I am attempting to expand beyond 4 screens and have tried a number of methods so far:
- having all 5 monitors plugged into 1 gpu (apparently hard limit of 4 despite connectors)
- multiseat with simultaneous user login (plasma does not like this)
- manually editing nvidia.conf attempting to put in second x screen.
current /etc/X11/mhwd.d/nvidia.conf:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 460.32.03
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" Relative "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "DELL P2419H"
HorizSync 30.0 - 83.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "Lenovo Group Limited M14"
HorizSync 30.0 - 90.0
VertRefresh 50.0 - 75.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce RTX 2080 SUPER"
BusID "PCI:11:0:0"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BoardName "GeForce RTX 2070 SUPER"
BusID "PCI:12:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-5.1"
Option "metamodes" "HDMI-0: nvidia-auto-select +1080+0 {rotation=invert}, DP-2: nvidia-auto-select +3000+0, DP-4.1: nvidia-auto-select +1080+1080, DP-4.2: nvidia-auto-select +0+110 {rotation=right}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "nvidia-auto-select +0+0 {AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
I am not sure what the problem is as other distros (ubuntu and centos) and windows can scale beyond 4 displays (I have tested with my specific configuration).
Also all of my monitors are working including the display link one as I have tested when they are connected with the main GPU.
I think I am doing something dumb here but don’t know how to fix it.
current inxi:
Host: farmboy-x570aorusmaster Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 Console: tty 3
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: X570 AORUS MASTER v: -CF serial: N/A
Mobo: Gigabyte model: X570 AORUS MASTER v: x.x serial: N/A UEFI: American Megatrends
v: F11 date: 12/06/2019
ID-1: hidpp_battery_0 charge: N/A condition: N/A
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP L2 cache: 4 MiB
Speed: 2200 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 2200 2: 2200 3: 2199
4: 2199 5: 2199 6: 2198 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200 13: 2202
14: 2200 15: 2200 16: 2193
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] driver: nvidia v: 460.32.03
Device-2: NVIDIA TU104 [GeForce RTX 2070 SUPER] driver: nvidia v: 460.32.03
Display: server: x org 1.20.10 driver: loaded: nvidia
Specifically I would like to have the plasma desktop run across my 2 gpus. Currently The 5 display comes up in the display configuration but when i click enable and apply the screen is still blank.
If there is any other information needed let me know
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 4 outputs: 10 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x373 cap: 0x2, Sink Output crtcs: 4 outputs: 8 associated providers: 1 name:NVIDIA-G0
xrandr -q
Screen 0: minimum 8 x 8, current 4920 x 2160, maximum 32767 x 32767
DP-4.1 connected 1920x1080+1080+1080 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+ 59.94 50.00
1600x1200 60.00
1600x900 60.00
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-4.2 connected 1080x1920+0+110 right (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
640x480 75.00 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+1080+0 inverted (normal left inverted right x axis y axis) 527mm x 296mm
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
DP-2 connected 1920x1080+3000+0 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+
1600x900 60.00
1152x864 75.00
800x600 75.00 60.32
640x480 75.00 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
USB-C-0 disconnected (normal left inverted right x axis y axis)
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
DP-1-4 disconnected (normal left inverted right x axis y axis)
DP-1-5 disconnected (normal left inverted right x axis y axis)
USB-C-1-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.94 50.00
1680x1050 59.95 59.88
1600x1200 70.00 60.00
1440x900 74.98 59.90 59.89
1366x768 59.79
1280x1024 75.02 71.93 60.02
1280x800 59.81
1280x720 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
1920x1080 (0x1be) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1bf) 148.350MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x1c0) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1600x1200 (0x1c1) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1280x1024 (0x1c3) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x1c4) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x720 (0x1c6) 74.180MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1280x720 (0x1c7) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1024x768 (0x1c9) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1ca) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x1cb) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x1cc) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x1cd) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x1ce) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1cf) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1d0) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
640x480 (0x1d1) 25.170MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.46KHz
v: height 480 start 490 end 492 total 525 clock 59.93Hz
