Momentary self resolved display corruption using Librewolf
Since Librewolf 154 and now on 155 I’m getting momentary self resolving display corruption only within the Librewolf window. Its more prominent when navigating away from a webpage or opening a new tab after playing a video.
Occurs on a clean profile also.
I haven’t yet tested Firefox to see if it also has the issue but it might.
Anyone else? So I can compare setups for troubleshooting?
inxi -zv8
  Kernel: 7.2.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.2-x86_64
    root=UUID=ca0fb9dc-ae10-46f2-a467-6c788f67cecc rw rootflags=subvol=@
    quiet splash resume=UUID=a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1
    udev.log_priority=3 sysrq_always_enabled=1 zswap.enabled=1
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
    wm: kwin_wayland with: krunner vt: 2 dm: N/A Distro: Manjaro
    base: Arch Linux
  Type: Convertible System: Dell product: XPS 15 9575 v: N/A
    serial: <superuser required> Chassis: type: 31 serial: <superuser required>
  Mobo: Dell model: 0C32VW v: A00 serial: <superuser required> part-nu: 080D
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.28.0
    date: 07/11/2023
  ID-1: BAT0 charge: 44.4 Wh (100%) condition: 44.4/75 Wh (59.2%) volts: 12.79
    min: 11.4 model: BYD DELL TMFYT8C type: Li-poly serial: <filter> charging:
    status: full type: custom avail: adaptive,custom,fast,standard,trickle
    cycles: N/A
  System RAM: total: 16 GiB available: 15.46 GiB used: 5.56 GiB (36.0%)
  Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
  Device-1: Motherboard type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: SK Hynix
    part-no: HMAA51S6AMR6N-UH serial: N/A
  Info: model: Intel Core i7-8705G bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 49599
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel Kaby Lake-H GT2 [HD Graphics 630] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:591b
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Polaris 22 XL [Radeon RX Vega
    M GL] vendor: Dell driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:694e class-ID: 0380
    temp: 46.0 C
  Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0bda:58f4
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Sharp 0x148d built: 2018 res: mode: 2560x1440
    hz: 60 scale: 125% (1.25) to: 2048x1152 dpi: 284 gamma: 1.2 chroma: red:
    x: 0.667 y: 0.325 green: x: 0.208 y: 0.737 blue: x: 0.145 y: 0.047 white:
    x: 0.318 y: 0.337 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 3840x2160
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
    device-ID: 8086:591b memory: 15.09 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.357 layers: 13 device: 0 type: integrated-gpu
    name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 26.2.2-arch1.1
    device-ID: 8086:591b surfaces: N/A device: 1 type: discrete-gpu name: AMD
    Radeon RX Vega M GL Graphics (RADV VEGAM) driver: mesa radv
    v: 26.2.2-arch1.1 device-ID: 1002:694e surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel HM175/QM175/CM238 HD Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a171 class-ID: 0403
  API: ALSA v: k7.2.3-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
    class-ID: 0280 temp: 47.0 C
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.2:6
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u2u2 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0489:e0a2
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
    lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0000
  Local Storage: total: 1.82 TiB used: 184.66 GiB (9.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T710SSD8
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: PBCR5103 temp: 35.9 C
    scheme: GPT
  ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 184.66 GiB (10.0%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: Manjaro
    uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
    used: 664 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
    uuid: FF0B-6823
  ID-3: /home raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
    used: 184.66 GiB (10.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: Manjaro uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
  ID-4: /home/<filter>/mnt/Dropbox raw-size: N/A size: 2.01 TiB
    used: 340.8 GiB (16.6%) fs: fuse.rclone remote: Dropbox:
  ID-5: /home/<filter>/mnt/GDrive raw-size: N/A size: 102 GiB
