Monitor will not shutdown after Sleep
I have already created a similar topic. However, much time has passed, I got a new monitor. I thought that the problem was in the old monitor that I used before.
I have two monitors:
  • Monitor-1: DVI-D-1 pos: bottom-r model: Philips PHL 246E9Q res: 1920x1080
    hz: 60 dpi: 93 diag: 604mm (23.8")
  • Monitor-2: HDMI-A-1 pos: primary,top-left model: Philips 32M1C5500V
    res: 2560x1440 hz: 144 dpi: 93 diag: 800mm (31.5")
I previously had a Samsung monitor, which is very old, instead of 32M1C5500V.
What’s wrong?
When both monitors are connected via cable (physically), they do not turn off after the time specified in the KDE Plasma System Settings. If I physically disconnect one of the monitors, it turns off after the time specified.
That is, if both monitors are physically connected, they do not turn off. Even if one of them is disabled programmatically (using the switching widget or in the settings). The following happens when the monitors’ turn-off time is reached (if they are both physically connected):
    1. When 3 minutes are reached, both monitors go to sleep mode.
    1. They go out.
    1. They go out for a few seconds and then light up again, as if I moved the mouse or pressed a keyboard key.
This happens, of course, when I do not move the mouse or touch the keyboard. This happens even with the mouse and keyboard physically disconnected from the PC.
It is inconvenient for me to physically disconnect (disconnect the DVI cable from the monitor) the second monitor every time, so that the main monitor turns off after a specified time (3 minutes, for example). It is also inconvenient for me to turn off the main monitor with a button every time when one monitor is turned off programmatically (via settings). With each new update, I hope that this will be fixed, but they still haven’t fixed it.
Tell me what can be done?
I tried to write a bash code that turns off the monitors via certain commands, but it didn’t help. The situation with my script at that time was similar to what happens without a script (they turn on again).
Once I came across that the problem may be that the video card has DVI + HDMI outputs. But I already doubt this information.
inxi -Gxx
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Tul / PowerColor driver: amdgpu
    v: kernel arch: GCN-4 pcie: speed: 8 GT/s lanes: 16 ports:
    active: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
    chip-ID: 1002:67df temp: 54.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 4480x2520
    display-ID: 0
  API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
    gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
    drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 470 Graphics
    (radeonsi polaris10 LLVM 19.1.7 DRM 3.59 6.13.0-3-rt5-MANJARO)
    device-ID: 1002:67df display-ID: :1.0
  API: Vulkan v: 1.4.304 surfaces: xcb,xlib,wayland device: 0
    type: discrete-gpu driver: N/A device-ID: 1002:67df
The thread title has been changed for clarity.
As your issue might involve aspects of Sleep/Hibernation, please provide full system information (see below).
Also, as you are using multiple monitors; I suggest to include some information about whatever KVM you might be using.
I’m sure someone will help when they are able.
System Information:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Those with privacy concerns, note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Thank You!
