoding-profiles.conf
[   0.004][v][cplayer] Applying profile 'default'...
[   0.004][d][global] config path: 'mpv.conf' -> '/home/lw208/.config/mpv/mpv.conf'
[   0.004][d][global] config path: 'config' -/-> '/home/lw208/.config/mpv/config'
[   0.004][d][global] config path: 'mpv.conf' -/-> '/home/lw208/.mpv/mpv.conf'
[   0.004][d][global] config path: 'config' -/-> '/home/lw208/.mpv/config'
[   0.004][d][global] config path: 'mpv.conf' -/-> '/etc/mpv/mpv.conf'
[   0.004][d][global] config path: 'config' -/-> '/etc/mpv/config'
[   0.004][v][cplayer] Reading config file /home/lw208/.config/mpv/mpv.conf
[   0.004][v][cplayer] Setting option 'hwdec' = 'auto-copy' (flags = 4)
[   0.004][v][cplayer] Setting option 'hwdec-codecs' = 'all' (flags = 4)
[   0.004][v][cplayer] Setting option 'v' = '' (flags = 8)
[   0.004][v][cplayer] Setting option 'log-file' = '~/log' (flags = 8)
[   0.006][d][global] config path: 'input.conf' -/-> '/home/lw208/.config/mpv/input.conf'
[   0.006][d][global] config path: 'input.conf' -/-> '/home/lw208/.mpv/input.conf'
[   0.006][d][global] config path: 'input.conf' -/-> '/etc/mpv/input.conf'
[   0.006][d][global] user path: '~/log' -> '/home/lw208/log'
[   0.009][d][osc] Loading lua script @osc.lua...
[   0.009][d][osc] loading mp.defaults
[   0.010][d][osc] loading @osc.lua
[   0.011][d][osc] reading options for osc
[   0.011][d][global] config path: 'script-opts/osc.conf' -/-> '/home/lw208/.config/mpv/script-opts/osc.conf'
[   0.011][d][global] config path: 'script-opts/osc.conf' -/-> '/home/lw208/.mpv/script-opts/osc.conf'
[   0.011][d][global] config path: 'script-opts/osc.conf' -/-> '/etc/mpv/script-opts/osc.conf'
[   0.011][d][osc] script-opts/osc.conf not found.
[   0.011][d][global] config path: 'lua-settings/osc.conf' -/-> '/home/lw208/.config/mpv/lua-settings/osc.conf'
[   0.012][d][global] config path: 'lua-settings/osc.conf' -/-> '/home/lw208/.mpv/lua-settings/osc.conf'
[   0.012][d][global] config path: 'lua-settings/osc.conf' -/-> '/etc/mpv/lua-settings/osc.conf'
[   0.012][d][osc] lua-settings/osc.conf not found.
[   0.013][d][ytdl_hook] Loading lua script @ytdl_hook.lua...
[   0.013][d][ytdl_hook] loading mp.defaults
[   0.014][d][ytdl_hook] loading @ytdl_hook.lua
[   0.014][d][ytdl_hook] reading options for ytdl_hook
[   0.014][d][global] config path: 'script-opts/ytdl_hook.conf' -/-> '/home/lw208/.config/mpv/script-opts/ytdl_hook.conf'
[   0.015][d][global] config path: 'script-opts/ytdl_hook.conf' -/-> '/home/lw208/.mpv/script-opts/ytdl_hook.conf'
[   0.015][d][global] config path: 'script-opts/ytdl_hook.conf' -/-> '/etc/mpv/script-opts/ytdl_hook.conf'
[   0.015][d][ytdl_hook] script-opts/ytdl_hook.conf not found.
[   0.015][d][global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/home/lw208/.config/mpv/lua-settings/ytdl_hook.conf'
[   0.015][d][global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/home/lw208/.mpv/lua-settings/ytdl_hook.conf'
[   0.015][d][global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/etc/mpv/lua-settings/ytdl_hook.conf'
[   0.015][d][ytdl_hook] lua-settings/ytdl_hook.conf not found.
[   0.016][d][stats] Loading lua script @stats.lua...
[   0.016][d][stats] loading mp.defaults
[   0.016][d][stats] loading @stats.lua
[   0.017][d][stats] reading options for stats
[   0.017][d][global] config path: 'script-opts/stats.conf' -/-> '/home/lw208/.config/mpv/script-opts/stats.conf'
[   0.017][d][global] config path: 'script-opts/stats.conf' -/-> '/home/lw208/.mpv/script-opts/stats.conf'
[   0.018][d][global] config path: 'script-opts/stats.conf' -/-> '/etc/mpv/script-opts/stats.conf'
[   0.018][d][stats] script-opts/stats.conf not found.
[   0.018][d][global] config path: 'lua-settings/stats.conf' -/-> '/home/lw208/.config/mpv/lua-settings/stats.conf'
[   0.018][d][global] config path: 'lua-settings/stats.conf' -/-> '/home/lw208/.mpv/lua-settings/stats.conf'
[   0.018][d][global] config path: 'lua-settings/stats.conf' -/-> '/etc/mpv/lua-settings/stats.conf'
[   0.018][d][stats] lua-settings/stats.conf not found.
[   0.018][d][console] Loading lua script @console.lua...
[   0.018][d][console] loading mp.defaults
[   0.019][d][console] loading @console.lua
[   0.020][d][auto_profiles] Loading lua script @auto_profiles.lua...
[   0.021][d][auto_profiles] loading mp.defaults
[   0.021][d][global] config path: 'scripts' -/-> '/home/lw208/.config/mpv/scripts'
[   0.021][d][global] config path: 'scripts' -/-> '/home/lw208/.mpv/scripts'
[   0.021][d][global] config path: 'scripts' -/-> '/etc/mpv/scripts'
[   0.021][v][cplayer] Waiting for scripts...
[   0.021][d][cplayer] Run command: define-section, flags=64, args=[name="showhide", contents="mouse_move script-binding osc/__keybinding1\nmouse_leave script-binding osc/__keybinding2\n", flags="force"]
[   0.022][d][cplayer] Run command: define-section, flags=64, args=[name="showhide_wc", contents="mouse_move script-binding osc/__keybinding3\nmouse_leave script-binding osc/__keybinding4\n", flags="force"]
[   0.022][d][cplayer] Run command: enable-section, flags=64, args=[name="showhide", flags="allow-hide-cursor+allow-vo-dragging"]
[   0.022][d][cplayer] Run command: enable-section, flags=64, args=[name="showhide_wc", flags="allow-hide-cursor+allow-vo-dragging"]
[   0.022][d][cplayer] Run command: define-section, flags=64, args=[name="input", contents="mbtn_left script-binding osc/__keybinding5\nshift+mbtn_left script-binding osc/__keybinding6\nmbtn_right script-binding osc/__keybinding7\nmbtn_mid script-binding osc/__keybinding8\nwheel_up script-binding osc/__keybinding9\nwheel_down script-binding osc/__keybinding10\nmbtn_left_dbl ignore\nshift+mbtn_left_dbl ignore\nmbtn_right_dbl ignore\n", flags="force"]
[   0.022][d][cplayer] Run command: enable-section, flags=64, args=[name="input", flags=""]
[   0.022][d][cplayer] Run command: define-section, flags=64, args=[name="window-controls", contents="mbtn_left script-binding osc/__keybinding11\n", flags="force"]
[   0.022][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   0.022][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-visibility=auto"]
[   0.022][v][cplayer] Set property: shared-script-properties -> 1
[   0.022][d][cplayer] Run command: disable-section, flags=64, args=[name="input"]
[   0.022][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   0.022][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"]
[   0.022][d][cplayer] Run command: define-section, flags=64, args=[name="input_stats", contents="", flags="default"]
[   0.022][d][cplayer] Run command: enable-section, flags=64, args=[name="input_stats", flags="allow-hide-cursor+allow-vo-dragging"]
[   0.022][d][cplayer] Run command: define-section, flags=64, args=[name="input_forced_stats", contents="", flags="force"]
[   0.022][d][cplayer] Run command: enable-section, flags=64, args=[name="input_forced_stats", flags="allow-hide-cursor+allow-vo-dragging"]
[   0.022][d][console] reading options for console
[   0.022][d][global] config path: 'script-opts/console.conf' -/-> '/home/lw208/.config/mpv/script-opts/console.conf'
[   0.022][d][global] config path: 'script-opts/console.conf' -/-> '/home/lw208/.mpv/script-opts/console.conf'
[   0.022][d][global] config path: 'script-opts/console.conf' -/-> '/etc/mpv/script-opts/console.conf'
[   0.022][d][console] script-opts/console.conf not found.
