I was having problem installing Grand Theft Auto San Andreas Via direct setup so i downloaded a iso file, extracted it and install. Installation went smoothly. But when i run Grand Theft Auto San Andreas from Menu it says cd not found. Hence it needs to iso to be used as a cd to start.
If anyone Knew how to mount an iso as a cd then please help me.
It needs to be mount for wine too(i think so) or wine reads mounted devices directly from linux?
sudo mount -t auto /path/to/iso /path/where/you/want/it -o loop,uid=1000
For more information, see…
man mount
wine is only a translation layer, not a virtual machine. It has access to whatever the underlying system has access, provided that the permissions on the mountpoint allow it.
Hey, Thanks for the reply i tried this but it didn’t work, but its GtaSa i can’t leave this game so i find a way to start it. The Fault was in its executable file (gta_sa.exe) it was the one asking for its dvd, so i downloaded a executable file for pc and BOOYAH!! it worked. Thanks
