Hi everyone,
I recently upgraded my graphics card from an R7 360 to an RX 6650 XT on my Manjaro system. Before the upgrade, everything was working fine, but now I’m facing some issues with my monitors and windows.
Problem Description:
- Monitor State: After installing the RX 6650 XT, both of my monitors start going off and on intermittently.
- Window Movement: I noticed that some open windows are randomly moving from one monitor to another without any user input. This behavior is unexpected and disruptive to my workflow.
Hardware Details:
- Old Graphics Card: R7 360
- New Graphics Card: RX 6650 XT
- Monitors: (Provide details about your monitors, such as make, model, and resolution)
- Connection: I’m using a DisplayPort to DVI cable to connect one of my monitors to the RX 6650 XT.
I also dont have any problem in i3.
Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b335dd10-3c78-4954-9f16-e82e50777fe8 rw quiet splash apparmor=1
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 info: docker wm: gnome-shell
dm: GDM v: 44.1 Distro: Manjaro Linux base: Arch Linux
Mobo: ASUSTeK model: TUF GAMING H770-PRO WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1002
date: 03/31/2023
System RAM: total: 32 GiB available: 31.16 GiB used: 10.17 GiB (32.6%)
Info: model: 13th Gen Intel Core i7-13700KF bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x113
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 2224 high: 3400 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1086 2: 1100 3: 1100
4: 3400 5: 1100 6: 3400 7: 1100 8: 3400 9: 1100 10: 3400 11: 1100 12: 1100
13: 1100 14: 3400 15: 1100 16: 3400 17: 800 18: 800 19: 3400 20: 3400
21: 3400 22: 3400 23: 3400 24: 3400 bogomips: 164088
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep serialize sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-2,DP-3,HDMI-A-1 empty: DP-1 bus-ID: 03:00.0 chip-ID: 1002:73ef
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4920x1920 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 mapped: DisplayPort-1 pos: bottom-r model: Asus VS228
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: DP-3 mapped: DisplayPort-2 pos: top-left model: MSI MP241X
serial: <filter> built: 2021 res: 1080x1920 hz: 60 dpi: 93 gamma: 1.2
size: 296x527mm (11.65x20.75") diag: 604mm (23.8") ratio: 16:9 modes:
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: primary,bottom-c
model: BenQ VZ2350 serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 96
gamma: 1.2 size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9
modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 6650 XT (navi23
LLVM 15.0.7 DRM 3.49 6.1.41-1-MANJARO) direct-render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-3: JMTek LLC. G33 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.3.4:9
chip-ID: 0c76:16c6 class-ID: 0300 serial: <filter>
API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:125c
class-ID: 0200
IF-ID-1: br-a023a4865ce1 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: br-a934f8a0973b state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-3: docker0 state: down mac: <filter>
all]
IF-ID-4: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
all]
IF-ID-5: vethd5937ca state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: vethe4df92a state: up speed: 10000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 21 state: up address: see --recommends
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 5.09 TiB used: 1.05 TiB (20.6%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 48.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: MP600 PRO LPX
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM31.4 temp: 48.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VX013-2XG104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5425 serial: <filter> fw-rev: CV11 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU630 size: 447.13 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 214b
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 0217 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 158.45 GiB (34.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:5
label: N/A uuid: b335dd10-3c78-4954-9f16-e82e50777fe8
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4 label: N/A
uuid: 7CCC-A54F
ID-3: /mnt/F1 raw-size: 447.13 GiB size: 439.04 GiB (98.19%)
used: 209.87 GiB (47.8%) fs: ext4 dev: /dev/sdb maj-min: 8:16 label: FS1
uuid: e923fc2b-5ba2-4334-ab06-1bd932f09f05
ID-4: /mnt/corsair raw-size: 456.7 GiB size: 448.46 GiB (98.20%)
used: 128.37 GiB (28.6%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:1
label: N/A uuid: 97596717-83df-42b5-bb5a-06d765982aea
ID-5: /run/media/mahdi/5FE98CE579525529 raw-size: 102.69 GiB
size: 102.69 GiB (100.00%) used: 39.41 GiB (38.4%) fs: ntfs dev: /dev/sdc2
maj-min: 8:34 label: N/A uuid: 5FE98CE579525529
ID-6: /run/media/mahdi/Files1 raw-size: 1.83 TiB size: 1.8 TiB (98.37%)
used: 540.76 GiB (29.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Files1
uuid: b885b3f8-0e42-4611-81f1-a7aac93aacb8
ID-1: swap-1 type: partition size: 9.06 GiB used: 41.1 MiB (0.4%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: eafd6f95-72c9-4499-ae4a-15ccc08370d7
ID-1: /dev/sda2 maj-min: 8:2 size: 1.81 TiB fs: ext4 label: Files 2
uuid: 5256a847-1643-477c-ac11-5b8800cad2bd
ID-2: /dev/sdc1 maj-min: 8:33 size: 300 MiB fs: vfat label: N/A
uuid: CAB5-B98C
ID-3: /dev/sdc3 maj-min: 8:35 size: 8.8 GiB fs: swap label: N/A
uuid: e2cbf23c-f9fe-4e2d-acf1-cb65621e002b
Device-1: 1-2:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Device-2: 1-3:3 info: Microsoft Natural Ergonomic Keyboard 4000 V1.0
type: keyboard,HID driver: microsoft,usbhid interfaces: 2 rev: 2.0
chip-ID: 045e:00db class-ID: 0300
Hub-2: 1-6:4 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-6.1:6 info: [Maxxter] Optical gaming mouse type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 18f8:0f99 class-ID: 0301
Hub-3: 1-6.3:8 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-6.3.4:9 info: JMTek LLC. G33 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Device-2: 1-14:5 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-4: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Device-1: 2-7:2 info: Western Digital Elements Portable (WDBUZG)
type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 144mA
chip-ID: 1058:10a8 class-ID: 0806 serial: <filter>
Hub-5: 2-9:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 56.0 C
mem: 58.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 577 Uptime: 3d 16h 41m wakeups: 83 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1820 pm: pacman pkgs: 1762 libs: 504 tools: gnome-software,pamac
pm: flatpak pkgs: 58 Shell: Zsh v: 5.9 running-in: alacritty inxi: 3.3.28
