I have had this issue since I installed Manjaro more than a year ago.
I’m using a thunderbolt dock station with two monitors. The problem always happens with the same monitor. I’ve swapped the cables already. Also, this does not happen with other laptops or with this laptop when I boot into Windows (yeah, I have some software that requires me to keep windows!).
I have read several articles during the last year, without any luck getting the issue fixed.
Any ideas of what I can try?
> lspci -k | grep -A 2 -E "(VGA|3D)"
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
DeviceName: Onboard IGD
Subsystem: Dell UHD Graphics 620
> inxi --admin --verbosity=7 --filter --no-host
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-6.6-x86_64
root=UUID=2f59c53d-f669-48fb-a956-3d5e1b4008b7 rw rootflags=subvol=@
resume=UUID=19d6a887-5054-4544-967a-b0bcff19cb9c udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: XPS 13 9370 v: N/A
Mobo: Dell model: 0F6P3V v: A00 serial: <superuser required> part-nu: 07E6
uuid: <superuser required> UEFI: Dell v: 1.21.0 date: 07/06/2022
ID-1: BAT0 charge: 41.0 Wh (100.0%) condition: 41.0/52.0 Wh (78.9%)
volts: 8.6 min: 7.6 model: LGC-LGC6.73 DELL H754V79 type: Li-poly
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: discharging
System RAM: total: 16 GiB available: 15.34 GiB used: 4.66 GiB (30.4%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: System Board Memory type: LPDDR3 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1 min: 1.25
max: 1.25 width (bits): data: 64 total: 64 manufacturer: Micron
part-no: MT52L1G32D4PG-093 serial: N/A
Device-2: System Board Memory type: LPDDR3 detail: synchronous unbuffered
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 550 high: 800 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 800 3: 400 4: 400
5: 800 6: 800 7: 400 8: 400 bogomips: 32012
sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-2,DP-5
off: eDP-1 empty: DP-1,DP-3,DP-4 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0bda:58f4
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3.3:7
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
alternate: fbdev,vesa dri: iris gpu: i915 d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-2 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-5 pos: right res: 1920x1080 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) device-ID: 8086:5917 memory: 14.99 GiB unified: yes display-ID: :1.0
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Device-2: Realtek USB Audio driver: hid-generic,usbhid type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3.1:5 chip-ID: 0bda:48f0
class-ID: 0300
Device-4: GN Netcom Jabra SPEAK 410 USB driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.4.3:9
chip-ID: 0b0e:0412 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
class-ID: 0280 temp: 50.0 C
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.3.4:6
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp60s0u1u3u4 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0489:e0a2
class-ID: e001
Local Storage: total: 931.51 GiB used: 364.05 GiB (39.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 44.9 C
scheme: GPT
ID-1: / raw-size: 64 GiB size: 64 GiB (100.00%) used: 39.51 GiB (61.7%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 2f59c53d-f669-48fb-a956-3d5e1b4008b7
ID-2: /boot raw-size: 512 MiB size: 487.2 MiB (95.16%)
used: 140.9 MiB (28.9%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:4
label: N/A uuid: 30d5806c-2f4e-42ee-a6c5-f436f82d211d
ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 172 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p10 maj-min: 259:5 label: N/A
uuid: 43A9-C62B
ID-4: /home raw-size: 848.51 GiB size: 848.51 GiB (100.00%)
used: 324.4 GiB (38.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c41cbbec-eddb-477e-9ef3-3a52e8a20f66
ID-5: /var/cache raw-size: 64 GiB size: 64 GiB (100.00%)
used: 39.51 GiB (61.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 2f59c53d-f669-48fb-a956-3d5e1b4008b7
ID-6: /var/log raw-size: 64 GiB size: 64 GiB (100.00%)
ID-1: swap-1 type: partition size: 18 GiB used: 5.8 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 19d6a887-5054-4544-967a-b0bcff19cb9c
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Realtek Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:58f4 class-ID: 0e02
serial: <filter>
Device-2: 1-7:3 info: Foxconn / Hon Hai type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 0489:e0a2 class-ID: e001
Device-3: 1-10:4 info: Shenzhen Goodix Fingerprint Reader
type: abstract (modem),CDC-data driver: cdc_acm interfaces: 2 rev: 2.0
chip-ID: 27c6:5385 class-ID: 0a00 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Hub-5: 3-1.3:3 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0612
Device-1: 3-1.3.1:5 info: Realtek USB Audio type: HID
chip-ID: 0bda:48f0 class-ID: 0300
Device-2: 3-1.3.3:7 info: Logitech C920 HD Pro Webcam type: video,audio
Hub-6: 3-1.4:4 info: Genesys Logic USB2.1 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0611
Device-1: 3-1.4.1:6 info: Apple Aluminium Keyboard (ANSI)
type: keyboard,mouse driver: apple,usbhid interfaces: 2 rev: 2.0
chip-ID: 05ac:024f class-ID: 0301
Device-2: 3-1.4.2:8 info: Logitech Unifying Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52f class-ID: 0300
Device-3: 3-1.4.3:9 info: GN Netcom Jabra SPEAK 410 USB type: audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 4-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 05e3:0625
Hub-9: 4-1.3:3 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0621
Device-1: 4-1.3.2:5 info: Genesys Logic USB Storage type: mass storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 05e3:0754 class-ID: 0806
serial: <filter>
Device-2: 4-1.3.4:6 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
Hub-10: 4-1.4:4 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
System Temperatures: cpu: 51.0 C pch: 48.0 C mobo: 40.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 0
Processes: 306 Power: uptime: 3h 37m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1744 libs: 399 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