[   0.022][d][auto_profiles] loading @auto_profiles.lua
[   0.022][d][global] config path: 'lua-settings/console.conf' -/-> '/home/lw208/.config/mpv/lua-settings/console.conf'
[   0.022][d][global] config path: 'lua-settings/console.conf' -/-> '/home/lw208/.mpv/lua-settings/console.conf'
[   0.022][d][global] config path: 'lua-settings/console.conf' -/-> '/etc/mpv/lua-settings/console.conf'
[   0.022][d][console] lua-settings/console.conf not found.
[   0.022][d][osc] osc_init
[   0.022][d][cplayer] Run command: define-section, flags=64, args=[name="input_console", contents="", flags="default"]
[   0.022][d][cplayer] Run command: enable-section, flags=64, args=[name="input_console", flags="allow-hide-cursor+allow-vo-dragging"]
[   0.022][d][cplayer] Run command: define-section, flags=64, args=[name="input_forced_console", contents="", flags="force"]
[   0.022][d][cplayer] Run command: enable-section, flags=64, args=[name="input_forced_console", flags="allow-hide-cursor+allow-vo-dragging"]
[   0.023][d][global] config path: 'fonts' -/-> '/home/lw208/.config/mpv/fonts'
[   0.023][d][global] config path: 'fonts' -/-> '/home/lw208/.mpv/fonts'
[   0.023][d][global] config path: 'fonts' -/-> '/etc/mpv/fonts'
[   0.023][d][osd/libass] ASS library version: 0x1600000 (runtime 0x1600000)
[   0.023][v][osd/libass] libass API version: 0x1600000
[   0.023][v][osd/libass] libass source: commit: 0.16.0-0-g1af6240c5d1e499326146e0b88c987e626b13c23-dirty
[   0.023][v][osd/libass] Shaper: FriBidi 1.0.12 (SIMPLE) HarfBuzz-ng 5.3.1 (COMPLEX)
[   0.023][d][global] config path: 'subfont.ttf' -/-> '/home/lw208/.config/mpv/subfont.ttf'
[   0.023][d][global] config path: 'subfont.ttf' -/-> '/home/lw208/.mpv/subfont.ttf'
[   0.023][d][global] config path: 'subfont.ttf' -/-> '/etc/mpv/subfont.ttf'
[   0.023][d][global] config path: 'fonts.conf' -/-> '/home/lw208/.config/mpv/fonts.conf'
[   0.023][d][global] config path: 'fonts.conf' -/-> '/home/lw208/.mpv/fonts.conf'
[   0.023][d][global] config path: 'fonts.conf' -/-> '/etc/mpv/fonts.conf'
[   0.023][v][osd/libass] Setting up fonts...
[   0.031][v][osd/libass] Using font provider fontconfig
[   0.031][v][osd/libass] Done.
[   0.032][d][auto_profiles] Exiting...
[   0.032][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"]
[   0.032][v][cplayer] Set property: shared-script-properties -> 1
[   0.032][d][global] config path: 'fonts' -/-> '/home/lw208/.config/mpv/fonts'
[   0.032][d][global] config path: 'fonts' -/-> '/home/lw208/.mpv/fonts'
[   0.032][d][global] config path: 'fonts' -/-> '/etc/mpv/fonts'
[   0.032][d][osd/libass] ASS library version: 0x1600000 (runtime 0x1600000)
[   0.032][v][osd/libass] libass API version: 0x1600000
[   0.032][v][osd/libass] libass source: commit: 0.16.0-0-g1af6240c5d1e499326146e0b88c987e626b13c23-dirty
[   0.032][v][osd/libass] Shaper: FriBidi 1.0.12 (SIMPLE) HarfBuzz-ng 5.3.1 (COMPLEX)
[   0.032][d][global] config path: 'subfont.ttf' -/-> '/home/lw208/.config/mpv/subfont.ttf'
[   0.032][d][global] config path: 'subfont.ttf' -/-> '/home/lw208/.mpv/subfont.ttf'
[   0.032][d][global] config path: 'subfont.ttf' -/-> '/etc/mpv/subfont.ttf'
[   0.032][d][global] config path: 'fonts.conf' -/-> '/home/lw208/.config/mpv/fonts.conf'
[   0.032][d][global] config path: 'fonts.conf' -/-> '/home/lw208/.mpv/fonts.conf'
[   0.032][d][global] config path: 'fonts.conf' -/-> '/etc/mpv/fonts.conf'
[   0.032][v][osd/libass] Setting up fonts...
[   0.040][v][osd/libass] Using font provider fontconfig
[   0.040][v][osd/libass] Done.
[   0.041][v][cplayer] Done loading scripts.
[   0.041][d][global] config path: 'watch_later' -> '/home/lw208/.config/mpv/watch_later'
[   0.041][v][cplayer] Running hook: ytdl_hook/on_load
[   0.041][v][ytdl_hook] ytdl:// hook
[   0.041][d][osc] osc_init
[   0.041][v][ytdl_hook] not a ytdl:// url
[   0.043][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"]
[   0.043][v][cplayer] Set property: shared-script-properties -> 1
[   0.043][d][cplayer] Run command: define-section, flags=64, args=[name="input_osc", contents="", flags="default"]
[   0.043][d][cplayer] Run command: enable-section, flags=64, args=[name="input_osc", flags="allow-hide-cursor+allow-vo-dragging"]
[   0.043][d][cplayer] Run command: define-section, flags=64, args=[name="input_forced_osc", contents="", flags="force"]
[   0.043][d][cplayer] Run command: enable-section, flags=64, args=[name="input_forced_osc", flags="allow-hide-cursor+allow-vo-dragging"]
[   0.043][d][osc] osc_init
[   0.043][v][bdmv/bluray] Opening Forrest.Gump.1994.REMASTERED.1080p.BluRay.x265-RARBG.mp4
[   0.043][v][file] Opening Forrest.Gump.1994.REMASTERED.1080p.BluRay.x265-RARBG.mp4
[   0.081][d][file] resize stream to 131072 bytes, drop 0 bytes
[   0.081][d][file] Stream opened successfully.
[   0.081][v][demux] Trying demuxers for level=normal.
[   0.081][d][demux] Trying demuxer: disc (force-level: normal)
[   0.081][d][demux] Trying demuxer: edl (force-level: normal)
[   0.108][d][demux] Trying demuxer: cue (force-level: normal)
[   0.108][d][demux] Trying demuxer: rawaudio (force-level: normal)
[   0.108][d][demux] Trying demuxer: rawvideo (force-level: normal)
[   0.108][d][demux] Trying demuxer: mkv (force-level: normal)
[   0.108][d][demux] Trying demuxer: libarchive (force-level: normal)
[   0.109][d][demux] Trying demuxer: lavf (force-level: normal)
[   0.114][v][lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048.
[   0.117][v][file] stream level seek from 131072 to 2370620997
[   0.541][v][demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat)
[   0.541][v][cplayer] Opening done: Forrest.Gump.1994.REMASTERED.1080p.BluRay.x265-RARBG.mp4
[   0.630][v][find_files] Loading external files in .
[   0.647][d][global] config path: 'sub' -/-> '/home/lw208/.config/mpv/sub'
[   0.647][d][global] config path: 'sub' -/-> '/home/lw208/.mpv/sub'
[   0.647][d][global] config path: 'sub' -/-> '/etc/mpv/sub'
[   0.647][v][cplayer] Running hook: ytdl_hook/on_preloaded
[   0.647][d][osc] osc_init
[   0.647][v][lavf] select track 0
[   0.647][v][lavf] select track 1
[   0.648][i][cplayer]  (+) Video --vid=1 (*) (hevc 1920x804 23.976fps)
[   0.648][i][cplayer]  (+) Audio --aid=1 --alang=eng (*) (aac 6ch 48000Hz)
[   0.648][i][display-tags] File tags:
[   0.648][i][display-tags]  Comment: Forrest.Gump.1994.REMASTERED.1080p.BluRay.x265-RARBG
[   0.648][i][display-tags]  Title: Forrest.Gump.1994.REMASTERED.1080p.BluRay.x265-RARBG
[   0.648][v][vo/gpu] Probing for best GPU context.
