Hi all
I’ve installed virtualbox, but i get error message i don’t know the meaning
My kernel version: 5.13.19-2-MANJARO
Hi all
Virtualbox brings a kernel module that must be activated first.
https://wiki.archlinux.org/title/VirtualBox#Load_the_VirtualBox_kernel_modules
Thank you maycne.sonahoz, but:
[bozzoh@bozzoh ~]$ sudo modprobe vboxdrv
[sudo] Mot de passe de bozzoh :
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/5.13.19-2-MANJARO
You do not have linux513-virtualbox-host-modules
installed …
Also. Linux513 is EOL, you should switch to either 514 or 510.
Ok!
Second time you help me maycne.sonahoz
It works
Thanks for the recommandation Strit, but i don’t know what is EOL and it works that way ?
EOL means End Of Life, which means that the kernel no longer gets updates and will be removed (together with it’s extra modules) from the repo sometime soonish.
Ah ok!
So i’d better follow your suggestion
Thank you Strit
Kernel 5.10 is LTS, this is the one you want as it will not be removed for the next 5 years or so. Or keep up with the news and kernel life cycle in the announcements, and change kernel before they get removed.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
