Move audio notification
How can I move the audio notification from the middle of the screen?
If you have the patience to go trough this, where is explained where and how is best to modify the files
Then you follow this, and see the code provided by one comment
And you put those things together, you might succeed. Is too much at this point to trim down in to a complete tutorial.
If you dislike the volume change to pop up, it can also be disabled by right click on the volume icon > Configure Audio Volume, and you disable the visuals for changes that occur …
Thanks for the reply
Not proportional to the amount of annoyance
Juice not worth squeeze :smiley:
