Hi!
Since upgrading my system yesterday (including a move from kernel 5.11 to 5.12), I’ve had a recurring issue where, now and then when I move my mouse, the cursor will suddenly “jump” to my second monitor; It just disappears from the main monitor, and appears in roughly the same spot on the second monitor (which is a pen display, but the pen isn’t placed anywhere near where the cursor appears). The monitors have different resolutions, but it’ll still appear in the same relative position to the edges. On top of that, I’ve been experiencing more mouse lag than usual. At first I suspected it might be low battery on my mouse (it’s a Logitech M705 “Marathon Mouse”), but switching the batteries didn’t seem to do much. I tried using an old wired mouse and it doesn’t seem to happen then, which would suggest an issue with the wireless connection, the mouse itself, or the Logitech Unifying Receiver. I tried monitoring both mice with xinput test
, and at first it looked like the wireless mouse stopped acting up while it was running, but after a few minutes it started happening again.
Anyone got any ideas what might be going on?
Here is the output of `inxi --admin --verbosity=7 --filter --no-host --width`:
~ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=88385d1a-f8d9-442b-bd5e-59038c49c640 rw quiet
cryptdevice=UUID=545675cd-3ec2-4adc-930e-e111cee266b9:luks-545675cd-3ec2-4adc-930e-e111cee266b9
root=/dev/mapper/luks-545675cd-3ec2-4adc-930e-e111cee266b9
resume=/dev/mapper/luks-545675cd-3ec2-4adc-930e-e111cee266b9
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <filter>
UEFI: American Megatrends v: P1.60 date: 11/05/2018
Device-1: hidpp_battery_0 model: Logitech M705 serial: <filter> charge: 100%
rechargeable: yes status: Discharging
RAM: total: 31.36 GiB used: 10.3 GiB (32.9%)
Info: 8-Core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001137 cache: L2: 4 MiB
bogomips: 108608
Speed: 2801 MHz min/max: 2200/3400 MHz boost: enabled Core speeds (MHz):
1: 2801 2: 2231 3: 1885 4: 1882 5: 1882 6: 1882 7: 1926 8: 1883 9: 1770
10: 1790 11: 1736 12: 1719 13: 1744 14: 1732 15: 1882 16: 1888
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 23:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 5011x3240 s-dpi: 96 s-size: 1326x857mm (52.2x33.7")
s-diag: 1579mm (62.2")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60
Monitor-2: HDMI-0 res: 3840x2160 hz: 60 dpi: 163
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 23:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 25:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:6 chip-ID: 08bb:2902
class-ID: 0300
Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.26 running: yes
vendor: ASRock driver: r8168 v: 8.048.03-NAPI modules: r8169 port: f000
bus-ID: 1f:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp31s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-3:4 chip-ID: 0a12:0001 class-ID: e001
Device-1: luks-7a1f7633-49b3-4723-bf4c-82dcc1cd5a9c maj-min: 254:1
type: LUKS dm: dm-1 size: 931.51 GiB
Components:
p-1: sda maj-min: 8:0 size: 931.51 GiB
Device-2: luks-545675cd-3ec2-4adc-930e-e111cee266b9 maj-min: 254:0
type: LUKS dm: dm-0 size: 237.96 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 237.97 GiB
Local Storage: total: 6.6 TiB used: 2.77 TiB (42.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: R0906I scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
rotation: SSD serial: <filter> rev: 4B6Q
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000528AS
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC3E scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Expansion Desk
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B serial: <filter>
rev: 0909 scheme: GPT
ID-1: / raw-size: 237.96 GiB size: 233.23 GiB (98.01%)
used: 185.4 GiB (79.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-545675cd-3ec2-4adc-930e-e111cee266b9 label: N/A
uuid: 88385d1a-f8d9-442b-bd5e-59038c49c640
used: 13.9 MiB (2.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 08EA-C1F1
ID-3: /mnt/126c42d1-afff-41f1-8331-afb0049be8e3 raw-size: 931.51 GiB
size: 916.77 GiB (98.42%) used: 623.64 GiB (68.0%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: HDD Secrets uuid: 126c42d1-afff-41f1-8331-afb0049be8e3
ID-4: /run/media/william/Seagate Expansion Drive raw-size: 4.55 TiB
size: 4.55 TiB (100.00%) used: 1.36 TiB (29.8%) fs: ntfs dev: /dev/sdc2
maj-min: 8:34 label: Seagate Expansion Drive uuid: C06C77346C7723F6
ID-5: /run/timeshift/backup raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 640.61 GiB (68.8%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-7a1f7633-49b3-4723-bf4c-82dcc1cd5a9c label: SATA SSD
uuid: 1b9b0e8f-47e7-4be0-9bd2-500975d6a425
ID-1: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
Device-1: 1-5:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-6:3 info: Holtek USB-HID Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 04d9:a131 class-ID: 0300
Device-1: 2-2:2 info: Seagate RSS LLC Desktop HDD 5TB (ST5000DM000)
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 8mA chip-ID: 0bc2:331a class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:6 info: Texas Instruments PCM2902 Audio Codec type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 08bb:2902 class-ID: 0300
Device-2: 3-2:5 info: Tablet Monitor type: Mouse driver: uclogic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006e
class-ID: 0301
Device-3: 3-3:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 45.5 C mobo: 0 C gpu: nvidia temp: 56 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 498 Uptime: 23h 23m wakeups: 404 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1829
pacman: 1815 lib: 455 flatpak: 0 snap: 14 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.04
