Nothing will be mounted automatically, except when plug in a USB Flash Drive. Any internal partition wonβt by default. The file manager will just offer a one-click mount.
If you rely on file-manager, then take a look at udisks2ctl
. You can add it to the autostart of the desktop environment and it will auto-mount it right away. Something like:
# Pretty rough, will print errors and skip if not possible
find /dev -maxdepth 1 -type b -exec udisksctl mount --block-device "{}" \;
or
find -L /dev/disk/by-label/ -type b -exec udisksctl mount --block-device "{}" \;
find -L /dev/disk/by-uuid/ -type b -exec udisksctl mount --block-device "{}" \;
It will automatically mount every possible device. Just create a desktop file and put it in ~/.config/autostart/
. Something like:
File: ~/.config/autostart/user-autmount.desktop
[Desktop Entry]
Name=User-Automount
Comment=Search and automount every possible drive after graphical user login
Exec=bash -c 'find -L /dev/disk/by-uuid/ -type b -exec udisksctl mount --block-device "{}" \;'
Type=Application
Terminal=true
StartupNotify=true
NoDisplay=true
A systemd unit is also possible:
File: ~/.config/systemd/user/user-automount.service
[Unit]
Description=Search and automount every possible drive after graphical user login
[Service]
ExecStart=/usr/bin/bash -c '/usr/bin/find -L /dev/disk/by-uuid/ -type b -exec udisksctl mount --block-device "{}" \;'
Type=simple
[Install]
WantedBy=default.target
Then enable it:
systemctl --user enable user-automount.service
systemctl --user start user-automount.service
I know you can do it more advanced with templates etc., but at least that is just one command and one file and no root permissions are needed for configuration and running.
Not tested by me, it is a rough template. Adjust it to your needs.
