Hi i was trying to find why my game cs go on steam its stuck on 60 fps , i found then i change refresh rate on monitor its only then change fps in game . if i have 1920x1080 60hz then i have in game 60 fps ,in game i can change all video settings from low till hard its not do nothing . ad if i change so resolution til i go 75 hz on monitor then i get 75 fps in game its stupid . if its possible to fix its be nice , thanks for help
Kernel: 5.15.93-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: Xfce v: 4.18.1 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: H81M-VG4 R2.0 serial: <superuser required>
BIOS: American Megatrends v: P1.30 date: 04/24/2015
Info: quad core model: Intel Core i7-4770K bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 2649 high: 3377 min/max: 800/3500 cores: 1: 2030 2: 2789
3: 2506 4: 3134 5: 3377 6: 2214 7: 2590 8: 2556 bogomips: 56014
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ASUSTeK driver: nvidia
v: 525.89.02 arch: Maxwell bus-ID: 01:00.0
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7 driver: X:
loaded: nvidia gpu: nvidia resolution: 1920x1080~60Hz
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GM204 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Sound API: ALSA v: k5.15.93-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
vendor: ASRock driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 342.81 GiB used: 155.49 GiB (45.4%)
ID-1: /dev/sda vendor: Gigabyte model: GP-GSTFS31240GNTD size: 223.57 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD SM841 2.5 7mm 128GB
ID-1: / size: 116.81 GiB used: 24.63 GiB (21.1%) fs: ext4 dev: /dev/sdb1
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
Processes: 241 Uptime: 53m Memory: 11.63 GiB used: 1.74 GiB (15.0%)
Init: systemd Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1247
Shell: Bash v: 5.1.16 inxi: 3.3.25
[ss@ss ~]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
[ss@ss ~]$
[ss@ss ~]$ mhwd -l
0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
0000:01:00.0 (0300:10de:13c2) Display controller nVidia Corporation:
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
