After one of the last updates, I’ve noticed that morc_menu doesn’t start. From the terminal, I have the following:
$ morc_menu
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 3 (X_GetWindowAttributes)
Resource id in failed request: 0x7e
Serial number of failed request: 7
Current serial number in output stream: 8
categorized menu:
response =
executable =
$morc_menu --version
morc_menu
Version 1.0, 2016-03-18
Copyright ©2016 Boruch Baum
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
$uname -r
6.6.84-1-MANJARO
The current version in the official repositories is;
pacman -Ss morc_menu:
extra/morc_menu 1.0+3+g2d89cb6-1
Categorized desktop application menu
If you have installed it via the AUR, perhaps the version is older, and no longer compatible. Removing it and installing the repo version might help.
Beyond that, I have nothing to add.
It works here - the first time I heard about it.
Installed in my Xfce4 VM to test and see.
Perhaps some optional dependency is missing or gets in the way?
I’d back up ~/.config/morc_menu and restore from /etc/skel
cp /etc/skel/.config/morc_menu_v1.conf ~/.config/morc_menu
or compare the two, at least.
Here is what the installation looked like:
sudo pacman -S morc_menu
resolving dependencies...
Packages (2) dmenu-5.3-3 morc_menu-1.0+3+g2d89cb6-1
Total Installed Size: 0.15 MiB
(2/2) checking keys in keyring [################################################################] 100%
(2/2) checking package integrity [################################################################] 100%
(2/2) loading package files [################################################################] 100%
(2/2) checking for file conflicts [################################################################] 100%
(2/2) checking available disk space [################################################################] 100%
(1/2) installing dmenu [################################################################] 100%
(2/2) installing morc_menu [################################################################] 100%
error: command failed to execute correctly
Optional dependencies for morc_menu
dmenu-manjaro: Support for mouse, xft fonts and menu placing
rofi: Alternative frontend
rootmenu: Spawn menu by clicking desktop
wmutils: Spawn menu on cursor
xdotool: Spawn menu on cursor
zenity: Alternative frontend [installed]
(1/1) Arming ConditionNeedsUpdate...
It’s not in AUR or in the Arch package repos - only in Manjaro repos.
I’ll take your word for it, I didn’t check.
As indicated, the versions did seem different, thus the suggestion.
I’ve diffed the config file and there are no changes. I have the correct version installed:
$pacman -F morc_menu
extra/morc_menu 1.0+3+g2d89cb6-1 [installed]
usr/bin/morc_menu
$pacman -Qi morc_menu
Version : 1.0+3+g2d89cb6-1
Description : Categorized desktop application menu
Architecture : any
URL : https://github.com/Boruch-Baum/morc_menu
Licenses : GPL-3.0-or-later
Groups : None
Provides : None
Depends On : bash dmenu
Optional Deps : dmenu-manjaro: Support for mouse, xft fonts and menu
placing [installed]
rofi: Alternative frontend [installed]
wmutils: Spawn menu on cursor [installed]
xdotool: Spawn menu on cursor [installed]
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 102.28 KiB
Packager : Mark Wagie <mark@manjaro.org>
Build Date : Thu 13 Jun 2024 03:23:08 AM CEST
Install Date : Fri 12 Jul 2024 08:10:15 AM CEST
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
$pacman -Q dmenu-manjaro rofi rootmenu wmutils xdotool zenity
dmenu-manjaro 5.3-1
rofi 1.7.8-2
error: package 'rootmenu' was not found
wmutils 1:1.7-1
xdotool 3.20211022.1-2
zenity 4.1.90-1
[edit] dmenu-manjaro was updated on 2025-03-31 so maybe that broke things. Other optional packages I’ve installed sufficiently long ago that they must not have impact on this.
That may be. Or not.
I didn’t install that one - it is an optional dependency.
… see my post - expand the
I was suggesting to diff the config file - not the binary /usr/bin/morc_menu
Yes, I diffed the config ofc.
You have installed all the optional dependencies with the exception of rootmenu
I installed none of those.
(correction: I had zenity already installed prior to this)
Perhaps some of these - as they are labelled as Alternative frontend - are not working well together?
This is pure speculation - I didn’t install those when I tried this quite elegantly looking program.
It simply worked for me and I was guessing that your config file could be at fault.
I have no further ideas.
In terms of dependencies, xdotool and wmutils I’ve had for quite some time and looking at the install dates there were no recent updates. Rofi was updated last month, so I can also eliminate it. The only items left standing are dmenu-manjaro, which depends on manjaro-i3-settings which was also recently updated.
