i have modemmanager 1.22.0 package
after enabling ther service and starting it with:
systemctl start ModemManager.service
systemctl enable ModemManager.service
i try to scan for modems and i get this error:
mmcli --scan-modems ✔
error: couldn't request to scan devices: 'GDBus.Error:org.freedesktop.ModemManager1.Error.Core.Cancelled: Operation was cancelled'
journalctl --no-pager --no-hostname -b -u ModemManager 1 ✘
أفريل 20 07:23:38 systemd[1]: Starting Modem Manager...
أفريل 20 07:23:38 ModemManager[433]: <msg> ModemManager (version 1.22.0-1) starting in system bus...
أفريل 20 07:23:38 systemd[1]: Started Modem Manager.
أفريل 20 07:23:42 ModemManager[433]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
أفريل 20 07:23:42 ModemManager[433]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1f.6': not supported by any plugin
أفريل 20 07:25:36 ModemManager[433]: <msg> [sleep-monitor-systemd] system is about to suspend
أفريل 20 07:29:42 ModemManager[433]: <msg> [sleep-monitor-systemd] system is resuming
أفريل 20 07:29:46 ModemManager[433]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
أفريل 20 07:29:46 ModemManager[433]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1f.6': not supported by any plugin
أفريل 20 07:51:31 ModemManager[433]: <msg> [sleep-monitor-systemd] system is about to suspend
أفريل 20 10:04:30 ModemManager[433]: <msg> [sleep-monitor-systemd] system is resuming
أفريل 20 10:04:34 ModemManager[433]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
أفريل 20 10:04:34 ModemManager[433]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1f.6': not supported by any plugin
أفريل 20 10:08:06 ModemManager[433]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
أفريل 20 10:08:06 ModemManager[433]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1f.6': not supported by any plugin
أفريل 20 10:11:34 ModemManager[433]: <wrn> Error cancelling authorization check: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: No such cancellation_id `cancellation-id-0' for name :1.8
أفريل 20 10:14:26 ModemManager[433]: <wrn> Error cancelling authorization check: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: No such cancellation_id `cancellation-id-1' for name :1.8
أفريل 20 10:20:51 ModemManager[433]: <wrn> Error cancelling authorization check: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: No such cancellation_id `cancellation-id-2' for name :1.8
أفريل 20 10:21:09 ModemManager[433]: <wrn> Error cancelling authorization check: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: No such cancellation_id `cancellation-id-3' for name :1.8
“You need to restore this file. Your linked Topic is about something different. After the restore restart your system.”
i removed it with sudo krusader. i think it doesnt go to trash and it is removed permanently
i have reinstalled it and the file is there again.
“Do not use sudo, and you should see an authentication window for your local user.” yes the windows appear and i enter the password.
now the problem is fixed. i get:
successfully requested to scan devices
