Manjaro doesn’t boots after changing my Hard Drive to other computer, I plugged in my hard drive on my other computer to do something in that PC, but it doesn’t boots up, I’m so new with this, so I will appreciate any help, thanks
Probably it won’t boot, different hardware, different bios…just start manjaro from a flash drive, like when you ran the installation, do what you have to do, and when you are done, leave the hard drive in its main machine.
The installed system is not prepared for such moving around.
It is possible - with a default install it is a hit’n’miss - but you have to prepare the system for this use case.
The default installer cannot prepare the system to be movable - you will need to do a manual installation.
If it is a UEFI system, probably you have to add a Manjaro entry to the UEFI/BIOS
