Monitor is black when it returns from sleep
  1. click on sleep from kde menu or use systemctl suspend.
  2. the system will sleep.
  3. wake via keyboard or mouse and the monitor completely black nothing reacts to the mouse.
I can fix this by hitting the menu key(windows key) kde menu will pop up. I navigate to system settings → Display & Monitor → Display configuration. Randomly change any setting and click Apply. The desktop will come back, I click revert and everything is back to normal
another clue: I have installed the same Manjaro on 2 workstations that have exact same hardware except - 1st WS has 1 monitor, 2nd WS has 2 monitors. When the 2nd system returns from suspend/sleep, the monitors are black or 1 is black the other displays its share of the desktop.
But! then Display Configuration (in System settings) says: An output has been removed. Settings have been reloaded. and both monitors blink and then display as normal the desktop
As a relatively new forum user, you are encouraged to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) is often useful (and this or similar will usually be asked for in Support threads):
inxi -zv8
This gives some (privacy-filtered) information about your system.
also if you unplug and plug in HDMI cable it will bring back the desktop
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=cc76a534-e376-43c9-aa3b-6b6047224bd2 rw quiet splash
    resume=UUID=4c6badf6-0499-4d3c-9d23-99355017ed4c udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Mini-pc System: Intel Client Systems product: NUC12WSHi7 v: M42761-303
    serial: <superuser required> Chassis: Intel Corporation type: 35 v: 2.0
  Mobo: Intel model: NUC12WSBi7 v: M46422-303 serial: <superuser required>
    part-nu: NUC12WSHi7000 uuid: <superuser required> UEFI: Intel
    v: WSADL357.0085.2022.0718.1739 date: 07/18/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  System RAM: total: 16 GiB available: 15.2 GiB used: 4.22 GiB (27.7%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: CBD32D4S2S1MF-8 serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
  Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x436
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
    st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
    KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 400 min/max: 400/4700:3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
    bogomips: 79888
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] driver: i915 v: kernel
    alternate: xe arch: Xe process: Intel 10nm built: 2021-22+ ports:
    active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:46a6 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: AOC 2367 serial: <filter> built: 2016
    res: 1920x1080 dpi: 96 gamma: 1.2 chroma: red: x: 0.635 y: 0.333 green:
    x: 0.310 y: 0.624 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
    size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x720,
    1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL
    GT2) device-ID: 8086:46a6 memory: 7.42 GiB unified: yes
  API: Vulkan v: 1.4.304 layers: N/A device: 0 type: integrated-gpu
    name: Intel Iris Xe Graphics (ADL GT2) driver: N/A device-ID: 8086:46a6
    surfaces: xcb,xlib
  Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 56:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  IF: enp86s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 21.64 GiB (4.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8SEP4512N-A0
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: SBM01100 temp: 23.9 C
    scheme: GPT
  ID-1: / raw-size: 459.92 GiB size: 451.63 GiB (98.20%)
    used: 21.64 GiB (4.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: cc76a534-e376-43c9-aa3b-6b6047224bd2
  ID-2: /4-D raw-size: N/A size: 436.39 GiB used: 146.33 GiB (33.5%) fs: nfs
    remote: eye:/data/4-D
  ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 8454-350B
  ID-4: /borne raw-size: N/A size: 436.39 GiB used: 146.33 GiB (33.5%)
    fs: nfs remote: eye:/ezra3/borne
  ID-5: /data raw-size: N/A size: 436.39 GiB used: 146.33 GiB (33.5%)
    fs: nfs remote: eye:/data
  ID-6: /ezra3 raw-size: N/A size: 436.39 GiB used: 146.33 GiB (33.5%)
  ID-7: /ipac4 raw-size: N/A size: 436.39 GiB used: 146.33 GiB (33.5%)
    fs: nfs remote: eye:/ipac4
  ID-8: /taxi raw-size: N/A size: 436.39 GiB used: 146.33 GiB (33.5%)
    fs: nfs remote: eye:/taxi
  ID-1: swap-1 type: partition size: 16.72 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 4c6badf6-0499-4d3c-9d23-99355017ed4c
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2 info: Logitech Cordless Trackball type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 50mA
    chip-ID: 046d:c508 class-ID: 0301
  Device-2: 3-2:3 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-3: 3-7:4 info: Arduino SA MKR1000 type: abstract (modem),CDC-data
    driver: cdc_acm interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 2341:804e class-ID: 0a00 serial: <filter>
  Device-4: 3-10:5 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 35.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1269 libs: 352 tools: pamac pm: flatpak pkgs: 0
    1: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    2: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    3: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    4: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    5: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    8: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    10: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    11: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    12: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    13: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    14: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    15: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    16: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    17: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    18: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    19: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    20: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    21: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    22: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    24: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    25: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    26: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    27: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    28: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    31: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    32: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    33: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    34: http://manjaro.grena.ge/stable/$repo/$arch
