Hi, I’m on a fresh install of Manjaro GNOME and I’ve installed RStudio. I’m on a DELL XPS 15 7590.
I’ve noticed that when I’m in RStudio the mouse cursos becomes very small when it changes from “arrow” to “finger pointing”. The issue doesn’t happen with other qt apps, as far as I’ve seen. The strange thing is that cursor size is ok except for that particular cursor type. It must be something about resolution (it’s an ultra hd display) but I can’t see why it happens with just one cursor.
Further information: when the “finger pointing” cursor appears, it’s white, but it should be black following the global cursor theme (Xcursor-breeze). So it looks like RStudio is using a wrong cursor, which happens to ben badly scaled.
The error message that I get when I open RStudio in a terminal is:
QApplication: invalid style override passed, ignoring it.
Available styles: Windows, Fusion
But setting one of those styles with rstudio-bin -style Fusion
or rstudio-bin -style Windows
doesn’t change anything.
Info on my system here:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=e6c4e28c-1714-4aa0-8378-71e34489645d ro quiet
cryptdevice=UUID=558055a3-e71d-4692-926f-516ae14a27c3:luks-558055a3-e71d-4692-926f-516ae14a27c3
root=/dev/mapper/luks-558055a3-e71d-4692-926f-516ae14a27c3 splash apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 15 7590 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 018W12 v: A06 serial: <filter> UEFI: Dell v: 1.9.1
date: 12/14/2020
ID-1: BAT0 charge: 67.1 Wh condition: 95.9/97.0 Wh (99%) volts: 12.1/11.4
model: LGC-LGC8.33 DELL 5XJ280A type: Li-ion serial: <filter>
status: Unknown
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 12 MiB
bogomips: 62431
Speed: 1648 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 1648 2: 903
3: 1614 4: 910 5: 1577 6: 1638 7: 960 8: 1033 9: 1070 10: 1476 11: 1606
12: 1487
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 460.32.03
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-12:4 chip ID: 0c45:6723
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 vendor: Bigfoot Networks driver: iwlwifi
v: kernel port: 3000 bus ID: 3b:00.0 chip ID: 8086:2723
IF: wlp59s0 state: up mac: <filter>
Local Storage: total: 476.94 GiB used: 85.12 GiB (17.8%)
model: PC SN730 NVMe WDC 512GB size: 476.94 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 11121012
temp: 33.9 C
ID-1: / raw size: 355.94 GiB size: 349.36 GiB (98.15%)
used: 85.12 GiB (24.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-558055a3-e71d-4692-926f-516ae14a27c3
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 496 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-1: swap-1 type: file size: 10 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2384 fan-2: 2402
Processes: 350 Uptime: 12m wakeups: 1951 Memory: 15.28 GiB
used: 5.99 GiB (39.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1311 pacman: 1301 lib: 390 flatpak: 7 snap: 3 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.2.02
