As of today’s Manjaro snapshot, I can no longer find the motherboard temperature sensors in the KDE system monitor, though other temperature sensors still show up. For my motherboard (PRIME X370-PRO) they were called tctl and tdie. I’ve reran sensors-detect but this doesn’t fix the situation. Anyone know where they might have gone? I’m now on kernel 5.13.1-3-MANJARO if this is important.
What is the output of sensors
in terminal?
nvme-pci-0100
Adapter: PCI adapter
Composite: +55.9°C (low = -273.1°C, high = +84.8°C)
(crit = +84.8°C)
Sensor 1: +55.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +56.9°C (low = -273.1°C, high = +65261.8°C)
amdgpu-pci-0a00
vddgfx: 1.04 V
fan1: 178 RPM (min = 0 RPM, max = 6000 RPM)
edge: +65.0°C (crit = +104000.0°C, hyst = -273.1°C)
power1: 58.13 W (cap = 208.00 W)
k10temp-pci-00c3
Tctl: +62.2°C
Tdie: +62.2°C
Tccd1: +53.2°C
So they’re still there, not an issue with the sensors being dropped by the system. Something must be up with the new Plasma 5.22 causing them not to be listed.
