I bought and installed the ASUS NVIDIA GeForce GT 710 Video Card after I found I could get no sound through the DVI cable.
I still get no sound.
The monitor is a 32 inch Philips BDM3201FD/75 2018 model. Hopefully the specs of the computer into which I am trying to install the video card can be found. I provided this information when I set up my account earlier tonight.
Ok. So you are now using HDMI. You see a picture but no sound.
What about the sound settings of your desktop environment. You have 2 sound devices:
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e0f
You need to tell your DE which device to use. There should be a sound configuration option in the system config section of your DE. There you need to select nvidia resp. HDMI as the outgoing device.
pavucontrol gives me:
First line: sound card icon, “Built-in Audio Digital Stereo (IEC958)”, speaker icon, faded lock icon, tick icon
Second line: Port: Digital Output (S/PIDF) - (no other option on drop-down menu.)
Third line: first 2/3 of horizontal line WAS blue. text says “100% (0.00) Db” twice
NOW third line is all colourless.
“Advanced” drop-down section: Only PCM is ticked. AC3, EAC3, DTS MPEG and AAAAC unticked.
Next line: Latency offset: 0.00
Next Line: sound card icon, "GK208 HDMI/DP Audio Controller Digital Stereo (HDMI), speaker icon, faded lock icon, tick icon.
I might call it a night, Thank you pobrn, mbod, and everyone else who has taken the trouble to read this.
I couldn’t find where in “system settings” to “to select that as audio output device”.
Below, is my attempt, with text, to emulate a screenshot of pavucontrol (I trust that the administrators consider it sufficiently small for me not to have to post it to pastebin.com. )
As I type this, the longer line, immediately below the line labelled “Front Right” is moving backwards and forwards as if in response to a news broadcast in one of my Firefox tabs, but there is no sound.
You’re not suggesting I switch to Ubuntu to get sound on my Philips 32" monitor, pobrn?
Another workaround might be to try Arch Linux on which Manjaro is based.
Having looked at How do I switch to another audio output sink in XFCE? on askubuntu.com, I don’t understand the difference between xfce4-pulseaudio-plugin and pulseaudio. Both have been installed on my system, but there is only “Pulse Audio Volume Control” within the “Multimedia applications” branch of my menu. Is that one, the other or a combination of the two?
Previously, I could get sound on my Philips 32" monitor on an older computer with only 8G of RAM, but I am unable to get the sound to work on my newer computer with 16G of RAM.
I had similar issue on Manjaro KDE. I had to do nothing special. Its all about selecting right profile in settings.
Go to Settings >> Audio >> Configure.
There in profile option select Digital stereo(HDMI) Output. If you want your mic input(select digital stero Output(HDMI) + analog stero input)
If you want to revert to your laptops mic and speakers, select Analog stero Duplex profile. (After selecting this you get to see speaker and headphone jack option in sound widget of KDE)
