modrinth crashes when pressing the 3 dots to open export and settigs menu aswell as crashes on logs screen.
Welcome, Noah,
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Modrith
Modrinth is a game launcher, available in Flatpak. By doing a quick Web Search I found one or two possible solutions…
You might first ensure that the Flatpak is set up right:
flatpak repair
flatpak update
Then you might try to launch it in a terminal something like…
flatpak run com.modrinth.ModrinthApp
Sometimes we just need to remove the application config files, and I’m not too familiar with the location of those for a flatpak.
It’s also in the AUR and available as an AppImage.
So more information is definitely required here.
