I have an encrypted secondary drive for storage in my machine that I have been using in this setup for over a year without issue. I made an ownership change trying to fix a permissions issue for a NAS shared folder…
sudo chown -R myuser:myuser /mnt/SF
I then attempted to log off the user session but my machine got stuck so after waiting, I did a hard reboot.
I then encountered the following error that stopped my system from booting…
[FAILED] Failed to mount /media/ssd
[DEPEND] Dependency failed for Local File Systems.
I was able to login to the command line with my root password, and amend my fstab to comment out the line causing the error, the last line…
file system mount point type options dump pass
UUID=4824-2933 /boot/efi vfat umask=0077 0 2
/dev/mapper/luks-bc99384c-29c6-556d-9f19-97d92b0b883a / ext4 defaults,noatime 0 1
/dev/mapper/luks-4ea2cd3f-8824-23d9-a1a4-cb6b74c02144 /media/ssd ext4 rw,user,exec 0 0
I was then able to reboot and log into the KDE desktop. In the file explorer, Dolphin, the secondary drive appears under Devices but when I click it I get this error…
An error occurred while accessing ‘ssd’, the system responded: The requested operation has failed: Error mounting /dev/dm-1 at /run/media/myuser/ssd: can’t read superblock on /dev/mapper/luks-4ea2cd3f-8824-23d9-a1a4-cb6b74c02144
I didn’t knowingly make any changes to the encrypted drive so I don’t understand why it stopped mounting.
Make a full copy as is of sdd onto another drive to ensure that if anyone asks you to do anything you can still revert the change.
What’s the output of the following commands running as root:
parted --list
smartctrl --all /dev/sdd
(I’m on shaky waters here as I know a lot about disks and superblocks but don’t do full drive encryption. *I sincerely hope you have an unencrypted backup of your drive!)
I forgot that before the issue started, I tried to log out of my user session which resulted in a black screen and seemed to be stuck. I waited a while and then did a hard reboot. I presume I interrupted a process that caused the issue. I have edited the original post accordingly.
To fix the issue, I went into the KDE Partition Manager GUI, selected the device, right clicked on the partition, and ran the Check process And that fixed the issue!
This is the output I received:
Check and repair partition ‘/dev/sda1’ (931.51 GiB, ext4)
Job: Check file system on partition ‘/dev/sda1’
Command: e2fsck -f -y -v /dev/mapper/luks-4ea2cd3f-8824-23d9-a1a4-cb6b74c02144
e2fsck 1.45.6 (20-Mar-2020)
SSD: recovering journal
JBD2: Invalid checksum recovering block 60293235 in log
Journal checksum error found in SSD
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Block bitmap differences: +26705922 +26705924 +(26705926--26705927) [... I have omitted a large amount of text here]
Fix? yes
>SSD: ***** FILE SYSTEM WAS MODIFIED *****
102214 inodes used (0.17%, out of 61054976)
1303 non-contiguous files (1.3%)
70 non-contiguous directories (0.1%)
# of inodes with ind/dind/tind blocks: 0/0/0
Extent depth histogram: 101646/538
43977913 blocks used (18.01%, out of 244189696)
0 bad blocks
2 large files
80773 regular files
21397 directories
0 character device files
0 block device files
0 fifos
0 links
35 symbolic links (22 fast symbolic links)
0 sockets
102205 files
Check file system on partition ‘/dev/sda1’: Success
Job: Maximise file system on ‘/dev/sda1’ to fill the partition
The file system on partition ‘/dev/sda1’ already has the requested length of 1,953,521,664 sectors.
Maximise file system on ‘/dev/sda1’ to fill the partition: Success
Check and repair partition ‘/dev/sda1’ (931.51 GiB, ext4): Success
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
(as that makes both our lives much easier)
No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
