Hi everyone!
I have an external USB HDD mounted in my /etc/fstab
. I use that external drive daily. For some reason, whenever my computer goes idle Linux is unmounting that HDD. This is a pretty big problem, because I use a service that stores data in it from time to time and, sometimes, when it tries to do during night (when I’m sleeping) it simply can’t since the driver is not mounted anymore.
During day, while I’m using the computer, the driver is mounted as expected. But, as soon as I leave my chair for a few minutes, when I go back to the computer the driver is not mounted anymore.
I’m using Gnome DE and I’ve already changed the Power > Automatic Suspend
settings to Off
Also, I’ve changed the /sys/bus/usb/devices/usb4/4-3/power/control
from auto
to on
I’ve also tried to change my /etc/udev/rules.d/50-usb_power_save.rules
file to the following:
ACTION=="add", SUBSYSTEM=="usb", ATTR{idVendor}=="0bc2", ATTR{idProduct}=="231a", TEST=="power/control", GOTO="power_usb_rules_end"
ACTION=="add", SUBSYSTEM=="usb", TEST=="power/control", ATTR{power/control}="auto"
LABEL="power_usb_rules_end"
And my /etc/udev/rules.d/usb-power.rules
to the following:
ACTION=="add", SUBSYSTEM=="usb", ATTR{idVendor}=="0bc2", ATTR{idProduct}=="231a", TEST=="power/control", ATTR{power/control}="on"
But it seems that none of those approaches worked.