[   0.648][v][vo/gpu/opengl] Initializing GPU context 'wayland'
[   0.648][v][vo/gpu/wayland] Registered for protocol wl_compositor
[   0.648][v][vo/gpu/wayland] Registered for protocol wl_shm
[   0.648][v][vo/gpu/wayland] Registered for protocol wl_output
[   0.648][v][vo/gpu/wayland] Registered for protocol wl_data_device_manager
[   0.648][v][vo/gpu/wayland] Registered for protocol wl_subcompositor
[   0.648][v][vo/gpu/wayland] Registered for protocol xdg_wm_base
[   0.648][v][vo/gpu/wayland] Registered for protocol wp_viewporter
[   0.648][v][vo/gpu/wayland] Registered for protocol wl_seat
[   0.648][v][vo/gpu/wayland] Registered for protocol zwp_linux_dmabuf_v1
[   0.648][v][vo/gpu/wayland] Registered for protocol wp_single_pixel_buffer_manager_v1
[   0.648][v][vo/gpu/wayland] Registered for protocol wp_presentation
[   0.648][w][vo/gpu/wayland] GNOME's wayland compositor lacks support for the idle inhibit protocol. This means the screen can blank during playback.
[   0.648][v][vo/gpu/wayland] Compositor doesn't support the wp_content_type_manager_v1 protocol!
[   0.648][v][vo/gpu/wayland] Compositor doesn't support the zxdg_decoration_manager_v1 protocol!
[   0.648][v][vo/gpu/wayland] Compositor doesn't support the zwp_idle_inhibit_manager_v1 protocol!
[   0.652][v][vo/gpu/wayland] Registered output DEL DELL S2421HS (0x4):
[   0.652][v][vo/gpu/wayland] 	x: 0px, y: 0px
[   0.652][v][vo/gpu/wayland] 	w: 1920px (530mm), h: 1080px (300mm)
[   0.652][v][vo/gpu/wayland] 	scale: 1
[   0.652][v][vo/gpu/wayland] 	Hz: 60.000000
[   0.699][v][vo/gpu/opengl] EGL_VERSION=1.5
[   0.699][v][vo/gpu/opengl] EGL_VENDOR=Mesa Project
[   0.699][v][vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES
[   0.699][v][vo/gpu/opengl] Trying to create Desktop OpenGL context.
[   0.699][d][vo/gpu/opengl] Chosen EGLConfig:
[   0.699][d][vo/gpu/opengl]   EGL_CONFIG_ID=0x15
[   0.699][d][vo/gpu/opengl]   EGL_RED_SIZE=0xa
[   0.699][d][vo/gpu/opengl]   EGL_GREEN_SIZE=0xa
[   0.699][d][vo/gpu/opengl]   EGL_BLUE_SIZE=0xa
[   0.699][d][vo/gpu/opengl]   EGL_ALPHA_SIZE=0x0
[   0.699][d][vo/gpu/opengl]   EGL_COLOR_BUFFER_TYPE=0x308e
[   0.699][d][vo/gpu/opengl]   EGL_CONFIG_CAVEAT=0x3038
[   0.699][d][vo/gpu/opengl]   EGL_CONFORMANT=0x4d
[   0.699][d][vo/gpu/opengl]   EGL_NATIVE_VISUAL_ID=0x0
[   0.702][v][vo/gpu/wayland] GL_VERSION='4.6 (Core Profile) Mesa 22.2.3'
[   0.702][v][vo/gpu/wayland] Detected desktop OpenGL 4.6.
[   0.702][v][vo/gpu/wayland] GL_VENDOR='Intel'
[   0.702][v][vo/gpu/wayland] GL_RENDERER='Mesa Intel(R) HD Graphics 630 (KBL GT2)'
[   0.702][v][vo/gpu/wayland] GL_SHADING_LANGUAGE_VERSION='4.60'
[   0.702][d][vo/gpu/wayland] Combined OpenGL extensions string:
[   0.702][d][vo/gpu/wayland] EGL_ANDROID_blob_cache EGL_ANDROID_native_fence_sync EGL_EXT_buffer_age EGL_EXT_create_context_robustness EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_EXT_present_opaque EGL_EXT_swap_buffers_with_damage EGL_IMG_context_priority EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_context_flush_control EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image_base EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_WL_bind_wayland_display EGL_WL_create_wayland_buffer_from_image  GL_3DFX_texture_compression_FXT1 GL_AMD_conservative_depth GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_gpu_shader_int64 GL_AMD_multi_draw_indirect GL_AMD_performance_monitor GL_AMD_pinned_memory GL_AMD_query_buffer_object GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trinary_minmax GL_AMD_texture_texture4 GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_viewport_index GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_ES2_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_compressed_texture_pixel_storage GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shader_viewport_layer_array GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map_array GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ATI_blend_equation_separate GL_ATI_texture_float GL_EXT_EGL_image_storage GL_EXT_EGL_sync GL_EXT_abgr GL_EXT_blend_equation_separate GL_EXT_demote_to_helper_invocation GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_memory_object GL_EXT_memory_object_fd GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_semaphore GL_EXT_semaphore_fd GL_EXT_shader_framebuffer_fetch GL_EXT_shader_framebuffer_fetch_non_coherent GL_EXT_shader_integer_mix GL_EXT_shader_samples_identical GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_shadow_lod GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_IBM_multimode_draw_arrays GL_INTEL_blackhole_render GL_INTEL_conservative_rasterization GL_INTEL_performance_query GL_INTEL_shader_atomic_float_minmax GL_INTEL_shader_integer_functions2 GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_parallel_shader_compile GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_MESA_framebuffer_flip_y GL_MESA_pack_invert GL_MESA_shader_integer_functions GL_MESA_texture_signed_rgba GL_NV_compute_shader_derivatives GL_NV_conditional_render GL_NV_copy_image GL_NV_depth_clamp GL_NV_fragment_shader_interlock GL_NV_packed_depth_stencil GL_NV_texture_barrier GL_OES_EGL_image GL_S3_s3tc
[   0.702][v][vo/gpu/wayland] Loaded extension GL_KHR_debug.
[   0.703][d][vo/gpu/opengl] Texture formats:
[   0.703][d][vo/gpu/opengl]   NAME       COMP*TYPE SIZE           DEPTH PER COMP.
