I recently started using qemu/kvm for vms and instantly noticed that performance wasn’t that great So I looked online to see what I can do to improve the performance inside the vms. I saw that turning on 3D acceration and OpenGL gets better performance. And I did. Except the mouse is very glitchy.
For example, inside a vm, if I move the cursor to a corner of a window, then it takes the shape of resize window. Which is expected. But then when I move the cursor away from the corner then it keeps that shape of resize window for some reason. Then cursor turns normal after a while. Same thing happens if I hover my cursor over a link. It takes the shape of a pointing index finger. Which is expected but when I move it away from the link, it keeps the shape of the pointing index finger. This issue is there in Debian XFCE4 vm but not in Debian GNOME vm.
Tried looking online but I couldn’t find anything related to my issue. Any help?
Edit: here’s what I mean
Olli
22 November 2023 18:10
2
hello @temegec14
may you post the mandatory
to see some infos like cpu, used governor etc… what type of mouse are you using ? usb, bluetooth, wired ? a bluetooth-mice and vm might cause issues.
i’m not sure if using opengl and 3d-acceleration is really helping or just minimizing the issue. but let’s see what inxi tells.
p.s.: what os’es are you using in your vm’s ?
hello @Olli thx for your response.
here’s the outout.
Kernel: 5.15.138-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9ac9639f-b7a3-4f1c-9c4b-3d1b7c06f60f rw quiet splash apparmor=1
security=apparmor resume=UUID=c2fe50c4-8036-4618-be86-5285ebe9e781
udev.log_priority=3
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 01HV08 v: A00 serial: <superuser required> UEFI: Dell
v: 2.9.0 date: 01/17/2019
ID-1: BAT0 charge: 33.7 Wh (81.8%) condition: 41.2/44.4 Wh (92.7%)
volts: 16.0 min: 14.8 model: LGC-LGC2.80 DELL 7PY0D type: Li-ion
serial: <filter> status: discharging
System RAM: total: 24 GiB available: 23.35 GiB used: 13.7 GiB (58.7%)
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF4
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2983 high: 3096 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3094 2: 3096 3: 3093
4: 2651 bogomips: 21607
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1
off: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0bda:5769
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: Acer V227Q H serial: <filter> built: 2023
res: 1920x1080 dpi: 102 gamma: 1.2 size: 476x267mm (18.74x10.51")
diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 model: AU Optronics 0x71ec built: 2016 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
API: ALSA v: k5.15.138-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.85 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF-ID-1: virbr0 state: up speed: 10 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet11 state: unknown speed: 10 Mbps duplex: full mac: <filter>
IP v6: <filter> scope: link
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 0cf3:e009
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 167.75 GiB (36.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C3
dev-links: cdrom
ID-1: / raw-size: 334 GiB size: 327.69 GiB (98.11%) used: 167.72 GiB (51.2%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 9ac9639f-b7a3-4f1c-9c4b-3d1b7c06f60f
used: 27.8 MiB (29.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: F241-AA15
ID-1: swap-1 type: partition size: 12.21 GiB used: 7.6 MiB (0.1%)
priority: -2 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: c2fe50c4-8036-4618-be86-5285ebe9e781
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 118.48 GiB fs: ntfs label: N/A
uuid: D4BC42C5BC42A1BA
ID-3: /dev/sda6 maj-min: 8:6 size: 488 MiB fs: vfat label: N/A
uuid: 989C-4122
ID-4: /dev/sda7 maj-min: 8:7 size: 499 MiB fs: ntfs label: N/A
uuid: 141080BF1080A976
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:6 info: MosArt 2.4G Keyboard Mouse type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:5918 class-ID: 0301
Device-2: 1-5:3 info: Realtek Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:5769 class-ID: 0e02 serial: <filter>
Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-4: 1-8:5 info: Qualcomm Atheros type: bluetooth driver: btusb
power: 100mA chip-ID: 0cf3:e009 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 59.0 C pch: 52.5 C mobo: 52.0 C
Fan Speeds (rpm): cpu: 0
Processes: 293 Uptime: 21h 8m wakeups: 1 Init: systemd v: 254
Packages: 1808 pm: dpkg pkgs: 0 pm: pacman pkgs: 1754 libs: 464
tools: gnome-software,pamac,yay pm: rpm pkgs: 0 pm: appimage pkgs: 0
pm: flatpak pkgs: 41 pm: snap pkgs: 13 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.31
Weirdly, the mouse issue is only there when I enabled 3D acceleration and opengl.
I’m using Debian 12 XFCE4 and Debian 12 Gnome in my VMs. The issue is in only XFCE4 edition for some reason.
Olli
22 November 2023 18:33
4
the first issue:
before using a vm change the cpu-speed manually to performance, otherwise it’s terrible experience.
https://wiki.archlinux.org/title/Scaling_governor
well, your cpu isn’t a monster for vm’s
second: check the xfce4 edition if it is using wayland or x11.
third:
check if you create a new vm from iso the following: usually a linux-installer asks you if you wanna use open or propietary drivers for the gpu.
if you choose propietary-driver they will/should install the RedHat-Virtio-display-driver that is excellent.
Changing the CPU governor to performance didn’t help. Issue is still there.
Debian XFCE4 is using x11.
Using debian’s default installer doesn’t ask whether to install open source or proprietary drivers. So by default it installs everything open source.
Olli
22 November 2023 19:31
6
your RAM-size is good but as said your cpu isn’t that kind of thing to run a vm. however, can you try to create a manjaro-vm and choose the propietary driver at the beginning of the installation. afterwards check that the red-hat-display-driver is usable in the display-size-settings. if you setup this vm use just the default-settings of kvm/virt-manager, they work fine with it.
I don’t think it’s a cpu related issue as videos and games runs very smoothly under vm. Might be a missing driver issue as you pointed it out.
Fyi, here’s the screenshot of the issue:
Yes, I can reproduce your problem, even with Manjaro or any other Distro. It is rather a problem of the spice server inside the VM, which renders/encodes the virtual screen and you see it on the spice client. It renders the cursor separately and sometimes it cannot catch the cursor properly due the layer latency, I suppose.
If you need acceleration on the VM and when the Host GPU is at least Intel Broadwell, then take look at Intel GVT-g: Intel GVT-g - ArchWiki But note that it will disable Hardware Accelerated Video Decoding in favor of a GPU pass-through.
First off, really appreciate you for reproducing the phenomenon I’m experiencing.
Second, glad I’m not the only one experiencing this
and finally, will defo take a look at attached link and give it a try.
Tysm again!
