Is there a way in Cinnamon to control the pipewire volume globally using mouse middle click + wheel up or down without using programs like xbindkeys to load at boot and remain on memory?
That could be possible only if mouse have internal memory.
If you know the command(s), you can always set them to automatically run on startup…
i can use xdotool to send keyboard keystrokes that raise or lower volume but assign them to mouse click combinations? how
Uhm…why are you asking? Because
- That isn’t what you originally asked; and
- I did mention that it’s if you knew the commands. I don’t.