    35: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    36: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    37: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    38: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    39: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    40: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    41: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    42: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    43: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    44: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    45: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    46: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    47: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    48: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    49: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    50: https://linorg.usp.br/manjaro/stable/$repo/$arch
    51: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    52: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    53: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    54: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    55: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    56: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    57: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    58: https://mirrors2.manjaro.org/stable/$repo/$arch
    59: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    60: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    61: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    62: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    63: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    64: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    65: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    66: https://mirror.init7.net/manjaro/stable/$repo/$arch
    67: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    68: https://manjaro.kurdy.org/stable/$repo/$arch
    69: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    70: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    71: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    72: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    73: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    74: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    75: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    76: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    77: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    78: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    79: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    80: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    81: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    82: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    83: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    84: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    85: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    86: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    87: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    88: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    89: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    90: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    91: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    92: https://mirror.23m.com/manjaro/stable/$repo/$arch
    93: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    94: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    95: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    96: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    97: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    98: https://manjaro.ynh.ovh/stable/$repo/$arch
    99: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    100: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    101: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    102: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    103: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 386
  1: cpu: 2.7% command: konsole pid: 15722 mem: 232.3 MiB (1.4%)
  2: cpu: 1.3% command: firefox pid: 9429 mem: 710.0 MiB (4.5%)
  3: cpu: 0.8% command: kwin_x11 pid: 947 mem: 185.3 MiB (1.1%)
  4: cpu: 0.8% command: firefox pid: 13896 mem: 321.2 MiB (2.0%)
  5: cpu: 0.6% command: Xorg pid: 781 mem: 83.3 MiB (0.5%)
  Memory top: 5 of 386
  1: mem: 710.0 MiB (4.5%) command: firefox pid: 9429 cpu: 1.3%
  2: mem: 609.1 MiB (3.9%) command: firefox pid: 9593 cpu: 0.1%
  3: mem: 500.0 MiB (3.2%) command: plasmashell pid: 982 cpu: 0.1%
  4: mem: 354.1 MiB (2.2%) command: firefox pid: 14290 cpu: 0.0%
  5: mem: 338.1 MiB (2.1%) command: firefox pid: 10621 cpu: 0.1%
  Processes: 386 Power: uptime: 1d 28m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 4 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.07 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
Mod edit: Formatted the Terminal output for you.
Please highlight pasted output and use the </> button at the top of the reply window. Cheers! :smiley:
Has your question been answered? Highlight the answer and help others by using the solution button below the correct reply.
NO
1 out of ~5 times the screen will return normally. Here is a hack to minimize the annoyance.
systemctl suspend
echo “sleeping”
sleep 1
read -p “absorb key that wakest monitor” -n 1 xxx
echo “resetting”
xrandr --rate 50
sleep 0.1
xrandr --rate 60
found the solution:
echo 0 > /sys/power/pm_async
ArchLinux
