I just updated the Manjaro install on my Thinkpad L13 Yoga Gen2. Since the update I have the issue that the mouse cursor sporadically (actually quite frequently) jumps to the left screen edge. If I try to move it back to the right, it is sometimes like somebody is fighting me and tries to move it to the left again.
Some further infos:
I have deactivated the touchpad and only use the trackpoint
I tried to switch to an older kernel (5.15 to be more precise) with no effect
The problem also appears in the Bios menu. Looks like the linux-firmware update is the problem. But downgrading it to the previous version didn’t solve the issue. So far, the only workaround was to deactivate the trackpoint and activate the touchpad, but I absolutely hate using the touchpad and would love to get my trackpoint back, so yeah…
Is it this one ?
Please provide some info, you are long enough around here.
Does it also happen with a live system (try manjaro, you may also try ubuntu) ?
Well, it happens in the BIOS menu, as I stated in my previous post, so it will for sure happen with a live system as well. I assume that the linux-firmware update messed up something…
The info about your device is sparse as far as linux is concerned.
There are hacks, but only for other models. You should look in /var/log/messages for psmouse and trackpoint entries, maybe… but all speculation, without system info.
Some links:
I can provide whatever system info is necessary, just let me know what it is. I assume that hardware like CPU, RAM or hard disk space is irrelevant here, that’s why I haven’t provided information about it. Here’s my inxi -F if it helps anyhow:
I contacted Lenovo support and they immediately told me to send it in for repair (not my intention initially) since I have still some warranty left on it. In case that they are not able or willing (it’s Linux) to solve the problem, I’ll try the firmware/bios update, thanks for the proposal! In any case I’ll report back how the story went on!
This is annoying, but a safe option. Wish you good luck.
Edit:
…nevertheless, fwupd, or gnome-firmware is a must.
That’s why people buy Thinkpads, even though it’s always been a bit more expensive to have good taste.
As far as I remember I did some firmware updates in the first few days after getting it, but looks like I didn’t keep up with new versions (or just missed the actual BIOS firmware, but I am sure that I did install some firmware related stuff).
Update: I got the laptop back and according to the repair report they exchanged everything (PCB, that is, the motherboard, and the keyboard&trackpoint combination). The cause was an electric damage.
However, I’m a bit afraid of running the linux-firmware update now, possibly it will brick the device again. But I cannot fix the linux-firmware version on the long run, too, right?
In the mean time I noticed that the stylus isn’t being charged after the repair (it’s shown to be at 0% and also doesn’t work), so it looks like I will have to send it in again anyway…
