Molly-guard doesn't work
Hello,
from my Manjaro I administrate my Rasperry Pis. Unfortunately it already happened that I accidentally restarted my local system instead of the remote system.
Under Debian/Ubuntu or Raspbian molly-guard works very well.
https://aur.archlinux.org/packages/molly-guard
Unfortunately, molly-guard doesn’t seem to work locally on my Manjaro, even though I changed the config:
cat /etc/molly-guard/rc
# molly-guard settings
# ALWAYS_QUERY_HOSTNAME
# when set, causes the 30-query-hostname script to always ask for the
# hostname, even if no SSH session was detected.
ALWAYS_QUERY_HOSTNAME=true
# USE_FQDN
# when set, causes the 30-query-hostname script to ask for the fully-qualified
# hostname, rather than the short name
#USE_FQDN=true
sudo reboot
is performed after the sudo password prompt without asking for the hostname.
What am I doing wrong?
Do I perhaps have a way elsewhere to set up the reboot of my machine via the console with a security prompt?
vkr
psyc
I have already tested it with Manjaro XFCE and Manjaro KDE, with the same result.
Did you read and proceed this after installation?
https://aur.archlinux.org/cgit/aur.git/tree/molly-guard.install?h=molly-guard
Hello,
thank you very much. No, I have not seen this hint yet.
How do I have to apply this?
user$ source "/etc/profile.d/molly-guard.sh"
user$ sudo reboot
reboot without asking for the hostname
user$ sudo source "/etc/profile.d/molly-guard.sh"
sudo: source: command not found
Maybe you can help me with this?
thanks and greetings
psyc
Gosh… this guard works with aliases. These aliases written in /etc/profile.d/molly-guard.sh and gets loaded after every login.
source "/etc/profile.d/molly-guard.sh" is only needed if you need it instantly without re-log/reboot.
Simply don’t use sudo here? As I see it replaces: halt poweroff reboot shutdown, but not sudo. It is not needed here. Or add like mentioned an alias: alias sudo="sudo "
Hello Megavolt,
unfortunately, I don’t quite understand it. Why is it not clearly described in the documentation what must be done?
I did a little “try and error” At the end I have the following lines in my
~/.bashrc
# molly-guard
alias sudo='sudo '
If i type
sudo reboot
it asks for the hostname and (the most important) if I cancel this security question, my local manjaro will not reboot either.
Nice!!
Thanks for your patience.
Greetings
psyc
Because molly-guard is just a simple helper script, just like for example manjaro-chroot. It is just a helper to setup such a simple guard. You can do it also without it pretty easy, just write some functions and add aliase, thats it.
The only source I found is the one from debian, so I conclude it is made with debian in mind, just like manjaro-chroot is made with manjaro in mind.
It is pretty much this script: File: shutdown.in | Debian Sources 126 lines of code. I don’t understand why you need to use exactly this, but well, everyone has different habits.
