So I installed Manjaro on my HP Omen 15 (2018) laptop last weekend and unfortunately I am having issues with one of my monitors. I have two identical monitors (Acer XV253Q). The left monitor is connected using HDMI, and the right one using DP 1.4. Both at 144hz refresh rate. I am not using the laptop’s built in monitor, lid is closed.
When both monitors turn off due to ‘Screen energy saving’ and I wake them up by moving my mouse or press keys, only the right monitor wakes up correctly. The left monitor does turn on, but it only shows “no signal” and just turns off again. The only way to get it working again is by rebooting, or changing something in the display settings and applying it.
I found out that if I change the left monitor’s refresh rate to 120Hz instead of 144Hz, it does wake up correctly. I changed the screen energy saving switch off time to 1 minute, and tried it many times to confirm it is only happening when running 144Hz. So for some reason the issue is not occurring with 120Hz?
Why is this happening? I would like to have 144hz on my left monitor as well.
I’m coming from Windows 10, there it worked fine so it is not a faulty monitor or anything.
Things I have tried that did not fix this:
- Using Kernel 5.10.89-1 instead of 5.15.12-1
- Add Option “HardDPMS” “False” in the device section in /etc/x11/mhwd.d/nvidia.conf
- Only connect the left monitor.
- Set left monitor as primary instead of right one.
cat /etc/X11/xorg.conf.d/90-mhwd.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 495.44
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
# Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
Option "HardDPMS" "True"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
xrandr (output is the same during the issue)
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 543mm x 302mm
1920x1080 60.00 + 143.98 119.98* 84.90 59.94 50.00 23.98
3840x2160 59.94 50.00 29.97 25.00 23.98
1680x1050 59.95
1440x900 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-0 connected (normal left inverted right x axis y axis)
1920x1080 144.00 + 60.00
640x480 59.94
DP-1 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 543mm x 302mm
1920x1080 60.00 + 143.98* 119.98 84.90 59.94 50.00
1680x1050 59.95
1440x900 59.89
1280x960 60.00
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=fa611949-eabe-4011-a503-beed685a6a84 rw quiet apparmor=1
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: N/A
Mobo: HP model: 84DB v: 93.21 serial: <filter> UEFI: AMI v: F.08
date: 02/21/2019
ID-1: BAT0 charge: 45.8 Wh (100.0%) condition: 45.8/45.8 Wh (100.0%)
volts: 17.2 min: 15.4 model: HP Primary type: Li-ion serial: N/A
status: Full
ID-2: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
status: Full
RAM: total: 15.51 GiB used: 3.4 GiB (21.9%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: Bottom - Slot 1 (top) size: No Module Installed
Device-2: Bottom - Slot 2 (under) size: 16 GiB speed: 2667 MT/s type: DDR4
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: SK Hynix
part-no: HMA82GS6CJR8N-VK serial: <filter>
Info: model: Intel Core i7-8750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 base/boost: 3861/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.2 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
10: 800 11: 800 12: 800 bogomips: 52815
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP104BM [GeForce GTX 1070 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1be1 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam
type: USB driver: uvcvideo bus-ID: 1-6:3 chip-ID: 05c8:03bc class-ID: 0e02
Display: server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: nvidia resolution: <missing: xdpyinfo>
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 3c:00.0
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 565.21 GiB (48.3%)
model: MZVLW256HEHP-000H1 size: 238.47 GiB block-size: physical: 512 B
rev: CXB73H1Q temp: 30.9 C scheme: GPT
SMART: yes health: PASSED on: 43d 11h cycles: 1,197
read-units: 22,617,704 [11.5 TB] written-units: 21,106,856 [10.8 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
family: Micron Client SSDs size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 023 temp: 40 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 133d 23h cycles: 858
written: 2.75 TiB
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 24.84 GiB (10.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: fa611949-eabe-4011-a503-beed685a6a84
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: 468E-7275
ID-3: /run/media/eric/MX500 raw-size: 906.5 GiB size: 906.5 GiB (100.00%)
used: 540.37 GiB (59.6%) fs: ntfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: MX500 uuid: D038DEE938DECE1A
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-3: 1-1.1:9 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 1-1.1.2:10 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-2: 1-1.3:6 info: Logitech G Pro Wireless Gaming Mouse
type: Mouse,Keyboard,HID driver: logitech-hidpp-device,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 498mA chip-ID: 046d:c088 class-ID: 0300
serial: <filter>
Device-3: 1-1.4:8 info: Hoksi DGK68C type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 2f68:4001 class-ID: 0300
Device-4: 1-6:3 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD Integrated Webcam
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03bc class-ID: 0e02
Device-5: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-1:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
Hub-6: 2-1.1:4 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.1
System Temperatures: cpu: 49.0 C pch: 49.0 C mobo: N/A gpu: nvidia
temp: 45 C
Processes: 330 Uptime: 2h 32m wakeups: 14 Init: systemd v: 250
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1232 lib: 336
flatpak: 0 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.12
running-in: konsole inxi: 3.3.11
