There are two problems I am facing currently
When i try to move the pointer using touch pad after some time of inactivity, i had to scratch on touch pad continuously then it works otherwise remain freezes. Mostly happens when i type for too long
Sometimes during moving it freezes all of the sudden and skips to the point where it should be. Or in simple words, it is freezes and skipping while moving
I am facing this problem since past week. I am using ASUS FX505GT and also i got tested from the service, touchpad is working fine in windows and is passing tests their technical team has written.
Also i checked by removing / using charger, the issue doesnt seem to be solved
Hello tbhaxor,
I’m afraid, I don’t really understand what you mean by “scratch”, could you please elaborate on that?
could you please provide the output of inxi -v 8 so that we can have a bit more info about what you are using, too?
Another thing to consider is having all of the drivers installed. Try to run:
pamac install libinput libevdev xf86-input-synaptics
Also, updating your system just in case is always a good idea, too. (pamac update)
best Regards, Julius
Rapidly move the finger on the touchpad
julius-gu:
output of inxi -v 8
System: Host: h3ll Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=55edfa0d-68e3-46c0-acb0-fcdc65111a17 rw quiet apparmor=1
security=apparmor udev.log_priority=3 snd_hda_intel.dmic_detect=0
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0 serial: <superuser/root required>
Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <superuser/root required> UEFI: American Megatrends v: FX505GT.307
date: 06/24/2020
Battery: ID-1: BAT0 charge: 30.3 Wh condition: 41.5/48.1 Wh (86%) volts: 12.6/11.7 model: Simplo SDI ICR18650 type: Li-ion
serial: 123456789 status: Charging cycles: 41
Memory: RAM: total: 15.49 GiB used: 2.10 GiB (13.6%)
PCI Slots: Permissions: Unable to run dmidecode. Root privileges required.
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: A (10) microcode: D6 L2 cache: 12.0 MiB bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia v: 450.80.02
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 1-11:2 chip ID: 13d3:56a2
serial: 0x0001
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2") s-diag: 1052mm (41.4")
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
Monitor-2: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.1 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
chip ID: 8086:a370
IF: wlo1 state: up mac: 0c:dd:24:41:19:9b
IP v4: 192.168.43.106/24 type: dynamic noprefixroute scope: global broadcast: 192.168.43.255
IP v6: 2401:4900:b98:e9dd:44f0:c96c:f62b:a077/64 type: dynamic noprefixroute scope: global
IP v6: fe80::ac4d:2c30:d747:f696/64 type: noprefixroute scope: link
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: 3000
bus ID: 02:00.0 chip ID: 10ec:8168
IF: enp2s0 state: down mac: 04:d4:c4:e4:71:fd
WAN IP: 106.202.36.212
Drives: Local Storage: total: 931.51 GiB used: 325.00 GiB (34.9%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-11Z10T0 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: WD-WX31AA7CLVNK rev: 1A01 scheme: GPT
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060 bus ID: 00:17.0
chip ID: 8086.282a rev: 10
Partition: ID-1: / raw size: 244.14 GiB size: 239.31 GiB (98.02%) used: 48.17 GiB (20.1%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 55edfa0d-68e3-46c0-acb0-fcdc65111a17
ID-2: /boot/efi raw size: 512.0 MiB size: 511.0 MiB (99.80%) used: 79.9 MiB (15.6%) fs: vfat dev: /dev/sda1
label: N/A uuid: 6BB0-A5B3
ID-3: /home raw size: 596.96 GiB size: 586.59 GiB (98.26%) used: 228.05 GiB (38.9%) fs: ext4 dev: /dev/sda3
label: N/A uuid: a7348e76-67cf-49c3-b61d-3e9915d419bd
ID-4: /opt raw size: 89.91 GiB size: 88.00 GiB (97.87%) used: 48.70 GiB (55.3%) fs: ext4 dev: /dev/sda4 label: N/A
uuid: 94aea198-a444-45df-bde2-2eb630444a24
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 7.45 GiB used: 2.1 MiB (0.0%) priority: -2 file: /swapfile
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-11:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 13d3:56a2 serial: 0x0001
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aaa
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 49.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 2400
Repos: Packages: pacman: 1606 lib: 393 flatpak: 0
1: https://repo.inara.pk/manjaro/stable/$repo/$arch
2: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
3: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
4: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
5: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
6: http://manjaro.dcc.uchile.cl/stable/$repo/$arch
7: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
8: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
Processes: CPU top: 5 of 317
1: cpu: 17.2% command: chrome pid: 37562 mem: 318.7 MiB (2.0%)
2: cpu: 17.0% command: chrome pid: 37847 mem: 192.7 MiB (1.2%)
3: cpu: 17.0% command: bash pid: 38949 mem: 23.2 MiB (0.1%)
4: cpu: 11.3% command: chrome pid: 37597 mem: 127.1 MiB (0.8%)
5: cpu: 5.5% command: xorg pid: 815 mem: 146.1 MiB (0.9%)
Memory top: 5 of 317
1: mem: 326.4 MiB (2.0%) command: plasmashell pid: 1397 cpu: 1.7%
2: mem: 318.7 MiB (2.0%) command: chrome pid: 37562 cpu: 17.2%
3: mem: 297.6 MiB (1.8%) command: baloo_file pid: 1395 cpu: 0.0%
4: mem: 293.1 MiB (1.8%) command: telegram-desktop pid: 5072 cpu: 0.8%
5: mem: 192.7 MiB (1.2%) command: chrome pid: 37847 cpu: 17.0%
Info: Processes: 317 Uptime: 3h 40m Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.08
hi,
I am also facing the same problem. I also have Asus Fx505GT. Did you find anyway to solve the issue??
Please switch to linux54. It will not solve the issue, but decreases the frequency to negligible.
If you still face issue, simply put your laptop on sleep and resume again.
Since switching to linux54 i faced this issue only 2 3 times
