Morc menu doesn't work in i3, and much more
Hi, the morc menu don’t work on i3, and the bash pointer in the terminal appears in the middle of the window terminal. I have to update via pamac because pacman has a lot of conflict.
Please help me to solve this problems
Thank you a lot
if you have conflict with pacman - you will have the same using pamac - so I will suggest you look into preparing for the update.
Then run
sudo pacman -Syu
