mpv is being weird about fonts.
I managed to set the OSD to something less squished with osd-font='Droid Sans' , but the info is still shown with what mpv has deemed as its current default font:
Here is what the OSD will look like, if I haven’t configured a font for it myself:
My ~/.config/mpv/mpv.conf:
cache=yes
demuxer-max-bytes=6GiB
demuxer-max-back-bytes=600MiB
geometry=48%x48%+1%+17%
ao=pipewire
volume=80
hwdec=no
profile=high-quality
ytdl-format=bestvideo[height<=?1440]+bestaudio/best
ytdl-raw-options='sub-lang="en,en-US,en-GB,fi"'
ytdl-raw-options-add=write-subs=
sub-font-size=45
x11-bypass-compositor=no
screenshot-directory=~/Pictures/Screenshots
screenshot-format=png
osc=yes
Kernel: 6.9.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=c28c9ba1-1ab9-48ed-a6c3-a5cf6794acea rw apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1 nowatchdog
mitigations=off amd-pstate=guided amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 2.K0 date: 10/20/2023
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4056 high: 4650 min/max: 550/4651 boost: enabled
scaling: driver: amd-pstate governor: schedutil cores: 1: 3918 2: 3915
3: 3735 4: 4011 5: 3754 6: 4649 7: 4280 8: 3718 9: 3800 10: 4400 11: 3851
12: 4650 bogomips: 88825
Type: spec_rstack_overflow status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2, HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 28:00.0
chip-ID: 1002:747e class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: DP-1 res: 2560x1440 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.7-arch10.3
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 17.0.6 DRM 3.57 6.9.1-1-MANJARO) device-ID: 1002:747e
memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 24.0.7-arch10.3
device-ID: 1002:747e surfaces: xcb,xlib,wayland
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 28:00.1 chip-ID: 1002:ab30
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SAVITECH ODAC-revB driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3
chip-ID: 262a:1048 class-ID: 0102
API: ALSA v: k6.9.1-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Supported mdraid levels: raid0
Device-1: md0 maj-min: 9:0 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 780914688 chunk-size: 512k super-blocks: 1.2
Components: Online:
0: sdb maj-min: 8:16 size: 186.31 GiB
1: sdc maj-min: 8:32 size: 186.31 GiB
2: sdd maj-min: 8:48 size: 186.31 GiB
3: sde maj-min: 8:64 size: 186.31 GiB
Local Storage: total: 1.18 TiB used: 849.27 GiB (70.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 910 200GB
size: 186.31 GiB block-size: physical: 4096 B logical: 512 B tech: SSD
serial: N/A fw-rev: a424
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 910 200GB
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 910 200GB
ID-5: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 910 200GB
ID-1: / raw-size: 465.26 GiB size: 456.89 GiB (98.20%)
used: 301.34 GiB (66.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 1 (default 60) cache-pressure: 30 (default 100)
zswap: yes compressor: zstd max-pool: 20%
ID-1: swap-1 type: file size: 8 GiB used: 8.5 MiB (0.1%) priority: -2
file: /mnt/faaast/swap
System Temperatures: cpu: 38.0 C mobo: 41.0 C gpu: amdgpu temp: 42.0 C
mem: 55.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1308 fan-3: 852 fan-4: 581 fan-5: 939
gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.27 GiB used: 8.62 GiB (27.6%)
Processes: 350 Power: uptime: 22h 43m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.49 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Packages: pm: pacman pkgs: 1581 libs: 458 tools: pamac Compilers:
gcc: 14.1.1 Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.34
