Monitor disconnects when opening specific applications
Today I updated all my applications after a quite long time running pacman -Syu, pamac update -a and snap refresh. Everything went fine so far, but now my external display keeps disconnecting when opening some specific applications (such as IntelliJ Idea) or performing some actions (for example watching a video, pretty much everything that needs some performance). After a few seconds the display will re-connect, but then disconnect again the next time an application is opened / some actions are performed.
This screen is connected via USB-C Adapter (HDMI). My other external screen that is connected just via HDMI has no problem at all. If I connect the working screen to the USB-C adapter it will show the same behavior. So something about the USB-C connection might be off.
I read through some threads and added i915.enable_psr=0 to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub (and ran sudo update-grub), which did not change anything.
I also switched my Kernel back to 5.10 which did not help.
At this point I do not know what to do further, any help would be appreciated :slight_smile:
Here is my inxi -v 8:
  Host: user-20tkcto1ww Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 14.1.1 clocksource: tsc avail: acpi_pm
    root=UUID=685581e0-90e4-41a1-9b03-2048bbd47b51 rw quiet apparmor=1
    security=apparmor resume=UUID=8547ee52-7589-4144-9d7a-aaaa797ee96a
    udev.log_priority=3 i915.enable_psr=0
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
  Type: Laptop System: LENOVO product: 20TKCTO1WW v: ThinkPad X1 Extreme Gen 3
  Mobo: LENOVO model: 20TKCTO1WW v: SDK0J40697 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20TK_BU_Think_FM_ThinkPad
    X1 Extreme Gen 3 uuid: <superuser required> UEFI: LENOVO
    v: N2VET30W (1.15 ) date: 04/15/2021
  ID-1: BAT0 charge: 65.1 Wh (100.0%) condition: 65.1/80.4 Wh (81.0%)
    volts: 17.1 min: 15.4 model: SMP 5B10X19049 type: Li-poly serial: 16
    status: full cycles: 168
  System RAM: total: 32 GiB available: 30.98 GiB used: 12.67 GiB (40.9%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 32 GiB
    speed: spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M471A4G43AB1-CWE
    serial: 03E4FC6A
  Device-2: ChannelB-DIMM0 type: no module installed
  Info: model: Intel Core i7-10850H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/5100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 64821
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand
    rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep smx ss ssbd sse sse2
    xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: DP-1,DP-2 off: eDP-1 empty: DP-3 bus-ID: 00:02.0
    chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: USB C Video Adaptor driver: N/A type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.4:5 chip-ID: 9636:9311
    class-ID: 1100 serial: 000000000001
  Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:6 chip-ID: 13d3:5405
    class-ID: fe01 serial: 0000
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1080 s-dpi: 96 s-size: 676x285mm (26.61x11.22")
    s-diag: 734mm (28.88")
  Monitor-1: DP-1 pos: primary,left model: Acer XF240H serial: T4YEE0014200
    built: 2015 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 chroma: red: x: 0.647
    y: 0.329 green: x: 0.310 y: 0.620 blue: x: 0.153 y: 0.071 white: x: 0.314
    y: 0.329 size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9
    modes: 1920x1080, 1920x1080i, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-2: DP-2 pos: right model: Samsung U32J59x serial: H4LR900250
    built: 2021 res: 640x480 dpi: 23 gamma: 1.2 chroma: red: x: 0.686 y: 0.310
    green: x: 0.259 y: 0.686 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
    720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 95 2: parse_edid:
    unhandled CEA mode 95 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 95 5: parse_edid: unhandled CEA mode 93 6: parse_edid:
    unhandled CEA mode 94
  Monitor-3: eDP-1 note: disabled model: BOE Display 0x08ec built: 2019
    res: 640x480 dpi: 279 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
    x: 0.208 y: 0.710 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 398mm (15.7") ratio: 16:9
    modes: 3840x2160
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 30.25 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 24.0.9-manjaro1.1
    device-ID: 8086:9bc4 surfaces: xcb,xlib
  Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
  API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  IF: wlp0s20f3 state: up mac: 68:54:5a:68:87:65
  IP v4: 192.168.0.129/24 type: dynamic noprefixroute scope: global
    broadcast: 192.168.0.255
  IP v6: 2a02:8388:6282:6980:99d9:e9c2:37c:3c66/64
  IP v6: fe80::cfff:6815:d2b0:d50e/64 type: noprefixroute scope: link
  Device-2: ASUSTek ROG KERIS WIRELESS driver: hid-generic,usbhid type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0b05:1960
    class-ID: 0301
  IF-ID-1: br-6cc02f881015 state: up speed: 10000 Mbps duplex: unknown
    mac: 02:42:69:1f:ac:f6
  IP v4: 172.21.0.1/16 scope: global broadcast: 172.21.255.255
  IP v6: fe80::42:69ff:fe1f:acf6/64 virtual: proto kernel_ll scope: link
  IF-ID-2: docker0 state: down mac: 02:42:5e:a1:4a:62