    used: 85.82 GiB (84.1%) fs: fuse.rclone remote: GDrive:
  ID-6: /home/<filter>/mnt/OneDrive raw-size: N/A size: 205 GiB
    used: 144.8 GiB (70.6%) fs: fuse.rclone remote: OneDrive:
  ID-7: /var/cache raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  ID-8: /var/log raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: partition size: 17.58 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1
  Device-1: 1-1:2 info: Realtek Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:58f4 class-ID: 0e02
    serial: <filter>
  Hub-2: 1-2:3 info: VIA Labs VL820 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2820
  Device-1: 1-2.1:6 info: Bizlink DELL DA300 type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 06c4:c412 class-ID: 0300
    serial: <filter>
  Device-2: 1-2.3:13 info: Lite-On USB Multimedia Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 04ca:0027 class-ID: 0300
  Device-3: 1-6:4 info: Foxconn / Hon Hai type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0489:e0a2 class-ID: e001
  Device-4: 1-10:16 info: Shenzhen Goodix Fingerprint Reader
    type: abstract (modem),CDC-data driver: N/A interfaces: 2 rev: 2.0
    chip-ID: 27c6:5395 class-ID: 0a00 serial: <filter>
  Device-5: 1-11:7 info: Logitech G502 Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c07d class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
  Hub-4: 2-2:5 info: VIA Labs VL820 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0820
  Device-1: 2-2.2:6 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 47.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1764 libs: 453 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://mirrors.manjaro.org/repo/testing/$repo/$arch
    2: https://opencolo.mm.fcix.net/manjaro/testing/$repo/$arch
    3: https://irltoolkit.mm.fcix.net/manjaro/testing/$repo/$arch
    4: https://codingflyboy.mm.fcix.net/manjaro/testing/$repo/$arch
    5: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/testing/$repo/$arch
Processes:
  CPU top: 5 of 313
  1: cpu: 12.8% command: librewolf pid: 601321 mem: 747.3 MiB (4.7%)
  2: cpu: 6.1% command: librewolf pid: 609418 mem: 372.8 MiB (2.3%)
  3: cpu: 2.7% command: kwin_wayland pid: 2777 mem: 403.8 MiB (2.5%)
  4: cpu: 2.6% command: librewolf pid: 601449 mem: 105.0 MiB (0.6%)
  5: cpu: 2.5% command: librewolf pid: 601486 mem: 314.9 MiB (1.9%)
  Memory top: 5 of 313
  1: mem: 747.3 MiB (4.7%) command: librewolf pid: 601321 cpu: 12.8%
  2: mem: 482.4 MiB (3.0%) command: librewolf pid: 601850 cpu: 1.8%
  3: mem: 467.0 MiB (2.9%) command: plasmashell pid: 3614 cpu: 0.1%
  4: mem: 403.8 MiB (2.5%) command: kwin_wayland pid: 2777 cpu: 2.7%
  5: mem: 373.2 MiB (2.3%) command: librewolf pid: 601509 cpu: 0.6%
  Processes: 313 Power: uptime: 1d 4h 40m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 7 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: Zsh v: 5.9.2
    running-in: konsole inxi: 3.3.41
Could it have something to do with the setting to use hardware acceleration for video?
Notes:
  1. I don’t use librewolf and I am not familiar with its settings, but from my understanding, it would be firefox-based. Therefore, I presume it would have similar settings.
  2. Could it be that (your installed version of) librewolf uses XWayland, rather than Wayland directly?
Don’t run librewolf but I can try since you have also a AMD more or less from the same year. I’ve seen similar corruption with firefox though. But I didn’t investigate since everything kinda bleeding edge
Very close to being the same - For this issue I expect Firefox will also have the issue (hopefully I can test it today).
Definitely one of the 1st things I checked. Definitely running on native Wayland.
Did it start after 154? And is it momentary display corruption that resolves itself in a split second? I notice it on the left side of the screen mostly and I haven’t been quick enough to capture it. I’m not doing any work that makes this anything more than an ugly annoyance but it is distracting.
Yep, but is rather random. In my case though, it’s not a corruption but more a glitch of old times. I installed librewolf, I’ll let you know if the corruption jumps out.
Update: It appears to be upstream of Librewolf as the same thing happens on Firefox and on a clean updated Manjaro. Unfortunately I don’t have any other hardware to test on further.
It’s annoying but I can’t seem to find any other reports of the same thing, so I’ll wait a few releases and see if it resolves itself.