inxi --filter --verbosity=8                                                             ✔
  Kernel: 6.13.0-3-rt5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.13-rt-x86_64
    root=UUID=00000000-0000-0000-0000-000000000000 rw rootflags=subvol=@
    quiet splash resume=UUID=00000000-0000-0000-0000-000000000000
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Desktop Mobo: ASRock model: H310CM-HDV serial: <superuser required>
    uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: P4.30
    date: 07/28/2021
  System RAM: total: 16 GiB available: 15.55 GiB used: 8.23 GiB (52.9%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M378A1G43EB1-CPB serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
    part-no: M378A1K43BB1-CPB serial: <filter>
  Info: model: Intel Core i3-9100F bits: 64 type: MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 4000 min/max: 800/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4000 2: 4000 3: 4000 4: 4000 bogomips: 28800
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
    v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20
    pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 off: DVI-D-1
    empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 54.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: DVI-D-1 model: Philips PHL 246E9Q serial: <filter> built: 2020
    res: 1920x1080 dpi: 93 gamma: 1.2 chroma: red: x: 0.663 y: 0.310 green:
    x: 0.275 y: 0.671 blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-1 model: Philips 32M1C5500V serial: <filter> built: 2024
    res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 93 gamma: 1.2 chroma: red:
    x: 0.675 y: 0.314 green: x: 0.282 y: 0.647 blue: x: 0.149 y: 0.063 white:
    x: 0.314 y: 0.329 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
    ratio: 16:9 modes: 2560x1440, 3840x2160, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 832x624,
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 96 2: parse_edid:
    unhandled CEA mode 97
    device-ID: 1002:67df memory: 3.91 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 470 Graphics (RADV POLARIS10) driver: N/A device-ID: 1002:67df
  Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
    RX 470/480 / 570/580/590] vendor: Tul / PowerColor driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  API: ALSA v: k6.13.0-3-rt5-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v6: <filter> type: noprefixroute scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Info: services: NetworkManager,nginx
  Local Storage: total: 7.51 TiB used: 56.65 GiB (0.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CX400-128-G2
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 117D scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD8004FRYZ-01VAEB0 size: 7.28 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1H01 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Apacer model: AS350 128GB
    tech: SSD serial: <filter> fw-rev: 1A0 scheme: GPT
  ID-1: / raw-size: 118.23 GiB size: 118.23 GiB (100.00%)
    used: 56.65 GiB (47.9%) fs: btrfs dev: /dev/sdc3 maj-min: 8:35 label: N/A
    uuid: 00000000-0000-0000-0000-000000000000
  ID-2: /home raw-size: 118.23 GiB size: 118.23 GiB (100.00%)
  ID-3: /var/cache raw-size: 118.23 GiB size: 118.23 GiB (100.00%)
  ID-4: /var/log raw-size: 118.23 GiB size: 118.23 GiB (100.00%)
  ID-1: swap-1 type: partition size: 1024 MiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdc2 maj-min: 8:34 label: N/A
  ID-1: /dev/sda1 maj-min: 8:1 size: 8 MiB fs: <superuser required> label: N/A
    uuid: N/A
  ID-2: /dev/sdb1 maj-min: 8:17 size: 104.49 GiB fs: ext4 label: N/A
    uuid: e405ed98-e8df-459f-a1d2-652bf1426f76
  ID-3: /dev/sdb3 maj-min: 8:19 size: 7.18 TiB fs: ext4 label: hdd
    uuid: 387b4c95-81fb-4242-b4f8-226a55fae1cb
  ID-4: /dev/sdc1 maj-min: 8:33 size: 9 MiB fs: <superuser required>
    label: N/A uuid: N/A
  Device-1: 1-1:2 info: USB OPTICAL MOUSE type: mouse,keyboard
    chip-ID: 4e53:5406 class-ID: 0301
  Device-2: 1-8:3 info: China Resource Semico USB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 1a2c:4c5e class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1142
  Packages: pm: pacman pkgs: 1355 libs: 342 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
Processes:
  CPU top: 5 of 347
  1: cpu: 32.5% command: java pid: 3473 mem: 3386.1 MiB (21.2%)
  2: cpu: 11.5% command: opera pid: 11963 mem: 314.1 MiB (1.9%)
  3: cpu: 11.4% command: zsh pid: 12059 mem: 8.88 MiB (0.0%)
  4: cpu: 10.0% command: kwin_wayland pid: 802 mem: 417.1 MiB (2.6%)
  5: cpu: 5.8% command: firefox pid: 5091 mem: 383.0 MiB (2.4%)
  Memory top: 5 of 347
  1: mem: 3386.1 MiB (21.2%) command: java pid: 3473 cpu: 32.5%
  2: mem: 584.0 MiB (3.6%) command: opera pid: 1475 cpu: 1.0%
  3: mem: 540.2 MiB (3.3%) command: firefox pid: 4866 cpu: 5.6%
  4: mem: 476.4 MiB (2.9%) command: plasmashell pid: 1028 cpu: 4.6%
  5: mem: 417.1 MiB (2.6%) command: kwin_wayland pid: 802 cpu: 10.0%
  Processes: 347 Power: uptime: 1h 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