[   0.703][d][vo/gpu/opengl]   r8         1*unorm   1B    LF CR ST {8}
[   0.703][d][vo/gpu/opengl]   rg8        2*unorm   2B    LF CR ST {8 8}
[   0.703][d][vo/gpu/opengl]   rgb8       3*unorm   3B    LF CR ST {8 8 8}
[   0.703][d][vo/gpu/opengl]   rgba8      4*unorm   4B    LF CR ST {8 8 8 8}
[   0.703][d][vo/gpu/opengl]   r16        1*unorm   2B    LF CR ST {16}
[   0.703][d][vo/gpu/opengl]   rg16       2*unorm   4B    LF CR ST {16 16}
[   0.703][d][vo/gpu/opengl]   rgb16      3*unorm   6B    LF CR ST {16 16 16}
[   0.703][d][vo/gpu/opengl]   rgba16     4*unorm   8B    LF CR ST {16 16 16 16}
[   0.703][d][vo/gpu/opengl]   r8ui       1*uint    1B       CR ST {8}
[   0.703][d][vo/gpu/opengl]   rg8ui      2*uint    2B       CR ST {8 8}
[   0.703][d][vo/gpu/opengl]   rgb8ui     3*uint    3B          ST {8 8 8}
[   0.703][d][vo/gpu/opengl]   rgba8ui    4*uint    4B       CR ST {8 8 8 8}
[   0.703][d][vo/gpu/opengl]   r16ui      1*uint    2B       CR ST {16}
[   0.703][d][vo/gpu/opengl]   rg16ui     2*uint    4B       CR ST {16 16}
[   0.703][d][vo/gpu/opengl]   rgb16ui    3*uint    6B          ST {16 16 16}
[   0.703][d][vo/gpu/opengl]   rgba16ui   4*uint    8B       CR ST {16 16 16 16}
[   0.703][d][vo/gpu/opengl]   r16f       1*float   4B    LF CR ST {32/16}
[   0.703][d][vo/gpu/opengl]   rg16f      2*float   8B    LF CR ST {32/16 32/16}
[   0.704][d][vo/gpu/opengl]   rgb16f     3*float  12B    LF CR ST {32/16 32/16 32/16}
[   0.704][d][vo/gpu/opengl]   rgba16f    4*float  16B    LF CR ST {32/16 32/16 32/16 32/16}
[   0.704][d][vo/gpu/opengl]   r32f       1*float   4B    LF CR ST {32}
[   0.704][d][vo/gpu/opengl]   rg32f      2*float   8B    LF CR ST {32 32}
[   0.704][d][vo/gpu/opengl]   rgb32f     3*float  12B    LF CR ST {32 32 32}
[   0.704][d][vo/gpu/opengl]   rgba32f    4*float  16B    LF CR ST {32 32 32 32}
[   0.704][d][vo/gpu/opengl]   rgb10_a2   4*unorm   4B    LF CR ST {0/10 0/10 0/10 0/2}
[   0.704][d][vo/gpu/opengl]   rgba12     4*unorm   8B    LF CR ST {16 16 16 16}
[   0.704][d][vo/gpu/opengl]   rgb10      3*unorm   6B    LF CR ST {16/10 16/10 16/10}
[   0.704][d][vo/gpu/opengl]   rgb565     3*unorm   2B    LF    ST {0/8 0/8 0/8}
[   0.704][d][vo/gpu/opengl]  LA = LUMINANCE_ALPHA hack format
[   0.704][d][vo/gpu/opengl]  LF = linear filterable
[   0.704][d][vo/gpu/opengl]  CR = can be used for render targets
[   0.704][d][vo/gpu/opengl]  ST = can be used for storable images
[   0.704][d][vo/gpu/opengl] Image formats:
[   0.704][d][vo/gpu/opengl]   yuv444p => 3 planes 1x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv420p => 3 planes 2x2 8/0 [r8/r8/r8] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   gray => 1 planes 1x1 8/0 [r8] (r) [unorm]
[   0.704][d][vo/gpu/opengl]   gray16 => 1 planes 1x1 16/0 [r16] (r) [unorm]
[   0.704][d][vo/gpu/opengl]   uyvy422
[   0.704][d][vo/gpu/opengl]   nv12 => 2 planes 2x2 8/0 [r8/rg8] (r/gb) [unorm]
[   0.704][d][vo/gpu/opengl]   p010 => 2 planes 2x2 16/6 [r16/rg16] (r/gb) [unorm]
[   0.704][d][vo/gpu/opengl]   argb => 1 planes 1x1 8/0 [rgba8] (argb) [unorm]
[   0.704][d][vo/gpu/opengl]   bgra => 1 planes 1x1 8/0 [rgba8] (bgra) [unorm]
[   0.704][d][vo/gpu/opengl]   abgr => 1 planes 1x1 8/0 [rgba8] (abgr) [unorm]
[   0.704][d][vo/gpu/opengl]   rgba => 1 planes 1x1 8/0 [rgba8] (rgba) [unorm]
[   0.704][d][vo/gpu/opengl]   bgr24 => 1 planes 1x1 8/0 [rgb8] (bgr) [unorm]
[   0.704][d][vo/gpu/opengl]   rgb24 => 1 planes 1x1 8/0 [rgb8] (rgb) [unorm]
[   0.704][d][vo/gpu/opengl]   0rgb => 1 planes 1x1 8/0 [rgba8] (_rgb) [unorm]
[   0.704][d][vo/gpu/opengl]   bgr0 => 1 planes 1x1 8/0 [rgba8] (bgr) [unorm]
[   0.704][d][vo/gpu/opengl]   0bgr => 1 planes 1x1 8/0 [rgba8] (_bgr) [unorm]
[   0.704][d][vo/gpu/opengl]   rgb0 => 1 planes 1x1 8/0 [rgba8] (rgb) [unorm]
[   0.704][d][vo/gpu/opengl]   rgba64 => 1 planes 1x1 16/0 [rgba16] (rgba) [unorm]
[   0.704][d][vo/gpu/opengl]   rgb565 => 1 planes 1x1 0/0 [rgb565] (rgb) [unknown]
[   0.704][d][vo/gpu/opengl]   pal8
[   0.704][d][vo/gpu/opengl]   vdpau
[   0.704][d][vo/gpu/opengl]   d3d11
[   0.704][d][vo/gpu/opengl]   dxva2_vld
[   0.704][d][vo/gpu/opengl]   mmal
[   0.704][d][vo/gpu/opengl]   mediacodec
[   0.704][d][vo/gpu/opengl]   cuda
[   0.704][d][vo/gpu/opengl]   yap8 => 2 planes 1x1 8/0 [r8/r8] (r/a) [unorm]
[   0.704][d][vo/gpu/opengl]   yap16 => 2 planes 1x1 16/0 [r16/r16] (r/a) [unorm]
[   0.704][d][vo/gpu/opengl]   grayaf32 => 2 planes 1x1 32/0 [r16f/r16f] (r/a) [float]
[   0.704][d][vo/gpu/opengl]   yuv444pf => 3 planes 1x1 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[   0.704][d][vo/gpu/opengl]   yuva444pf => 4 planes 1x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[   0.704][d][vo/gpu/opengl]   yuv420pf => 3 planes 2x2 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[   0.704][d][vo/gpu/opengl]   yuva420pf => 4 planes 2x2 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[   0.704][d][vo/gpu/opengl]   yuv422pf => 3 planes 2x1 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[   0.704][d][vo/gpu/opengl]   yuva422pf => 4 planes 2x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[   0.704][d][vo/gpu/opengl]   yuv440pf => 3 planes 1x2 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[   0.704][d][vo/gpu/opengl]   yuva440pf => 4 planes 1x2 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[   0.704][d][vo/gpu/opengl]   yuv410pf => 3 planes 4x4 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[   0.704][d][vo/gpu/opengl]   yuva410pf => 4 planes 4x4 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[   0.704][d][vo/gpu/opengl]   yuv411pf => 3 planes 4x1 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[   0.704][d][vo/gpu/opengl]   yuva411pf => 4 planes 4x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[   0.704][d][vo/gpu/opengl]   rgb30 => 1 planes 1x1 10/0 [rgb10_a2] (bgr) [unknown]
[   0.704][d][vo/gpu/opengl]   y1 => 1 planes 1x1 8/-7 [r8] (r) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp1 => 3 planes 1x1 8/-7 [r8/r8/r8] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp2 => 3 planes 1x1 8/-6 [r8/r8/r8] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp3 => 3 planes 1x1 8/-5 [r8/r8/r8] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp4 => 3 planes 1x1 8/-4 [r8/r8/r8] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp5 => 3 planes 1x1 8/-3 [r8/r8/r8] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp6 => 3 planes 1x1 8/-2 [r8/r8/r8] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   vdpau_output
[   0.704][d][vo/gpu/opengl]   vaapi
[   0.704][d][vo/gpu/opengl]   videotoolbox
[   0.704][d][vo/gpu/opengl]   drm_prime
[   0.704][d][vo/gpu/opengl]   yuyv422
