Greetings All,
I’m posting a solution to a firmware update problem with the AKAI MPC Sample and KDE Plasma.
I was not able to update firmware through: mpc-sample.local on any browser.
My Solution:
- Connect MPC Sample to your computer via USB and turn it on
- Add another wired connection and restrict it to, in my case, USB0 (save the connection)
- Open any browser and start a private window session, for good measure
- type in the address bar: mpc-sample.local
- Update as usual
Hope this helps somebody.
Cheers,
AT