$pactree -r dmenu-manjaro
dmenu-manjaro
├─manjaro-i3-settings
└─morc_menu
$pacman -Qi dmenu-manjaro
Version : 5.3-1
Description : Customized recency-aware dmenu for manjaro-i3 with
xft- and mouse-support
Architecture : x86_64
URL : https://tools.suckless.org/dmenu
Licenses : MIT
Groups : i3-manjaro
Provides : dmenu dmenu-xft
Depends On : coreutils fontconfig freetype2 glibc
libfontconfig.so=1-64 libx11 libxinerama libxft
noto-fonts sh
Optional Deps : None
Required By : manjaro-i3-settings morc_menu
Optional For : i3-wm morc_menu
Conflicts With : dmenu dmenu-xft
Replaces : None
Installed Size : 58.97 KiB
Build Date : Sun 23 Mar 2025 07:54:32 PM CET
Install Date : Mon 31 Mar 2025 10:03:35 AM CEST
Install Reason : Installed as a dependency for another package
$ pacman -Qi manjaro-i3-settings
Version : 1:20230912-1
Description : Manjaro Linux i3 settings
Architecture : any
URL : https://gitlab.manjaro.org/profiles-and-settings/desktop-settings
Groups : i3-manjaro
Provides : manjaro-desktop-settings
Depends On : adapta-maia-theme conky-i3 dmenu-manjaro dunst
gsfonts i3-default-artwork i3exit i3-scripts
i3-scrot i3-gaps i3-help i3status
manjaro-base-skel ttf-terminus-nerd nitrogen
papirus-maia-icon-theme picom urxvt-perls
xcursor-breeze xorg-fonts-misc xorg-mkfontscale
xorg-xset
Optional Deps : artwork-i3: Manjaro-i3 wallpapers [installed]
manjaro-backgrounds: Collection of Manjaro wallpapers
Required By : None
Optional For : None
Conflicts With : manjaro-desktop-settings
Replaces : manjaro-i3-settings-dev
Installed Size : 109.29 KiB
Build Date : Sun 23 Mar 2025 11:57:36 PM CET
Install Date : Mon 31 Mar 2025 10:04:36 AM CEST
Install Script : No
$inxi -zv8
Kernel: 6.6.84-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.6-x86_64
root=UUID=6bb0f422-04df-45b8-953c-2d25b8276f0a rw quiet apparmor=1
Desktop: i3 v: 4.24 with: i3bar tools: xautolock avail: i3lock vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P8P67 PRO v: Rev 1.xx
BIOS: American Megatrends v: 3207 date: 04/13/2012
System RAM: total: 32 GiB available: 31.31 GiB used: 12.7 GiB (40.5%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: 8502 part-no: 1866 CL10 Series serial: <filter>
Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
manufacturer: 8502 part-no: 1866 CL10 Series serial: N/A
Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2500 min/max: 1600/2500 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2500 2: 2500 3: 2500 4: 2500 5: 2500 6: 2500
7: 2500 8: 2500 bogomips: 40010
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com.
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none off: DP-2,DP-3
empty: DP-1,DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1b06
class-ID: 0300
Device-2: Microsoft LifeCam Cinema driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.1:3
chip-ID: 045e:075d class-ID: 0102
Display: x11 server: X.Org v: 21.1.16 compositor: Picom v: 12.5 driver: X:
loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 92 s-size: 1237x393mm (48.70x15.47")
s-diag: 1298mm (51.1")
Monitor-1: not-matched mapped: DP-3 pos: left res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 96 size: 510x287mm (20.08x11.3") diag: 585mm (23.04")
modes: N/A
Monitor-2: not-matched mapped: DP-4 pos: primary,right res:
mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 93
size: 700x390mm (27.56x15.35") diag: 801mm (31.55") modes: N/A
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Info: Tools: gpu: nvidia-smi x11: xdpyinfo, xprop, xrandr
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10ef class-ID: 0403
Device-3: Microsoft LifeCam Cinema driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.84-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
class-ID: 0200
Device-2: Qualcomm Atheros AR922X Wireless Network Adapter driver: ath9k
v: kernel bus-ID: 07:01.0 chip-ID: 168c:0029 class-ID: 0280
IF: wlp7s1 state: up mac: <filter>
Local Storage: total: 2.8 TiB used: 974.64 GiB (34.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSA2CW080G3
size: 74.53 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0302 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EALX-009BA0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1H15
scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE WH10LS30 rev: 1.00
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 74.03 GiB size: 72.31 GiB (97.68%) used: 40.25 GiB (55.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6bb0f422-04df-45b8-953c-2d25b8276f0a