[   0.704][d][vo/gpu/opengl]   yuv422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv410p => 3 planes 4x4 8/0 [r8/r8/r8] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   monow
[   0.704][d][vo/gpu/opengl]   monob
[   0.704][d][vo/gpu/opengl]   yuvj422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   uyyvyy411
[   0.704][d][vo/gpu/opengl]   bgr8
[   0.704][d][vo/gpu/opengl]   bgr4
[   0.704][d][vo/gpu/opengl]   bgr4_byte
[   0.704][d][vo/gpu/opengl]   rgb8
[   0.704][d][vo/gpu/opengl]   rgb4
[   0.704][d][vo/gpu/opengl]   rgb4_byte
[   0.704][d][vo/gpu/opengl]   nv21 => 2 planes 2x2 8/0 [r8/rg8] (r/bg) [unorm]
[   0.704][d][vo/gpu/opengl]   gray16be
[   0.704][d][vo/gpu/opengl]   yuv440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuvj440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva420p => 4 planes 2x2 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm]
[   0.704][d][vo/gpu/opengl]   rgb48be
[   0.704][d][vo/gpu/opengl]   rgb48 => 1 planes 1x1 16/0 [rgb16] (rgb) [unorm]
[   0.704][d][vo/gpu/opengl]   rgb565be
[   0.704][d][vo/gpu/opengl]   rgb555be
[   0.704][d][vo/gpu/opengl]   bgr565be
[   0.704][d][vo/gpu/opengl]   bgr555be
[   0.704][d][vo/gpu/opengl]   yuv420p16 => 3 planes 2x2 16/0 [r16/r16/r16] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv420p16be
[   0.704][d][vo/gpu/opengl]   yuv422p16 => 3 planes 2x1 16/0 [r16/r16/r16] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv422p16be
[   0.704][d][vo/gpu/opengl]   yuv444p16 => 3 planes 1x1 16/0 [r16/r16/r16] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv444p16be
[   0.704][d][vo/gpu/opengl]   rgb444
[   0.704][d][vo/gpu/opengl]   rgb444be
[   0.704][d][vo/gpu/opengl]   bgr444
[   0.704][d][vo/gpu/opengl]   bgr444be
[   0.704][d][vo/gpu/opengl]   ya8 => 1 planes 1x1 8/0 [rg8] (ra) [unorm]
[   0.704][d][vo/gpu/opengl]   bgr48be
[   0.704][d][vo/gpu/opengl]   bgr48 => 1 planes 1x1 16/0 [rgb16] (bgr) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv420p9be
[   0.704][d][vo/gpu/opengl]   yuv420p9 => 3 planes 2x2 16/-7 [r16/r16/r16] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv420p10be
[   0.704][d][vo/gpu/opengl]   yuv420p10 => 3 planes 2x2 16/-6 [r16/r16/r16] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv422p10be
[   0.704][d][vo/gpu/opengl]   yuv422p10 => 3 planes 2x1 16/-6 [r16/r16/r16] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv444p9be
[   0.704][d][vo/gpu/opengl]   yuv444p9 => 3 planes 1x1 16/-7 [r16/r16/r16] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv444p10be
[   0.704][d][vo/gpu/opengl]   yuv444p10 => 3 planes 1x1 16/-6 [r16/r16/r16] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   yuv422p9be
[   0.704][d][vo/gpu/opengl]   yuv422p9 => 3 planes 2x1 16/-7 [r16/r16/r16] (r/g/b) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp => 3 planes 1x1 8/0 [r8/r8/r8] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp9be
[   0.704][d][vo/gpu/opengl]   gbrp9 => 3 planes 1x1 16/-7 [r16/r16/r16] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp10be
[   0.704][d][vo/gpu/opengl]   gbrp10 => 3 planes 1x1 16/-6 [r16/r16/r16] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   gbrp16be
[   0.704][d][vo/gpu/opengl]   gbrp16 => 3 planes 1x1 16/0 [r16/r16/r16] (g/b/r) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva422p => 4 planes 2x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva444p => 4 planes 1x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva420p9be
[   0.704][d][vo/gpu/opengl]   yuva420p9 => 4 planes 2x2 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva422p9be
[   0.704][d][vo/gpu/opengl]   yuva422p9 => 4 planes 2x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva444p9be
[   0.704][d][vo/gpu/opengl]   yuva444p9 => 4 planes 1x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva420p10be
[   0.704][d][vo/gpu/opengl]   yuva420p10 => 4 planes 2x2 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva422p10be
[   0.704][d][vo/gpu/opengl]   yuva422p10 => 4 planes 2x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva444p10be
[   0.704][d][vo/gpu/opengl]   yuva444p10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.704][d][vo/gpu/opengl]   yuva420p16be
[   0.704][d][vo/gpu/opengl]   yuva420p16 => 4 planes 2x2 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.705][d][vo/gpu/opengl]   yuva422p16be
[   0.705][d][vo/gpu/opengl]   yuva422p16 => 4 planes 2x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.705][d][vo/gpu/opengl]   yuva444p16be
[   0.705][d][vo/gpu/opengl]   yuva444p16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.705][d][vo/gpu/opengl]   xyz12 => 1 planes 1x1 16/4 [rgb16] (rgb) [unorm]
[   0.705][d][vo/gpu/opengl]   xyz12be
[   0.705][d][vo/gpu/opengl]   nv16 => 2 planes 2x1 8/0 [r8/rg8] (r/gb) [unorm]
[   0.705][d][vo/gpu/opengl]   nv20 => 2 planes 2x1 16/-6 [r16/rg16] (r/gb) [unorm]
[   0.705][d][vo/gpu/opengl]   nv20be
[   0.705][d][vo/gpu/opengl]   rgba64be
[   0.705][d][vo/gpu/opengl]   bgra64be
[   0.705][d][vo/gpu/opengl]   bgra64 => 1 planes 1x1 16/0 [rgba16] (bgra) [unorm]
[   0.705][d][vo/gpu/opengl]   yvyu422
[   0.705][d][vo/gpu/opengl]   ya16be
[   0.705][d][vo/gpu/opengl]   ya16 => 1 planes 1x1 16/0 [rg16] (ra) [unorm]
[   0.705][d][vo/gpu/opengl]   gbrap => 4 planes 1x1 8/0 [r8/r8/r8/r8] (g/b/r/a) [unorm]
[   0.705][d][vo/gpu/opengl]   gbrap16be
[   0.705][d][vo/gpu/opengl]   gbrap16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (g/b/r/a) [unorm]
[   0.705][d][vo/gpu/opengl]   qsv
[   0.705][d][vo/gpu/opengl]   d3d11va_vld
[   0.705][d][vo/gpu/opengl]   yuv420p12be
[   0.705][d][vo/gpu/opengl]   yuv420p12 => 3 planes 2x2 16/-4 [r16/r16/r16] (r/g/b) [unorm]
[   0.705][d][vo/gpu/opengl]   yuv420p14be
[   0.705][d][vo/gpu/opengl]   yuv420p14 => 3 planes 2x2 16/-2 [r16/r16/r16] (r/g/b) [unorm]
[   0.705][d][vo/gpu/opengl]   yuv422p12be
[   0.705][d][vo/gpu/opengl]   yuv422p12 => 3 planes 2x1 16/-4 [r16/r16/r16] (r/g/b) [unorm]
[   0.705][d][vo/gpu/opengl]   yuv422p14be
[   0.705][d][vo/gpu/opengl]   yuv422p14 => 3 planes 2x1 16/-2 [r16/r16/r16] (r/g/b) [unorm]
[   0.705][d][vo/gpu/opengl]   yuv444p12be
[   0.705][d][vo/gpu/opengl]   yuv444p12 => 3 planes 1x1 16/-4 [r16/r16/r16] (r/g/b) [unorm]
[   0.705][d][vo/gpu/opengl]   yuv444p14be
[   0.705][d][vo/gpu/opengl]   yuv444p14 => 3 planes 1x1 16/-2 [r16/r16/r16] (r/g/b) [unorm]
[   0.705][d][vo/gpu/opengl]   gbrp12be
[   0.705][d][vo/gpu/opengl]   gbrp12 => 3 planes 1x1 16/-4 [r16/r16/r16] (g/b/r) [unorm]
[   0.705][d][vo/gpu/opengl]   gbrp14be
[   0.705][d][vo/gpu/opengl]   gbrp14 => 3 planes 1x1 16/-2 [r16/r16/r16] (g/b/r) [unorm]
[   0.705][d][vo/gpu/opengl]   yuvj411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[   0.705][d][vo/gpu/opengl]   bayer_bggr8
[   0.705][d][vo/gpu/opengl]   bayer_rggb8
[   0.705][d][vo/gpu/opengl]   bayer_gbrg8
