Hello, I installed mosquitto (version 2.0.8 which is the latest) and enabled auto start with sudo systemctl enable mosquitto.service.
However, it fails to start automatically after reboot with this error:
systemctl status mosquitto
● mosquitto.service - Mosquitto MQTT Broker daemon
Loaded: loaded (/usr/lib/systemd/system/mosquitto.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2021-03-26 12:01:14 CET; 48s ago
Process: 638 ExecStart=/usr/bin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 638 (code=exited, status=1/FAILURE)
mar 26 12:01:14 nas systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
mar 26 12:01:14 nas systemd[1]: Stopped Mosquitto MQTT Broker daemon.
mar 26 12:01:14 nas systemd[1]: mosquitto.service: Start request repeated too quickly.
mar 26 12:01:14 nas systemd[1]: mosquitto.service: Failed with result 'exit-code'.
mar 26 12:01:14 nas systemd[1]: Failed to start Mosquitto MQTT Broker daemon.
It is not really helpful, is it?
If I start it manually with sudo systemctl start mosquitto.service it works.
Can you please help me to debug this problem? Could it be something permission-related?
Thanks,
Andrea
EDIT
I tried running the unit’s command and it appears to work correctly: sudo -u mosquitto /usr/bin/mosquitto -c /etc/mosquitto/mosquitto.conf. It starts and I am able to see connections and publish messages.
Permissons look also good, at least to me:
sudo ls -als /etc/mosquitto/
4 drwxr-xr-x 2 mosquitto root 4096 23 mar 14.47 .
4 drwxr-xr-x 74 root root 4096 23 gen 2013 ..
4 -rw-r--r-- 1 mosquitto root 230 6 mar 15.55 aclfile.example
40 -rw-r--r-- 1 mosquitto root 39393 22 mar 10.01 mosquitto.conf
40 -rw-r--r-- 1 mosquitto root 39196 6 mar 15.55 mosquitto.conf.pacnew
4 -rw-r--r-- 1 mosquitto root 23 6 mar 15.55 pskfile.example
4 -rw-r--r-- 1 mosquitto root 355 6 mar 15.55 pwfile.example
4 -rw-r--r-- 1 mosquitto root 743 17 mar 20.16 secret
Done, thanks. However, files were pretty much identical. mosquitto -v -c /etc/mosquitto/mosquitto.conf gives:
1616771087: mosquitto version 2.0.8 starting
1616771087: Config loaded from /etc/mosquitto/mosquitto.conf.
1616771087: Opening ipv4 listen socket on port 1883.
1616771087: mosquitto version 2.0.8 running
1616771091: New connection from 192.168.1.85:54253 on port 1883.
It is working if started manually (with or without systemd), so maybe @Dulbi is right and dependencies might cause this issue.
sudo systemctl edit mosquitto.service
# Add following lines to override default restart behaviour:
[Service]
Restart=always
RestartSec=15
StartLimitInterval=150
StartLimitBurst=8
So basically, restarting the service for a longer time seems to fix my issue.
This is not the best way to work it out, but it works. I honestly don’t have any more time to properly fix this.
It looks like a dependency problem after all, as @Dulbi suggested.
Thanks for your time anyway.
Seems like I had an issue a while back with a service not starting when it involved network.target (which I never found). I changed to NetworkManager.service and the service started working.
Try changing in the .service file:
Requires=network.target
To: After=NetworkManager.service
