Just of late after some updates (not sure which) my mouse wheel has started going really slow. When I reboot the machine the mouse wheel works at a normal speed and without any issues. After some time of not being used, just sitting next to me, ie 15-20 min, the scroll wheel speed slows right down for all interactions throughout the system. This includes web pages, scrolling in apps, and even desktop selection. If I reboot the system at this point and reorganise my desktops, the mouse scroll wheel goes back to normal speed.
I’ve the same issue as you but I didn’t found any solution for that…Did you maange to find something ?
System information?
inxi -Fanzy
Log file after the slowdown is happening?
sudo journalctl -r |more
Kernel: 6.8.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.8-x86_64
root=UUID=36cc3010-0883-414a-9fe0-06575a75da0d rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 46.0 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy avail: swaylock dm: GDM v: 46.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Dell product: G5 5500 v: N/A
Mobo: Dell model: 06P54X v: A00 serial: <superuser required> part-nu: 09E2
uuid: <superuser required> UEFI: Dell v: 1.28.0 date: 12/18/2023
ID-1: BAT0 charge: 31.9 Wh (100.0%) condition: 31.9/68.0 Wh (46.9%)
volts: 15.9 min: 15.2 model: SMP DELL 72WGV05 type: Li-poly serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: discharging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3367 high: 3603 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3600 2: 3600 3: 3602
4: 3600 5: 3600 6: 3603 7: 3598 8: 3600 9: 3601 10: 3600 11: 3600 12: 800
bogomips: 62431
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh]
vendor: Dell driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm
non-free: 545.xx+ status: current (as of 2024-02; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f14 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0c45:671f
class-ID: 0e02
Device-4: Realtek RTL2838 DVB-T driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0bda:2838
class-ID: 0000 serial: <filter>
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.5
compositor: gnome-shell driver: X: loaded: modesetting dri: iris gpu: i915
display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x05e4 built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 2 drv: swrast surfaceless:
drv: nvidia wayland: drv: iris x11: drv: iris inactive: gbm
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.4-manjaro1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 30.38 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2070 with Max-Q Design driver: nvidia v: 550.67
device-ID: 10de:1f14 surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: Intel UHD Graphics (CML GT2) driver: mesa intel
v: 24.0.4-manjaro1.2 device-ID: 8086:9bc4 surfaces: xcb,xlib,wayland
Device-1: Intel Comet Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: BEHRINGER GmbH X-Touch driver: snd-usb-audio type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:6 chip-ID: 1397:00b1
class-ID: 0103 serial: <filter>
Device-4: BEHRINGER GmbH X18/XR18 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:7 chip-ID: 1397:00d4
API: ALSA v: k6.8.4-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.4 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:2502
class-ID: 0200
IF: enp60s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 4.55 TiB used: 3.2 TiB (70.3%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WDS100T3XHC-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM13.2 temp: 37.9 C
scheme: GPT
ID-1: / raw-size: 464.96 GiB size: 464.96 GiB (100.00%)
used: 401.46 GiB (86.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:6
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 88.9 MiB (14.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 464.96 GiB size: 464.96 GiB (100.00%)
ID-4: /var/log raw-size: 464.96 GiB size: 464.96 GiB (100.00%)
System Temperatures: cpu: 64.0 C pch: 61.0 C mobo: 59.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 2407 fan-1: 2411 fan-2: 2420
Memory: total: 32 GiB note: est. available: 31.11 GiB used: 11.5 GiB (37.0%)
Processes: 459 Power: uptime: 2h 33m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.43 GiB services: gsd-power,
tool: systemctl
Packages: 2081 pm: pacman pkgs: 2015 libs: 452 tools: gnome-software,
pacaur, pamac, yay pm: flatpak pkgs: 44 pm: snap pkgs: 22 Compilers:
clang: 17.0.6 gcc: 13.2.1 alt: 12 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.33
as for the slow down, I don’t know when it happens, it’s at random
It only seems to happen if the laptop has been left idle for some time… If I keep using the laptop it doesn’t do it until I walk away for some time.
