I would like to mount an ISO file as the System does it when I double click on that.
In this case I can see an icon with name on my desktop of it, and I can access the content of that.
What would be the proper terminal command to achieve the same state?
I believe mount points in /media and /mnt are automatically added to most file managers’ side panel, and thus should also show on the desktop if the associated setting is enabled.
Otherwise there may be an option to add for Cinnamon/Nemo to add the mount to the desktop, wherever the mount folder is.
I checked Nemo, and my mounted ISO can’t see on the side panel.
Could you give the information what is the associated setting? Just to enable that.
And just reminder, i am searching for a terminal command. If that is exist…
