Hello, i installed manjaro linux xfce4 basic installation and after i use 30 minutes mouse cursor starts loading (the loading cursor icon) and dont stop, it has been 2 hours and the mouse cursor still loading, i customized a bit my task bar but i don’t think a taskbar can have any issue with my mouse cursor. The cursor only appears when i move my cursor into taskbar and desktop. On applications it’s normal
Similar issue here. Changing the cursor resets the mouse cursor to the state it should be in, but it still occurs later. I was able to trigger this consistently by looking inside a .zip (an icon pack from xfce-look) in Engrampa Archive Manager. May be worth checking to see if any bug reports have been made upstream to XFCE.