  IP v4: 172.17.0.1/16 scope: global broadcast: 172.17.255.255
  IF-ID-3: veth23327fe state: up speed: 10000 Mbps duplex: full
    mac: 9a:f1:11:cb:af:d7
  WAN IP: 84.115.216.37
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 134.47 GiB (14.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: X0EF73BHFPZ1 fw-rev: 5108AGLA temp: 44.9 C
    scheme: GPT
  ID-1: / raw-size: 59.61 GiB size: 58.37 GiB (97.93%) used: 48.6 GiB (83.3%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: 685581e0-90e4-41a1-9b03-2048bbd47b51
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
    label: NO_LABEL uuid: AA19-C1D5
  ID-3: /home raw-size: 206.47 GiB size: 202.17 GiB (97.92%)
    used: 85.82 GiB (42.5%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
    label: N/A uuid: 9dd5aa61-94bf-4d8a-8a35-0ec3dc8ed48d
  ID-1: swap-1 type: partition size: 14.9 GiB used: 52.5 MiB (0.3%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 8547ee52-7589-4144-9d7a-aaaa797ee96a
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
    uuid: F816-5F11
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 573.49 GiB fs: bitlocker
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
    label: WinRE_DRV uuid: E8DE190EDE18D6A2
  Device-1: 1-1:2 info: Logitech Logi Bolt Receiver type: keyboard,mouse,HID
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c548 class-ID: 0300
  Hub-2: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-5.4:5 info: USB C Video Adaptor type: billboard driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 9636:9311 class-ID: 1100 serial: 000000000001
  Device-2: 1-6:4 info: ASUSTek ROG KERIS WIRELESS type: HID,mouse,keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:1960 class-ID: 0301
  Device-3: 1-8:6 info: IMC Networks Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5405 class-ID: fe01
    serial: 0000
  Device-4: 1-9:7 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00bd class-ID: ff00 serial: 77164ed87336
  Device-5: 1-14:8 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 4-2:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  System Temperatures: cpu: 38.0 C pch: 58.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 4658 fan-2: 4414
  Packages: 1663 pm: pacman pkgs: 1643 libs: 440 tools: pamac,yay pm: appimage
    pkgs: 0 pm: flatpak pkgs: 0 pm: snap pkgs: 20
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 398
  1: cpu: 28.2% command: java pid: 3120 mem: 4547.2 MiB (14.3%)
  2: cpu: 21.6% command: firefox pid: 3568 mem: 567.6 MiB (1.7%)
  3: cpu: 11.9% command: firefox pid: 5638 mem: 257.7 MiB (0.8%)
  4: cpu: 4.6% command: Xorg pid: 1640 mem: 93.8 MiB (0.2%)
  5: cpu: 4.3% command: kwin_x11 pid: 2444 mem: 197.4 MiB (0.6%)
  Memory top: 5 of 398
  1: mem: 4547.2 MiB (14.3%) command: java pid: 3120 cpu: 28.2%
  2: mem: 1243.5 MiB (3.9%) command: pamac-manager pid: 5561 cpu: 1.2%
  3: mem: 567.6 MiB (1.7%) command: firefox pid: 3568 cpu: 21.6%
  4: mem: 421.8 MiB (1.3%) command: brave pid: 6303 cpu: 4.2%
  5: mem: 393.2 MiB (1.2%) command: brave pid: 6571 cpu: 4.1%
  Processes: 398 Power: uptime: 18m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.38 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 255 default: graphical tool: systemctl
  Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Bash v: 5.2.26
    running-in: hyper inxi: 3.3.34
The output of unplugging and plugin in again (journalctl -fk)
usb 1-5: USB disconnect, device number 9
usb 1-5.4: USB disconnect, device number 10
usb 4-2: USB disconnect, device number 3
usb 1-4: new high-speed USB device number 11 using xhci_hcd
usb 4-1: new SuperSpeed USB device number 4 using xhci_hcd
usb 4-1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.5sb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 4-1: Product: USB3.1 Hub
usb 4-1: Manufacturer: GenesysLogic
hub 4-1:1.0: USB hub found
hub 4-1:1.0: 4 ports detected
usb 1-4: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.55
usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-4: Product: USB2.1 Hub
usb 1-4: Manufacturer: GenesysLogic
hub 1-4:1.0: USB hub found
hub 1-4:1.0: 4 ports detected
usb 1-4.4: new full-speed USB device number 12 using xhci_hcd
usb 1-4.4: not running at top speed; connect to a high speed hub
usb 1-4.4: New USB device found, idVendor=9636, idProduct=9311, bcdDevice= 2.01
usb 1-4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-4.4: Product: USB C Video Adaptor
usb 1-4.4: Manufacturer: USB C
usb 1-4.4: SerialNumber: 000000000001
If any further output is needed just let me know.
Edit: This topic closed automatically. Thanks for your help @Olli & @linux-aarhus. I tried using a different USB-C adaptor and everything is working fine now :tada:
which of them is connected via usb-c?
Currently the Samsung U32J59x, but i tried switching and also the Acer wont work
connected via USB-C
Noting you are using x11
Lenovo and Intel - usually a really good combination
This may be causing your issues - the adapter you are using - according the linux hardware database the device is failing on the probed devices.
this was the warning/error with the samsung
can you try this with the acer again and run the inxi command to check if the same edid-error/warning is also existing with the acer ?
