Dear experts,
I’m currently on linux514 and noticed that linux514 will be EOL and tested linux515 and that one is not working for me atm: System works with linux514 but not with linux515. So I tried linux510 to make sure I have an escape route if linux514 is pulled and linux515 isn’t ready for me, but I run into an issue.
My screens are 2x 27 inch: MSI MAG274QRF-QD with 165Hz support.
Linux510 works with 60Hz (I have 3 options 165Hz, 120Hz and 60Hz, I haven’t tried 120Hz) or else it will not load the SDDM login screen or if I get pass that, it will not load the desktop. Most of the time it will not load the login screen and my monitors will go into standby mode and I don’t get them out of that state. If i switch my screen to 60Hz, it works!
I switch Hz via > System settings > Display and Monitor > Display configuration > Refresh rate.
At the moment I’m working in linux514, that works.
Current system specs: inxi --admin --verbosity=7 --filter --width
Kernel: 5.14.21-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=7203573d-0ddc-4484-933c-033127cfc0a1 rw quiet apparmor=1
security=apparmor resume=UUID=b666983d-8b2e-4246-bada-d2ef3c249d31
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4021
date: 08/09/2021
RAM: total: 62.71 GiB used: 13.73 GiB (21.9%)
Info: 12-Core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201016 cache:
L1: 768 KiB L2: 6 MiB L3: 64 MiB bogomips: 177692
Speed: 3594 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 3594 2: 3357 3: 2239 4: 2283 5: 3618 6: 3227 7: 2861 8: 2716 9: 2729
10: 2979 11: 2293 12: 2823 13: 2910 14: 2312 15: 2322 16: 2663 17: 2249
18: 2771 19: 2902 20: 3064 21: 2472 22: 3157 23: 2273 24: 2317
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel bus-ID: 0c:00.0 chip-ID: 1002:73bf class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3:2 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5119x1440 s-dpi: 96 s-size: 1354x381mm (53.3x15.0")
s-diag: 1407mm (55.4")
Monitor-1: DisplayPort-0 res: 2560x1440 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DisplayPort-1 res: 2560x1440 dpi: 109
OpenGL: renderer: AMD Radeon RX 6800 XT (SIENNA_CICHLID DRM 3.42.0
5.14.21-2-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 0c:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0e:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: Cambridge Silicon Radio Audioengine HD3 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:3 chip-ID: 0a12:1243
class-ID: 0300 serial: <filter>
Device-5: Corsair CORSAIR VIRTUOSO SE Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 1b1c:0a3e
Sound Server-1: ALSA v: k5.14.21-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:5
Local Storage: total: 1.36 TiB used: 736.69 GiB (52.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7 temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung
model: SSD 850 EVO 500G size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 8104 scheme: MBR
ID-1: / raw-size: 862.15 GiB size: 847.54 GiB (98.31%)
used: 332.49 GiB (39.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 7203573d-0ddc-4484-933c-033127cfc0a1
label: NO_LABEL uuid: AFF8-F7D7
ID-3: /mnt/nasxtreem/container-apps raw-size: N/A size: 11.9 TiB
used: 1.86 TiB (15.6%) fs: cifs dev: /dev/Container-apps
ID-4: /mnt/nasxtreem/documents raw-size: N/A size: 11.9 TiB
used: 1.86 TiB (15.6%) fs: cifs dev: /dev/Documents
ID-5: /mnt/nasxtreem/multimedia raw-size: N/A size: 11.9 TiB
used: 1.86 TiB (15.6%) fs: cifs dev: /dev/Multimedia
ID-6: /mnt/nasxtreem/multimedia-kids raw-size: N/A size: 11.9 TiB
used: 1.86 TiB (15.6%) fs: cifs dev: /dev/Multimedia-kids
ID-7: /mnt/nasxtreem/photos raw-size: N/A size: 11.9 TiB
used: 1.86 TiB (15.6%) fs: cifs dev: /dev/Photos
ID-8: /mnt/nasxtreem/work raw-size: N/A size: 11.9 TiB
used: 1.86 TiB (15.6%) fs: cifs dev: /dev/Work
ID-9: /run/timeshift/backup raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 404.21 GiB (88.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: backup
uuid: 2e051197-f9fa-456d-b05e-3d2727b59ccb
ID-1: swap-1 type: partition size: 69.07 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: b666983d-8b2e-4246-bada-d2ef3c249d31
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-3:2 info: Logitech C922 Pro Stream Webcam type: Video,Audio
power: 500mA chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-2: 1-4:3 info: Cambridge Silicon Radio Audioengine HD3
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0a12:1243 class-ID: 0300
serial: <filter>
Hub-2: 1-5:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-6:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Sharkoon JMicron JMS567 ATA/ATAPI Bridge
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 8mA chip-ID: 357d:7788 class-ID: 0806 serial: <filter>
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-1:2 info: Corsair CORSAIR VIRTUOSO SE Wireless Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 5
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:0a3e class-ID: 0300
serial: <filter>
Device-2: 3-4:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 5-2:2 info: Cooler Master ARES type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 2516:014d class-ID: 0300
Hub-7: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
Hub-8: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-9: 7-1:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2812 class-ID: 0900
Device-1: 7-1.4:4 info: Metadot Das Keyboard 4 type: Keyboard,HID
power: 100mA chip-ID: 24f0:0140 class-ID: 0300
Device-2: 7-4:3 info: Logitech G502 Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c07d class-ID: 0300 serial: <filter>
Hub-10: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-11: 8-1:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0812 class-ID: 0900
System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 60.0 C
mem: 60.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 601 Uptime: 3h 0m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1514 lib: 447
flatpak: 0 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.09