[   0.705][d][vo/gpu/opengl]   bayer_grbg8
[   0.705][d][vo/gpu/opengl]   bayer_bggr16
[   0.705][d][vo/gpu/opengl]   bayer_bggr16be
[   0.705][d][vo/gpu/opengl]   bayer_rggb16
[   0.705][d][vo/gpu/opengl]   bayer_rggb16be
[   0.705][d][vo/gpu/opengl]   bayer_gbrg16
[   0.705][d][vo/gpu/opengl]   bayer_gbrg16be
[   0.705][d][vo/gpu/opengl]   bayer_grbg16
[   0.705][d][vo/gpu/opengl]   bayer_grbg16be
[   0.705][d][vo/gpu/opengl]   xvmc
[   0.705][d][vo/gpu/opengl]   yuv440p10 => 3 planes 1x2 16/-6 [r16/r16/r16] (r/g/b) [unorm]
[   0.705][d][vo/gpu/opengl]   yuv440p10be
[   0.705][d][vo/gpu/opengl]   yuv440p12 => 3 planes 1x2 16/-4 [r16/r16/r16] (r/g/b) [unorm]
[   0.705][d][vo/gpu/opengl]   yuv440p12be
[   0.705][d][vo/gpu/opengl]   ayuv64 => 1 planes 1x1 16/0 [rgba16] (argb) [unorm]
[   0.705][d][vo/gpu/opengl]   ayuv64be
[   0.705][d][vo/gpu/opengl]   p010be
[   0.705][d][vo/gpu/opengl]   gbrap12be
[   0.705][d][vo/gpu/opengl]   gbrap12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (g/b/r/a) [unorm]
[   0.705][d][vo/gpu/opengl]   gbrap10be
[   0.705][d][vo/gpu/opengl]   gbrap10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (g/b/r/a) [unorm]
[   0.705][d][vo/gpu/opengl]   gray12be
[   0.705][d][vo/gpu/opengl]   gray12 => 1 planes 1x1 16/-4 [r16] (r) [unorm]
[   0.705][d][vo/gpu/opengl]   gray10be
[   0.705][d][vo/gpu/opengl]   gray10 => 1 planes 1x1 16/-6 [r16] (r) [unorm]
[   0.705][d][vo/gpu/opengl]   p016 => 2 planes 2x2 16/0 [r16/rg16] (r/gb) [unorm]
[   0.705][d][vo/gpu/opengl]   p016be
[   0.705][d][vo/gpu/opengl]   gray9be
[   0.705][d][vo/gpu/opengl]   gray9 => 1 planes 1x1 16/-7 [r16] (r) [unorm]
[   0.705][d][vo/gpu/opengl]   gbrpf32be
[   0.705][d][vo/gpu/opengl]   gbrpf32 => 3 planes 1x1 32/0 [r16f/r16f/r16f] (g/b/r) [float]
[   0.705][d][vo/gpu/opengl]   gbrapf32be
[   0.705][d][vo/gpu/opengl]   gbrapf32 => 4 planes 1x1 32/0 [r16f/r16f/r16f/r16f] (g/b/r/a) [float]
[   0.705][d][vo/gpu/opengl]   opencl
[   0.705][d][vo/gpu/opengl]   gray14be
[   0.705][d][vo/gpu/opengl]   gray14 => 1 planes 1x1 16/-2 [r16] (r) [unorm]
[   0.705][d][vo/gpu/opengl]   grayf32be
[   0.705][d][vo/gpu/opengl]   grayf32 => 1 planes 1x1 32/0 [r16f] (r) [float]
[   0.705][d][vo/gpu/opengl]   yuva422p12be
[   0.705][d][vo/gpu/opengl]   yuva422p12 => 4 planes 2x1 16/-4 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.705][d][vo/gpu/opengl]   yuva444p12be
[   0.705][d][vo/gpu/opengl]   yuva444p12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[   0.705][d][vo/gpu/opengl]   nv24 => 2 planes 1x1 8/0 [r8/rg8] (r/gb) [unorm]
[   0.705][d][vo/gpu/opengl]   nv42 => 2 planes 1x1 8/0 [r8/rg8] (r/bg) [unorm]
[   0.705][d][vo/gpu/opengl]   vulkan
[   0.705][d][vo/gpu/opengl]   y210be
[   0.705][d][vo/gpu/opengl]   x2rgb10be
[   0.705][d][vo/gpu/opengl]   x2bgr10
[   0.705][d][vo/gpu/opengl]   x2bgr10be
[   0.705][d][vo/gpu/opengl]   p210be
[   0.705][d][vo/gpu/opengl]   p210 => 2 planes 2x1 16/6 [r16/rg16] (r/gb) [unorm]
[   0.705][d][vo/gpu/opengl]   p410be
[   0.705][d][vo/gpu/opengl]   p410 => 2 planes 1x1 16/6 [r16/rg16] (r/gb) [unorm]
[   0.705][d][vo/gpu/opengl]   p216be
[   0.705][d][vo/gpu/opengl]   p216 => 2 planes 2x1 16/0 [r16/rg16] (r/gb) [unorm]
[   0.705][d][vo/gpu/opengl]   p416be
[   0.705][d][vo/gpu/opengl]   p416 => 2 planes 1x1 16/0 [r16/rg16] (r/gb) [unorm]
[   0.705][v][vo/gpu] Testing FBO format rgba16f
[   0.705][d][vo/gpu] Resizing texture: 16x16
[   0.705][v][vo/gpu] Using FBO format rgba16f.
[   0.705][v][vo/gpu] No advanced processing required. Enabling dumb mode.
[   0.707][v][vo/gpu] Resize: 0x0
[   0.707][v][vd] Container reported FPS: 23.976216
[   0.707][v][vd] Codec list:
[   0.707][v][vd]     hevc - HEVC (High Efficiency Video Coding)
[   0.707][v][vd]     hevc_qsv (hevc) - HEVC video (Intel Quick Sync Video acceleration)
[   0.707][v][vd]     hevc_v4l2m2m (hevc) - V4L2 mem2mem HEVC decoder wrapper
[   0.707][v][vd]     hevc_cuvid (hevc) - Nvidia CUVID HEVC decoder
[   0.707][v][vd] Opening decoder hevc
[   0.707][v][vd] Looking at hwdec hevc-nvdec...
[   0.707][v][vd] Not using this for auto-copy.
[   0.707][v][vd] Looking at hwdec hevc-vaapi...
[   0.707][v][vd] Looking at hwdec hevc-vdpau...
[   0.707][v][vd] Looking at hwdec hevc-nvdec-copy...
[   0.708][e][ffmpeg] AVHWDeviceContext: Cannot load libcuda.so.1
[   0.708][e][ffmpeg] AVHWDeviceContext: Could not dynamically load CUDA
[   0.708][v][vd] Could not create device.
[   0.708][v][vd] Looking at hwdec hevc-vaapi-copy...
[   0.708][d][vaapi] libva: VA-API version 1.16.0
[   0.708][d][vaapi] libva: Trying to open /usr/lib/dri/iHD_drv_video.so
[   0.709][d][vaapi] libva: Found init function __vaDriverInit_1_15
[   0.710][d][vaapi] libva: va_openDriver() returns 0
[   0.710][v][vaapi] Initialized VAAPI: version 1.16
[   0.710][d][ffmpeg] AVHWDeviceContext: VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 22.4.4 ().
[   0.710][d][ffmpeg] AVHWDeviceContext: Driver not found in known nonstandard list, using standard behaviour.
[   0.710][v][vd] Trying hardware decoding via hevc-vaapi-copy.
[   0.710][v][vd] Selected codec: hevc (HEVC (High Efficiency Video Coding))
[   0.710][v][vf] User filter list:
[   0.710][v][vf]   (empty)
[   0.711][v][ad] Codec list:
[   0.711][v][ad]     aac - AAC (Advanced Audio Coding)
[   0.711][v][ad]     aac_fixed (aac) - AAC (Advanced Audio Coding)
[   0.711][v][ad] Opening decoder aac
[   0.711][v][ad] Requesting 1 threads for decoding.
[   0.713][v][ad] Selected codec: aac (AAC (Advanced Audio Coding))
[   0.713][v][af] User filter list:
[   0.713][v][af]   (empty)
[   0.713][v][cplayer] Starting playback...
[   0.713][v][file] stream level seek from 2376208303 to 44
[   0.714][d][lavf] stream 1: resize index to 128
[   0.714][d][lavf] stream 0: resize index to 128
[   0.714][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"]
[   0.714][v][cplayer] Set property: shared-script-properties -> 1
[   0.714][v][af] [in] 48000Hz 5.1 6ch floatp
[   0.714][v][af] [userspeed] 48000Hz 5.1 6ch floatp
[   0.714][v][af] [userspeed] (disabled)
[   0.714][v][af] [convert] 48000Hz 5.1 6ch floatp
[   0.715][w][ffmpeg/demuxer] mov,mp4,m4a,3gp,3g2,mj2: Packet corrupt (stream = 0, dts = 2102083).
[   0.715][e][ffmpeg/demuxer] mov,mp4,m4a,3gp,3g2,mj2: stream 1, offset 0x45783: partial file
[   0.715][v][lavf] EOF reached.
[   0.715][v][vd] Pixel formats supported by decoder: vaapi vdpau cuda yuv420p10le
[   0.715][v][vd] Codec profile: Main 10 (0x2)
[   0.715][v][vd] Requesting pixfmt 'vaapi' from decoder.
[   0.741][i][vd] Using hardware decoding (vaapi-copy).
[   0.741][v][vd] Decoder format: 1920x804 p010 auto/auto/auto/limited/auto CL=mpeg2/4/h264
[   0.741][v][vd] Using container aspect ratio.
