I’m having trouble editing simple text document that’s located on my network storage using default Manjaro’s “mousepad” editor. To be more precise, double click triggers only a loading circle animation and nothing else happens - the document won’t even open. But for example when i try using “leafpad” editor same thing works just fine.
And when i try editing document on local storage it works fine using both programs. Problem occurs only with editing these “remote” files with mousepad.
Is that a bug in mousepad ?
I know that answer to this question could be, well just use leafpad instead, but for curiosity sake and for sake of having as less redundant software on my PC, i would like to know if that can be achieved with default editor
Your response is pretty detailed and to be honest didn’t expected that someone would invest that much effort to post a link to relevant mousepad tickets. So thank you for that.
I will definitely check those and will open new ticket in case its not done before me.
