On start up my mouse cursor was not on screen and the mouse pad isn’t working when I click it. I’ve experienced something similar once before with the mouse and it wasn’t hardware, but don’t recall what solved it. I tried an external mouse and it worked straight away, I know it could be a hardware issue, but I want to make sure there is nothing software related before sending it to be repaired. Any thoughts?
The mouse pad, there is no cursor on screen and if I try to login by pressing the mouse pad it doesn’t react, only when I type a key on the keyboard, so that suggests the whole pad is not active or working.
I have that issue once in a while with my dell laptop since I have it… When I press ctrl + shift + f2 (or was it ctrl + alt + shift + f2 … not remember atm 100%) while booting it reloads the kernel module when the mousepad does not work and then it works again.
I think it is a kernel module + driver issue … but I did not further investigate that issue because that simple solution solves my problems. Since some kernel updates and firmeware updates a while ago I did not have this problem quite a while now.
IF laptop touchpad right click is not working on gnome
install dconf editor and go to
/org/gnome/desktop/peripherals/touchpad/click-method
disable default value which is “fingers” and choose custom value “areas”
If this your problem or maybe I did not understand correctly.
So I have updated the kernel and tried manually loading the driver. Currently trying to update the bios/firmware, but that’s a bit more involved as Starlabs have their own custom versions of things like fwupd. Any other ideas I can try while waiting for their support to get back to me?
Not sure of their bios, but normally you should be able by flashing the bios with a simple usb stick where you put the update on. - Further I would also receommend to make a full update and clean your system of all orphaned and old files and dependencies not needed any longer - BEFORE - you flash your bios.
Also make shure that you do not blow your system and get a safe-copy of your most important files not to risk any total loss of all your files and so on.