[   0.741][v][vf] [in] 1920x804 p010 bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[   0.741][v][vf] [userdeint] 1920x804 p010 bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[   0.741][v][vf] [userdeint] (disabled)
[   0.741][v][vf] [autorotate] 1920x804 p010 bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[   0.742][v][vf] [autorotate] (disabled)
[   0.742][v][vf] [convert] 1920x804 p010 bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[   0.742][v][vf] [convert] (disabled)
[   0.742][v][vf] [out] 1920x804 p010 bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[   0.742][v][ao] Trying audio driver 'pipewire'
[   0.742][v][ao/pipewire] requested format: 48000 Hz, 5.1 channels, floatp
[   0.742][v][ao/pipewire] Headers version: 0.3.60
[   0.742][v][ao/pipewire] Library version: 0.3.59
[   0.744][v][ao/pipewire] Core user: lw208
[   0.744][v][ao/pipewire] Core host: desktop-linux
[   0.744][v][ao/pipewire] Core version: 0.3.59
[   0.744][v][ao/pipewire] Core name: pipewire-0
[   0.744][v][ao/pipewire] PipeWire does not have any audio sinks, skipping
[   0.745][v][ao] Trying audio driver 'pulse'
[   0.745][v][ao/pulse] requested format: 48000 Hz, 5.1 channels, floatp
[   0.745][v][ao/pulse] Library version: 16.1.0
[   0.745][v][ao/pulse] Proto: 35
[   0.745][v][ao/pulse] Server proto: 4294967295
[   0.746][v][ao/pulse] Channel layouts:
[   0.747][v][ao/pulse]  - #fl
[   0.747][v][ao/pulse]  - #fr
[   0.747][v][ao/pulse]  - #fc
[   0.747][v][ao/pulse]  - #lfe
[   0.747][v][ao/pulse]  - #bl
[   0.747][v][ao/pulse]  - #br
[   0.747][v][ao/pulse]  - #flc
[   0.747][v][ao/pulse]  - #frc
[   0.747][v][ao/pulse]  - #bc
[   0.747][v][ao/pulse]  - #sl
[   0.747][v][ao/pulse]  - #sr
[   0.747][v][ao/pulse]  - #tc
[   0.747][v][ao/pulse]  - #tfl
[   0.747][v][ao/pulse]  - #tfc
[   0.747][v][ao/pulse]  - #tfr
[   0.747][v][ao/pulse]  - #tbl
[   0.747][v][ao/pulse]  - #tbc
[   0.747][v][ao/pulse]  - #tbr
[   0.747][v][ao/pulse] result: 5.1
[   0.950][v][ao/pulse] device buffer: 4800 samples.
[   0.951][v][ao/pulse] using soft-buffer of 9600 samples.
[   0.951][i][cplayer] AO: [pulse] 48000Hz 5.1 6ch float
[   0.951][v][cplayer] AO: Description: PulseAudio audio output
[   0.951][v][autoconvert] inserting resampler
[   0.951][v][swresample] format change, reinitializing resampler
[   0.951][v][swresample] 48000Hz 5.1 floatp -> 48000Hz 5.1 float
[   0.951][v][af] [out] 48000Hz 5.1 6ch float
[   0.958][i][cplayer] VO: [gpu] 1920x804 p010
[   0.958][v][cplayer] VO: Description: Shader-based GPU Renderer
[   0.958][v][vo/gpu] reconfig to 1920x804 p010 bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[   0.958][v][vo/gpu/wayland] Reconfiguring!
[   0.958][d][vo/gpu] max content size: 1920x1080
[   0.958][d][vo/gpu] monitor size: 1920x1080
[   0.958][v][vo/gpu] Resize: 1920x804
[   0.958][v][vo/gpu] Window size: 1920x804 (Borders: l=0 t=0 r=0 b=0)
[   0.958][v][vo/gpu] Video source: 1920x804 (1:1)
[   0.958][v][vo/gpu] Video display: (0, 0) 1920x804 -> (0, 0) 1920x804
[   0.958][v][vo/gpu] Video scale: 1.000000/1.000000
[   0.958][v][vo/gpu] OSD borders: l=0 t=0 r=0 b=0
[   0.958][v][vo/gpu] Video borders: l=0 t=0 r=0 b=0
[   0.958][v][vo/gpu] Texture for plane 0: 1920x804
[   0.959][v][vo/gpu] Texture for plane 1: 960x402
[   0.959][v][vo/gpu] Testing FBO format rgba16f
[   0.959][d][vo/gpu] Resizing texture: 16x16
[   0.959][v][vo/gpu] Using FBO format rgba16f.
[   0.959][v][vo/gpu] No advanced processing required. Enabling dumb mode.
[   0.959][v][vo/gpu/wayland] Handling resize on the egl side
[   0.962][v][vo/gpu] Resize: 1920x804
[   0.962][v][vo/gpu] Window size: 1920x804 (Borders: l=0 t=0 r=0 b=0)
[   0.962][v][vo/gpu] Video source: 1920x804 (1:1)
[   0.962][v][vo/gpu] Video display: (0, 0) 1920x804 -> (0, 0) 1920x804
[   0.962][v][vo/gpu] Video scale: 1.000000/1.000000
[   0.962][v][vo/gpu] OSD borders: l=0 t=0 r=0 b=0
[   0.962][v][vo/gpu] Video borders: l=0 t=0 r=0 b=0
[   0.962][v][vo/gpu] Reported display depth: 10
[   0.974][d][vo/gpu/opengl] vertex shader source:
[   0.974][d][vo/gpu/opengl] [  1] #version 440
[   0.974][d][vo/gpu/opengl] [  2] #define tex1D texture
[   0.974][d][vo/gpu/opengl] [  3] #define tex3D texture
[   0.974][d][vo/gpu/opengl] [  4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x))
[   0.974][d][vo/gpu/opengl] [  5] in vec2 vertex_position;
[   0.974][d][vo/gpu/opengl] [  6] in vec2 vertex_texcoord0;
[   0.974][d][vo/gpu/opengl] [  7] out vec2 texcoord0;
[   0.974][d][vo/gpu/opengl] [  8] in vec2 vertex_texcoord1;
[   0.974][d][vo/gpu/opengl] [  9] out vec2 texcoord1;
[   0.974][d][vo/gpu/opengl] [ 10] void main() {
[   0.974][d][vo/gpu/opengl] [ 11] gl_Position = vec4(vertex_position, 1.0, 1.0);
[   0.974][d][vo/gpu/opengl] [ 12] texcoord0 = vertex_texcoord0;
[   0.974][d][vo/gpu/opengl] [ 13] texcoord1 = vertex_texcoord1;
[   0.974][d][vo/gpu/opengl] [ 14] }
[   0.974][d][vo/gpu/opengl] fragment shader source:
[   0.974][d][vo/gpu/opengl] [  5] out vec4 out_color;
[   0.974][d][vo/gpu/opengl] [  6] in vec2 texcoord0;
[   0.974][d][vo/gpu/opengl] [  7] in vec2 texcoord1;
[   0.974][d][vo/gpu/opengl] [  8] layout(std140, binding=0) uniform UBO {
[   0.974][d][vo/gpu/opengl] [  9] layout(offset=0) mat3 colormatrix;
[   0.974][d][vo/gpu/opengl] [ 10] layout(offset=48) vec3 colormatrix_c;
[   0.974][d][vo/gpu/opengl] [ 11] layout(offset=64) vec3 src_luma;
[   0.974][d][vo/gpu/opengl] [ 12] layout(offset=80) vec3 dst_luma;
[   0.974][d][vo/gpu/opengl] [ 13] layout(offset=96) vec2 texture_size0;
[   0.974][d][vo/gpu/opengl] [ 14] layout(offset=112) mat2 texture_rot0;
[   0.974][d][vo/gpu/opengl] [ 15] layout(offset=144) vec2 texture_off0;
[   0.974][d][vo/gpu/opengl] [ 16] layout(offset=152) vec2 pixel_size0;
[   0.974][d][vo/gpu/opengl] [ 17] layout(offset=160) vec2 texture_size1;
[   0.974][d][vo/gpu/opengl] [ 18] layout(offset=176) mat2 texture_rot1;
[   0.974][d][vo/gpu/opengl] [ 19] layout(offset=208) vec2 texture_off1;
[   0.974][d][vo/gpu/opengl] [ 20] layout(offset=216) vec2 pixel_size1;
[   0.974][d][vo/gpu/opengl] [ 21] };
[   0.974][d][vo/gpu/opengl] [ 22] uniform sampler2D texture0;
[   0.974][d][vo/gpu/opengl] [ 23] uniform sampler2D texture1;
[   0.974][d][vo/gpu/opengl] [ 24] void main() {
[   0.974][d][vo/gpu/opengl] [ 25] vec4 color = vec4(0.0, 0.0, 0.0, 1.0);
[   0.974][d][vo/gpu/opengl] [ 26] color.r = 1.003906 * vec4(texture(texture0, texcoord0)).r;
[   0.974][d][vo/gpu/opengl] [ 27] color.gb = 1.003906 * vec4(texture(texture1, texcoord1)).rg;
[   0.974][d][vo/gpu/opengl] [ 28] color = color.rgbr;
[   0.974][d][vo/gpu/opengl] [ 29] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c;
[   0.974][d][vo/gpu/opengl] [ 30] color.a = 1.0;
[   0.974][d][vo/gpu/opengl] [ 31] // color mapping
[   0.974][d][vo/gpu/opengl] [ 32] color.rgb *= vec3(1.000000);
[   0.974][d][vo/gpu/opengl] [ 33] color.rgb *= vec3(1.000000);
[   0.974][d][vo/gpu/opengl] [ 34] out_color = color;
[   0.974][d][vo/gpu/opengl] [ 35] }
[   0.974][d][vo/gpu/opengl] shader link log (status=1):
[   0.989][v][vo/gpu/wayland] Given DND offer with mime type text/plain
[   0.989][v][vo/gpu/wayland] Given DND offer with mime type text/plain;charset=utf-8
[   0.989][v][vo/gpu/wayland] Received a new DND offer. Releasing the previous offer.
