So I have Manjaro installation that works fine. Today I decided to pull out my two SSDs (one “system” and one “data”) and put them in other computer that don’t have any drive. It was unable to boot, it was just displaying black screen with blinking cursor. Do I need to reinstall GRUB like it’s depicted here? I remember I was doing susch things before in Arch wihout problem but then I didn’t had EFI installed… The other computer is fully functional, can boot from flash or other SSD drive.
Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=132c7756-e49f-4b54-8031-f60889f27257 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: Gigabyte model: F2A68HM-S1 v: x.x serial: N/A
uuid: 03000200-0400-0500-0006-000700080009 UEFI: American Megatrends v: F1
date: 11/14/2014
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
Info: model: AMD A8-7600 Radeon R7 10 Compute Cores 4C+6G socket: FM2 (P0)
note: check bits: 64 type: MCP arch: Steamroller level: v2 built: 2014
process: GF 28nm family: 0x15 (21) model-id: 0x30 (48) stepping: 1
microcode: 0x6003104
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 256 KiB desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 1400 min/max: 1400/3100 boost: enabled
base/boost: 3100/3100 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
bogomips: 24765
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: NVIDIA GF119 [GeForce GT 520] vendor: ASUSTeK ENGT520 SILENT
driver: nouveau v: kernel non-free: series: 390.xx+
status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DVI-I-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:1040 class-ID: 0300
temp: 41.0 C
Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
alternate: fbdev,vesa dri: nouveau gpu: nouveau display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 model: Dell U2419H serial: <filter> built: 2020
res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.2.4-arch1.0.1
glx-v: 1.4 direct-render: yes renderer: NVD9 device-ID: 10de:1040
memory: 991.2 MiB unified: no
Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
class-ID: 0403
Device-2: NVIDIA GF119 HDMI Audio vendor: ASUSTeK ENGT520 SILENT
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0e08 class-ID: 0403
API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: n/a (root, process) with: wireplumber
status: active tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-039b8f783f2f state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-1fee39f0e525 state: down mac: <filter>
IF-ID-3: br-371a7ffb3b62 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-3c5198f65278 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: br-42bdda6993d1 state: down mac: <filter>
IF-ID-6: br-45d6d6dc23f6 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-7: br-4c8670060d5a state: down mac: <filter>
IF-ID-8: br-58d8c103547f state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-9: br-592471b51118 state: down mac: <filter>
IF-ID-10: br-60887cfaa3e1 state: down mac: <filter>
IF-ID-11: br-626449f67006 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-12: br-8c5bf3ca6527 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-13: br-ae5c45fbef4c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-14: br-b223f62599dc state: down mac: <filter>
IF-ID-15: br-e73ec7bbcc5c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-16: br-f3ca67385fcf state: down mac: <filter>
IF-ID-17: docker0 state: down mac: <filter>
IF-ID-18: veth11d9bdd state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-19: veth183d429 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-20: veth1d9fe44 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-21: veth2aa0e6f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-22: veth31ccb1f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-23: veth34f7050 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-24: veth4c597ee state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-25: veth4e290fe state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-26: veth54ed8f0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-27: veth5a3a07c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-28: veth5dc556e state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-29: veth6597c17 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-30: veth8db6a5f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-31: vethb3c981d state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-32: vethb439ad4 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-33: vethbacf67c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-34: vethcdb4fc5 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-35: vethd69bd06 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-36: vethdf5e262 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-37: vethe1826b7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-38: vethec1c38a state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-39: vethef524f6 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-40: vethf01300e state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-41: vethf1131f8 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-42: vethf822664 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: NetworkManager, nginx, systemd-timesyncd
Local Storage: total: 558.92 GiB used: 455.63 GiB (81.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: HP model: SSD S650 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 611 temp: 29 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 174d 9h cycles: 748
read: 1.8 MiB written: 3.5 MiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
family: Driven SSDs size: 447.13 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 0107 temp: 31 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 315d 12h cycles: 1773
read: 20792 GiB written: 15102 GiB
ID-1: / raw-size: 111.49 GiB size: 109.18 GiB (97.93%)
used: 52.91 GiB (48.5%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nouveau temp: 41.0 C
Fan Speeds (rpm): cpu: 0 fan-2: 1650 fan-3: 0 fan-4: 0 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 4.01 gpu: nouveau mV: 900.00
Packages: pm: pacman pkgs: 1793 libs: 528 tools: pamac
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
4: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Memory: total: 16 GiB available: 15.57 GiB used: 4.31 GiB (27.7%)
Processes: 377 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16
default: Bash v: 5.2.37 running-in: yakuake inxi: 3.3.36