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 120.4 MiB (23.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 97E8-8045
ID-3: /byczek raw-size: 400.39 GiB size: 393.04 GiB (98.16%)
used: 2 MiB (0.0%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: byczek
uuid: 6a842156-9de5-4322-80dc-abacab03eb07
ID-4: /home raw-size: 292.97 GiB size: 287.31 GiB (98.07%)
used: 271.63 GiB (94.5%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
label: glutaminian_kodu uuid: 690a8f37-1233-4f0e-b8d8-263d3bb3a836
ID-5: /mnt/hdd raw-size: 250 GiB size: 245.02 GiB (98.01%)
used: 210.87 GiB (86.1%) fs: ext4 dev: /dev/sdc5 maj-min: 8:37 label: N/A
uuid: 8a7751c3-613f-4f49-9f97-e5ca3deb5ffe
ID-6: /run/media/marcin/windows raw-size: 638.54 GiB
size: 638.54 GiB (100.00%) used: 451.77 GiB (70.7%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: N/A uuid: CCCE9867CE984B98
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: ntfs label: System Reserved
uuid: 94FE42AEFE428906
ID-2: /dev/sdc2 maj-min: 8:34 size: 681.41 GiB fs: ntfs label: data
uuid: 01D921C52386A1C0
ID-3: /dev/sdc3 maj-min: 8:35 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdd2 maj-min: 8:50 size: 531.12 GiB fs: ntfs label: morda
uuid: 0794973B0F0BDEEA
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: Microsoft LifeCam Cinema type: video,audio
Device-2: 2-1.3:4 info: Holtek USB-HID Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 04d9:a232 class-ID: 0300
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 5-1:2 info: Realtek RTS5411 Hub ports: 3 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 5-1.1:4 info: Trust GXT 165 Gaming Mouse type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 480mA chip-ID: 145f:0276 class-ID: 0301
Device-2: 5-1.3:5 info: LG USA 27UP850 - WK.AEUDCSN External Monitor 4K
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 043e:9a39
class-ID: 0300 serial: <filter>
Hub-9: 5-2:3 info: Atmel 4-Port Hub ports: 4 rev: 1.1
chip-ID: 03eb:0902 class-ID: 0900
Hub-10: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 29.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1731 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
pkgs: 171 libs: 25 pm: pacman pkgs: 1553 libs: 435 tools: pamac,yay
pm: flatpak pkgs: 7
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
3: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
5: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
6: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
7: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Active nix channels for user: marcin
1: home-manager https://github.com/nix-community/home-manager/archive/master.tar.gz
2: nixpkgs https://nixos.org/channels/nixpkgs-unstable
Processes:
CPU top: 5 of 290
1: cpu: 92.2% command: thunderbird pid: 26765 mem: 760.5 MiB (2.3%)
2: cpu: 7.0% command: alacritty pid: 28532 mem: 108.2 MiB (0.3%)
3: cpu: 6.9% command: haskell-language-server-9.2.8 pid: 10979
mem: 6951.5 MiB (21.6%)
4: cpu: 6.6% command: emacs pid: 3776 mem: 575.7 MiB (1.7%)
5: cpu: 4.5% command: opera pid: 9258 mem: 593.6 MiB (1.8%)
Memory top: 5 of 290
1: mem: 6951.5 MiB (21.6%) command: haskell-language-server-9.2.8
pid: 10979 cpu: 6.9%
2: mem: 1135.6 MiB (3.5%) command: opera pid: 3882 cpu: 2.0%
3: mem: 945.0 MiB (2.9%) command: opera pid: 4270 cpu: 0.3%
4: mem: 760.5 MiB (2.3%) command: thunderbird pid: 26765 cpu: 92.2%
5: mem: 593.6 MiB (1.8%) command: opera pid: 9258 cpu: 4.5%
Processes: 290 Power: uptime: 4h 2m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 1 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 12.52 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 257
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: alacritty
inxi: 3.3.37
The error occurs because of the default settings of morc_menu in its configuration file ~/.config/morc_menu/morc_menu_v1.conf.
In line 96 the -w switch has to be changed to -z so that the width of the morc_menu window can be displayed.
Open the file and change line 96 from
menu_cmd="dmenu -i -l MENU_LINES -x X_POSITION -y Y_POSITION -w MENU_WIDTH ${DMENU_OPTIONS} "
to
menu_cmd="dmenu -i -l MENU_LINES -x X_POSITION -y Y_POSITION -z MENU_WIDTH ${DMENU_OPTIONS}"
After the change morc_menu should work again.
I assume this happened because of the dmenu-manjaro package that got updated lately.
system
Closed
19 April 2025 08:54
13