[   0.989][v][vo/gpu/wayland] Surface entered output DEL DELL S2421HS (0x4), scale = 1, refresh rate = 60.000000 Hz
[   0.989][v][vo/gpu] Assuming 60.000000 FPS for display sync.
[   0.989][v][cplayer] first video frame after restart shown
[   0.990][d][osc] osc_init
[   0.992][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"]
[   0.992][v][cplayer] Set property: shared-script-properties -> 1
[   0.992][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   0.993][d][osc] osc_init
[   0.993][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"]
[   0.993][v][cplayer] Set property: shared-script-properties -> 1
[   0.994][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.000][v][cplayer] audio ready
[   1.000][d][cplayer] starting video playback
[   1.000][v][cplayer] delaying audio start 0.000000 vs. -0.083416, diff=0.083416
[   1.000][v][cplayer] playback restart complete @ -0.083416, audio=ready, video=playing
[   1.024][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.075][v][cplayer] starting audio playback
[   1.076][v][ao/pulse] starting AO
[   1.090][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.204][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.244][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.275][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.305][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.335][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.378][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.408][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.445][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.475][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.510][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.549][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.589][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.620][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.660][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.692][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.737][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.781][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.811][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.852][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.889][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.935][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   1.982][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   2.020][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   2.055][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   2.102][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   2.148][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   2.178][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   2.219][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   2.251][d][cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[   2.254][d][cplayer] Run command: script-binding, flags=73, args=[name="osc/__keybinding4"]
[   2.278][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"]
[   2.278][v][cplayer] Set property: shared-script-properties -> 1
[   2.281][d][cplayer] Run command: enable-section, flags=64, args=[name="input", flags=""]
[   2.281][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.310][v][osd/libass] fontselect: (sans-serif, 400, 0) -> /usr/share/fonts/noto/NotoSans-Regular.ttf, 0, NotoSans-Regular
[   2.314][v][osd/libass] fontselect: (mpv-osd-symbols, 400, 0) -> mpv-osd-symbols-Regular, 0, mpv-osd-symbols-Regular
[   2.315][v][vo/gpu] Reallocating OSD texture to 2048x512.
[   2.315][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.315][d][vo/gpu/opengl] vertex shader source:
[   2.315][d][vo/gpu/opengl] [  1] #version 440
[   2.315][d][vo/gpu/opengl] [  2] #define tex1D texture
[   2.315][d][vo/gpu/opengl] [  3] #define tex3D texture
[   2.315][d][vo/gpu/opengl] [  4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x))
[   2.315][d][vo/gpu/opengl] [  5] in vec2 vertex_position;
[   2.315][d][vo/gpu/opengl] [  6] in vec2 vertex_texcoord;
[   2.315][d][vo/gpu/opengl] [  7] out vec2 texcoord;
[   2.315][d][vo/gpu/opengl] [  8] in vec4 vertex_ass_color;
[   2.315][d][vo/gpu/opengl] [  9] out vec4 ass_color;
[   2.315][d][vo/gpu/opengl] [ 10] void main() {
[   2.315][d][vo/gpu/opengl] [ 11] gl_Position = vec4(vertex_position, 1.0, 1.0);
[   2.315][d][vo/gpu/opengl] [ 12] texcoord = vertex_texcoord;
[   2.315][d][vo/gpu/opengl] [ 13] ass_color = vertex_ass_color;
[   2.315][d][vo/gpu/opengl] [ 14] }
[   2.315][d][vo/gpu/opengl] fragment shader source:
[   2.315][d][vo/gpu/opengl] [  5] out vec4 out_color;
[   2.315][d][vo/gpu/opengl] [  6] in vec2 texcoord;
[   2.315][d][vo/gpu/opengl] [  7] in vec4 ass_color;
[   2.315][d][vo/gpu/opengl] [  8] layout(std140, binding=0) uniform UBO {
[   2.315][d][vo/gpu/opengl] [  9] layout(offset=0) vec3 src_luma;
[   2.315][d][vo/gpu/opengl] [ 10] layout(offset=16) vec3 dst_luma;
[   2.315][d][vo/gpu/opengl] [ 11] };
[   2.315][d][vo/gpu/opengl] [ 12] uniform sampler2D osdtex;
[   2.315][d][vo/gpu/opengl] [ 13] void main() {
[   2.315][d][vo/gpu/opengl] [ 14] vec4 color = vec4(0.0, 0.0, 0.0, 1.0);
[   2.315][d][vo/gpu/opengl] [ 15] color = vec4(ass_color.rgb, ass_color.a * texture(osdtex, texcoord).r);
[   2.315][d][vo/gpu/opengl] [ 16] // color mapping
[   2.315][d][vo/gpu/opengl] [ 17] color.rgb *= vec3(1.000000);
[   2.315][d][vo/gpu/opengl] [ 18] color.rgb *= vec3(1.000000);
[   2.315][d][vo/gpu/opengl] [ 19] out_color = color;
[   2.315][d][vo/gpu/opengl] [ 20] }
[   2.315][d][vo/gpu/opengl] shader link log (status=1):
[   2.345][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.387][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.423][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.454][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.484][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.515][v][af] filter input EOF
[   2.515][v][af] filter output EOF
[   2.515][v][cplayer] audio filter EOF
[   2.515][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.515][v][cplayer] audio draining
[   2.515][v][cplayer] audio EOF reached
[   2.545][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.584][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.624][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.625][e][ffmpeg/video] hevc: Invalid NAL unit size (25630 > 3227).
[   2.625][e][ffmpeg/video] hevc: Error splitting the input into NAL units.
[   2.625][w][vd] Error while decoding frame (hardware decoding)!
[   2.654][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.685][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.716][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.717][v][ao/pulse] audio end or underrun
[   2.750][w][cplayer] Invalid video timestamp: 1.710028 -> 1.710028
[   2.758][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.765][w][cplayer] Invalid video timestamp: 1.710028 -> 1.584904
[   2.788][d][cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[   2.792][v][vf] filter input EOF
[   2.792][v][vf] filter output EOF
[   2.799][v][cplayer] EOF code: 1
[   2.799][d][ad] Uninit decoder.
[   2.799][d][vd] Uninit decoder.
[   2.804][d][cplayer] Terminating demuxers...
[   2.804][d][cplayer] Done terminating demuxers.
[   2.805][v][cplayer] finished playback, success (reason 0)
[   2.805][i][cplayer]
[   2.805][i][cplayer] Exiting... (End of file)
[   2.805][d][console] Exiting...
[   2.805][d][cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="remove", value="osc-margins"]
[   2.805][v][cplayer] Set property: shared-script-properties -> 1
[   2.805][d][stats] Exiting...
[   2.805][d][osc] Exiting...
[   2.805][d][ytdl_hook] Exiting...
[   2.807][v][cplayer] draining left over audio
[   2.825][v][ao/pulse] audio end or underrun
[   2.826][d][vo/gpu] flushing shader cache
[   2.829][v][vo/gpu/wayland] Deregistering output DEL DELL S2421HS (0x4)
请大家帮忙看看,问题出在哪?是ffmpeg的问题吗?谢谢。
看上去这个 e 就是错误日志,可以搜一下
搜索了,没有找到有用的信息,看起来是ffmpeg认为这个文件损坏了,有点奇怪。
为什么MPV不同样指定硬件解码器为vaapi呢?MPV官方文档似乎是说copy的解码器是不推荐的,除非普通解码器不能正常使用。
这个问题最终发现是局域网samba共享的问题,换成NFS后播放正常。
