Monitors go blank after 10 minutes
Same issue here since the upgrade to 4.20, monitors go blank after 10 minutes.
I don’t have xfce-screensaver installed.
‘Put to sleep after’ in Power Manager for AC is fully disabled.
xfconf-query -lvc xfce4-power-manager
/xfce4-power-manager/blank-on-ac                        0
/xfce4-power-manager/blank-on-battery                   0
/xfce4-power-manager/brightness-on-ac                   9
/xfce4-power-manager/brightness-on-battery              9
/xfce4-power-manager/brightness-switch                  0
/xfce4-power-manager/brightness-switch-restore-on-exit  1
/xfce4-power-manager/critical-power-action              3
/xfce4-power-manager/dpms-enabled                       false
/xfce4-power-manager/dpms-on-ac-off                     20
/xfce4-power-manager/dpms-on-ac-sleep                   0
/xfce4-power-manager/dpms-on-battery-off                5
/xfce4-power-manager/dpms-on-battery-sleep              0
/xfce4-power-manager/general-notification               true
/xfce4-power-manager/inactivity-on-ac                   75
/xfce4-power-manager/inactivity-on-battery              15
/xfce4-power-manager/inactivity-sleep-mode-on-battery   1
/xfce4-power-manager/lid-action-on-ac                   1
/xfce4-power-manager/lid-action-on-battery              1
/xfce4-power-manager/logind-handle-lid-switch           true
/xfce4-power-manager/power-button-action                0
/xfce4-power-manager/show-panel-label                   1
/xfce4-power-manager/show-presentation-indicator        false
/xfce4-power-manager/show-tray-icon                     false
Your post has been moved to a dedicated topic.
Please do not add your Support request to another member’s issue. Always create your own topic and provide information for those who might wish to help.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
There’s an interesting bug report and discussion here:
ArchWiki - Xfce - Display Blanking
Xfce Power Manager
Xfce Power Manager controls DPMS settings only. They can be configured in the Power Manager GUI within the Display tab.
Note that when Display power management is turned off, DPMS is fully disabled, but this does not mean that Power Manager will simply stop controlling DPMS. However, it does not control screen blanking, which may remain enabled even after display power management is disabled.
To disable both blanking and DPMS, right click on the power manager system tray icon or left click on the panel applet and make sure that the option labelled Presentation mode is ticked.
