Mouse in GDM very slow
Hello Friends,
I’m facing a specific issue with the GNOME (GDM) login screen. The mouse movement is extremely slow and unresponsive. After logging in, the mouse behavior returns to normal, working correctly in the desktop environment.
Has anyone experienced this or knows how I can change this mouse acceleration?
Thanks
I solved my problem using the command below.
sudo -u gdm dbus-launch gsettings set org.gnome.desktop.peripherals.mouse speed '0.9'
