rethus
1
I’ve build a new pc and want to move my sdd now into this new pc.
If I do so and start the pc, it immediately enter the bios (MSI).
In the bios I see the SDD is recognized. What might be the issue, that the system only switch into bios-mode instead of just starting?
The UEFI needs an entry where to boot from.
Please be a bit more verbose in your description.
- Is on your SSD a BIOS or a UEFI-install
OR: inxi !
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxi
in a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already
for your problem in the forum ? (Wisdom lies in asking → listening → reading
Hi @rethus,
I’m not
on this. but it might be that the old machine was BIOS and the new one is UEFI…
I think it can be converted, I just don’t know how. It’s probably easier to simply reinstall, though.
Edit:
AH! See
rethus
4
I think I already have UEFI, don’t remember. But sys/firmware/efi returns following:
[ -d /sys/firmware/efi ] && echo UEFI || echo BIOS
UEFI
Is this a proof of that I have UEFI?
Partition manager shows it that way:
inxi:
inxi
Kernel: 6.1.69-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c63f7ccc-1f25-44e8-aafc-d5833a65f3ef rw acpi_osi=Linux
"acpi_osi=!Windows 2012" acpi=force acpi_enforce_resources=lax
rd.udev.log-priority=3 nopti spectre_v2=off
resume=UUID=b73dfb10-0e46-4863-8b13-6a38eed1755e
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 dm:
1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: N76VZ v: 1.0 serial: <filter>
Mobo: ASUSTeK model: N76VZ v: 1.0 serial: <filter>
UEFI: American Megatrends v: N76VZ.207 date: 05/23/2012
ID-1: BAT0 charge: 0.4 Wh (100.0%) condition: 0.4/57.2 Wh (0.7%) volts: 12.4
min: 11.1 model: ASUSTeK N56--52 type: Li-ion serial: N/A status: full
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 90%
rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 15.08 GiB used: 4.84 GiB (32.1%)
igpu: 512 MiB
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CMSA8GX3M1A1600C11 serial: N/A
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i7-3610QM socket: rPGA988B bits: 64 type: MT MCP
arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15 process: Intel 22nm
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1197 high: 1200 min/max: 1200/3300 base/boost: 2300/3800
scaling: driver: intel_cpufreq governor: schedutil volts: 5.0 V
ext-clock: 100 MHz cores: 1: 1197 2: 1200 3: 1200 4: 1197 5: 1197 6: 1197
7: 1197 8: 1198 bogomips: 36735
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK N56VZ
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1,VGA-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:0166
class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 650M] vendor: ASUSTeK N56VZ
driver: nvidia v: 390.157 alternate: nouveau,nvidia_drm non-free:
series: 470.xx+ status: legacy-active (EOL~2024-09-xx) arch: Kepler
code: GKxxx process: TSMC 28nm built: 2012-2018 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:0fd1
class-ID: 0300
Display: server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: modesetting unloaded: fbdev
alternate: vesa dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: LVDS-1 pos: right model: Chi Mei Opto 0x1720 built: 2011
res: 1920x1080 hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
Monitor-2: VGA-1 pos: primary,left model: BenQ BL2400 serial: <filter>
built: 2011 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 609mm (24") ratio: 16:9, 15:9 modes:
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: intel crocus platforms: gbm: drv: crocus
surfaceless: drv: crocus x11: drv: crocus inactive: wayland
API: OpenGL v: 4.2 vendor: intel mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
device-ID: 8086:0166 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu
name: Intel HD Graphics 4000 (IVB GT2) driver: mesa intel
v: 23.1.9-manjaro1.1 device-ID: 8086:0166 surfaces: xcb,xlib
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2 speed: 5 GT/s
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
API: ALSA v: k6.1.69-1-MANJARO status: kernel-api with: 1: osspd
status: off 2: aoss type: oss-emulator tools: alsactl,alsamixer,amixer
Server-2: JACK v: 1.9.22 status: off with: a2jmidid status: off tools: N/A
Server-3: PipeWire v: 1.0.0 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active (root, process) with:
tools: pacat,pactl,pamixer,pavucontrol
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:0887
class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK N56VZ
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 04:00.0 chip-ID: 1969:1091 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-1f3a680af564 state: down mac: <filter>
IF-ID-2: br-553d7bda5ca7 state: down mac: <filter>
IF-ID-3: br-869e550acc09 state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1:3
chip-ID: 8087:07da class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 931.51 GiB used: 617.36 GiB (66.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 167d 14h cycles: 4259
written: 41.03 TiB
Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: BD-CMB UJ160 rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 916.32 GiB size: 901.75 GiB (98.41%)
used: 617.36 GiB (68.5%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: c63f7ccc-1f25-44e8-aafc-d5833a65f3ef
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 152 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: 9B96-8EF3
Kernel: swappiness: 25 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: b73dfb10-0e46-4863-8b13-6a38eed1755e
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.1:3 info: Intel Centrino Bluetooth Wireless Transceiver
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 8087:07da
class-ID: e001
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-2:2 info: DYGMA DEFY type: abstract (modem),CDC-data,HID
driver: cdc_acm,hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 35ef:0012 class-ID: 0300 serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 63.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Processes: 288 Uptime: 6m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 2255 pm: dpkg
pkgs: 0 pm: pacman pkgs: 2229 libs: 586 tools: pamac,yay pm: rpm pkgs: 0
pm: flatpak pkgs: 7 pm: snap pkgs: 19 Shell: Sudo (sudo) v: 1.9.15p4
default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
This is your EFI-Partition
All you need to do is recreate a boot entry in your UEFI (Bios) that points to the EFI partition and the Grub binary there.
You can do this yourself by reinstalling Grub from
- live manjaro and chroot
or
- from inside your running manjaro
(see @ wiki)
Or someone who knows can help you. (My knowledge in this area is not yet sufficient to give good tips)
