Hello everyone . I just made a clean manjaro kde install. i’ve been experiencing issues with the mouse pointer. in some applications (like cura, or editing lattedock) just displaces itself or makes the dropdown menus dissapear, here’s a link showing the same error I get. [QTBUG-68944] QML based menus not usable under Weston - Qt Bug Tracker.
how can I fix this Issue? or just use x11? thanks
Kernel: 5.18.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=817936d5-fa8e-4deb-be17-ac813a563632 rw quiet
resume=UUID=924d80f6-f4f9-4faf-a14b-bed7812b9e4a udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_wayland vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: Nitro AN515-44 v: V1.04
serial: <superuser required>
Mobo: RO model: Stonic_RNS v: V1.04 serial: <superuser required>
UEFI: Insyde v: 1.04 date: 02/04/2021
ID-1: BAT1 charge: 19.2 Wh (44.2%) condition: 43.4/57.5 Wh (75.5%)
volts: 14.8 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: discharging
RAM: total: 15 GiB used: 2.98 GiB (19.9%)
RAM Report:
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x60 (96) stepping: 1 microcode: 0x8600103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1386 high: 1397 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1396 2: 1397
3: 1397 4: 1397 5: 1396 6: 1278 7: 1397 8: 1396 9: 1396 10: 1367 11: 1397
12: 1397 13: 1393 14: 1394 15: 1397 16: 1396 bogomips: 92656
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: NVIDIA TU117M vendor: Acer Incorporated ALI driver: nvidia
v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-3:2
chip-ID: 0408:a061 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.10-1-MANJARO)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: N/A alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.18.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.54 running: yes
Device-1: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0
chip-ID: 10ec:2600 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
Local Storage: total: 1.14 TiB used: 323.54 GiB (27.7%)
model: PC SN530 SDBPNPZ-256G-1014 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21103900 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SPZX-21Z10T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A02 scheme: GPT
ID-1: / raw-size: 221.67 GiB size: 217.13 GiB (97.95%)
used: 65.62 GiB (30.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 817936d5-fa8e-4deb-be17-ac813a563632
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 9180-D13E
ID-3: /media/guillo raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 257.93 GiB (28.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 759f8476-f3a7-4349-9c7a-f9842ff6395f
ID-1: swap-1 type: partition size: 16.5 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 924d80f6-f4f9-4faf-a14b-bed7812b9e4a
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Quanta HD User Facing type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:a061
class-ID: 0e02
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 38.0 C
Processes: 341 Uptime: 1h 45m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 alt: 11
clang: 14.0.6 Packages: apt: 0 pacman: 1406 lib: 373 flatpak: 0 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
