I tried to re-install KDE with a separate partition for /home AND btrfs for root. At the time of installation, the single partition was btrfs, but when I was done with the installation, root was on ext4 and /home on btrfs.
There wasn’t a way to specify the format when I was replacing a partition (root) as opposed to erasing the entire disk.
I have installed kde as one big partition and then went in kparted and made it two partitions, setting the second one with a mount point /home. Both partitions, sda2 and sda3 are btrfs.
My question: does the system automatically ‘move’ /home to sda3? Or do I need to move it. If I need to move it, how do I do that?
You can’t simply move mount options around: fstab - ArchWiki
Most notably, the main difference between the two recorded home mounts is that the latter sits at the root of the partition, while the former is a subvolume: Btrfs - ArchWiki
